Tailgate Options
Discussion in '1st Gen Tundras (2000-2006)' started by jsvwx, Oct 19, 2024.
  1. Oct 19, 2024 at 5:39 AM
    jsvwx
    jsvwx [OP] New Member
    New York
    2001 AC SR5 V6 5M 4WD
    Hi everyone. Just purchased a 2001 Tundra SR5 AC 6.5’ bed V6 manual in tan, which I think is the desert sand mica. The top of the tailgate was dented and I’m trying to figure out what options I have. Are all tailgates interchangeable for all tundras between 2001 to 2006? If I can find a tall enough cap molding, then I can cover it, but no luck searching online so far. The other option is a junkyard, but so far I found a couple that came off the V8s. Thanks!
  2. Oct 19, 2024 at 5:42 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    AC and DC are different trucks more or less.
    Look for another AC donor.
    jsvwx[OP] and shifty` like this.
  3. Oct 19, 2024 at 5:48 AM
    Hello friend.
    Please do yourself a favor and read this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It should answer many questions and give you the warnings you need to hear. Not a ton of V6 content but … “enough” stuff you absolutely need to know.
    jsvwx[QUOTED][OP] likes this.
  4. Oct 19, 2024 at 10:00 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    The access cab tailgate is shorter in height than a double cab tailgate
    jsvwx[OP] likes this.
  5. Oct 20, 2024 at 3:33 AM
    jsvwx
    New York
    Thanks guys for the advice! So if I'm reading this post correctly, I have to look for AC tailgates only, but can it come off an AC with a V8 and/or AT?
  6. Oct 20, 2024 at 4:13 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    IIRC AC and RC are same. DC is different.
  7. Oct 20, 2024 at 6:41 AM
    No no, not at all.
    • AC and RC share virtually all body parts, major exceptions being one bed is longer and one cab is larger but otherwise same doors, same front/rear glass etc. This includes the tailgate, of course.
    • DC is a totally different beast, but it and the Sequoia share a number of body parts, but the bed of DC is taller, with a totally different height/profile from the AC/RC, different doors, different fender flares, etc. - DC is more a "3rd cousin" to the AC/RC and more like a sibling of the Sequoia
    • AC DC RC do have wiring harnes differences for electrical stuff
    • AC DC RC do share a lot of engine and electrical parts
    • Engine-wise, 00-04 are pretty similar, 05-06 are nearly identical, but there's pretty siginificant differencess between the two year ranges (00-04 and 05-06), and people need to be wary when swapping engines in the 00-04 range because of varying wire pinouts for the throttle body, specifically
  8. Oct 20, 2024 at 7:41 AM
    BuzzardsGottaEat
    '16 Tundra DCLB
    Round Tires
    Any AC (or RC) with any engine and transmission and whatever else configuration will have the same tailgate size, correct.
    DC is out.
