Tailgate soft drop not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dank1296, Jun 21, 2019.
  1. Jun 21, 2019 at 7:36 PM
    Dank1296
    Dank1296 [OP] New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    2015 TRD 4x4 tailgate soft drop down not working. Truck still under extended warranty. Is this something that dealer will fix. Or is there an easy fix i can do. Thanks for suggestions
  2. Jun 21, 2019 at 7:48 PM
    AZTundra
    Paul
    Phoenix, AZ
    There is a shock located behind the left rear taillight.
    TheBeast likes this.
  3. Jun 21, 2019 at 9:19 PM
    TheBeast The Beach
    happened to mine at around 45K..dealer replaced it.
  4. Jun 21, 2019 at 9:23 PM
    AZTundra
    Paul
    Phoenix, AZ
    There was a picture somewhere on here, but I couldn't find it. Even checked Google, but came up empty handed. Dealer should be able to cover if under warranty....
  5. Jun 21, 2019 at 10:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dang, mine waited until truck was 1 year out of warranty to wear out! Lucky youres happened fast
  6. Jun 22, 2019 at 11:24 AM
    TopShapeCabrio
    TopShapeCabrio New Member
    Pat
    2017 DC Tundra TRD
    Raider LoRider Tonneau Cover/WeatherTech
    AZTundra[QUOTED] likes this.
  7. Jun 22, 2019 at 7:47 PM
    msbaugh440
    msbaugh440 2019 limited, TRD package, cement
    Utah
    2019 Tundra limited, TRD off road, Cement
    Takes 10 seconds to remove it if you want to just take it in and have them give you a new one. Not sure how a strut could fail, there is a weird bellows looking thing on the bottom maybe that failed (if it’s not just a dust cover), or maybe it just popped off the ball. Just need a 30 torx bit to remove the drivers side tail light and a flat head screw driver... remove it with the tail gate up...
