Tailshaft Seal Replacement - Need advice
Discussion in 'General Tundra Discussion' started by minter66, Aug 23, 2023.
  1. Aug 23, 2023 at 8:13 AM
    minter66
    minter66 [OP] 2007 TSS CrewMax
    I originally noticed leaking last year when putting in my catalytic shield.
    https://www.tundras.com/threads/what-is-happening-here.116171/
    Last weekend I finally took it to my dads and put it on his lift and replaced the tail shaft seal as well as flushed the transmission fluid. I didn't notice any leaking for 2 days, but I just crawled up under the truck and now there is a few drips of red/pink ATF hanging from the tailshaft again.
    Im about to take a 1300 mi trip to Iowa and back to get our new camper. I am looking for advice on what to do.
    1) Replace the seal again - maybe I bought a bad one or I didn't install it right?
    2) Put gasket sealer designed for oil/gas around the seal in the tailshaft
    3) Drive it as is and bring ATF with me in case the leak gets worse.
  2. Aug 23, 2023 at 9:53 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Did you notice any abnormal wear on the driveshaft where it inserts into the tailshaft?
  3. Aug 23, 2023 at 9:59 AM
    Slag_Dynamics
    Arizona
    Gone
    I also believe there is a bushing inside the tailshaft that may be worn allowing too much fluid to get past and the seal may be unable to contain it.
  4. Aug 23, 2023 at 11:18 AM
    minter66
    Someone in my old thread mentioned this. I appreciate you confirming it. I did not notice wear, but I also was really focused on the seal and getting the ATF flush done.
    So the bushing is also some sort of seal? The actual shaft is not the problem? Any idea on the part number?
  5. Aug 23, 2023 at 11:40 AM
    Slag_Dynamics
    Arizona
    Gone
    The actual tailshaft housing as a unit with bushing and seal should be 35180-04010 and is like $400-450.00.
    Here are some photos showing that bushing.
  6. Aug 23, 2023 at 11:40 AM
    minter66
    Yikes - no way to replace just the bushing then?
  7. Aug 23, 2023 at 1:19 PM
    Slag_Dynamics
    Arizona
    Gone
    You can, I’m just showing the bushing and where it’s located. It’s easier than just posting the bushing. I do believe you need to remove the entire tailshaft and insert it from the transmission side of the shaft though.
  8. Aug 23, 2023 at 3:45 PM
    minter66
    Thank you for the valuable information. Looking into bushing now. I assume there is a gasket of some sort between the tailshaft housing and the end of transmission?
  9. Aug 23, 2023 at 6:01 PM
    Slag_Dynamics
    Arizona
    Gone
    Yes there is.
  10. Aug 25, 2023 at 9:55 AM
    minter66
    Well I ended up taking it into a shop.
    First problem, I apparently did not install the seal correctly. I had it cocked a little to the 11 oclock position. I bought a new seal and delivered it to the shop where they installed it
    Second problem, he said the bushing seemed fine, but the output shaft from the transmission can move around. Is it supposed to be able to move or be firm/solid?
    At this point it sounds like I need to take it to a transmission shop as the output shaft should not be moving.
  11. Aug 25, 2023 at 10:07 AM
    Slag_Dynamics
    Arizona
    Gone
    I believe the bushing is what helps keep the shaft aligned and from moving too much within the seal. I’m not a transmission expert though. If the shaft is moving too much, I would imagine the seal will continue to leak due to pressure from the shaft. I would also think some lateral movement is expected.
  12. Aug 25, 2023 at 10:15 AM
    minter66
    Then it is worth it for me to try to replace the bushing or just the entire housing. If that does not solve it - off to a transmisson shop then.
    Thank you for your help.
