Take full control of your Toyota’s factory e-locker
Discussion in '3rd Gen Tundras (2022+)' started by CajunTim, Mar 17, 2025.
  1. Mar 17, 2025 at 8:15 PM
    CajunTim
    CajunTim [OP] Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    What is everyone’s opinion on this?
    2022-Current Tundra
    Compatible with: Any Model with a Factory installed E-Locker
    Unlock Your Vehicle’s True Potential
    Take full control of your Toyota’s factory e-locker with the Freedom Locker, the ultimate upgrade for off-road enthusiasts and adventurers. Designed to enhance your vehicle’s capability, the Freedom Locker allows you to engage your factory e-locker not just in 4WD low but also in 2WD and 4WD high, giving you unparalleled flexibility and traction in all driving conditions.
    Key Features:
    • Extended E-Locker Functionality: Unlock your factory e-locker in 2WD, 4WD high, and 4WD low for complete traction control in any terrain.
    • Seamless Integration: Specifically engineered for Toyota vehicles, the Freedom Locker works flawlessly with your factory 4WD system without compromising OEM features.
    • Enhanced Off-Road Capability: Navigate challenging trails, loose sand, mud, or snow with confidence, knowing your vehicle is equipped to handle it all.
    • Plug-and-Play Installation: Simple and straightforward setup with no cutting or extensive modifications required.
    • Durable Build: Made with high-quality components to ensure reliable performance and longevity, even under extreme conditions.
    Why Choose the Freedom Locker?
    • Maximized Traction: Overcome obstacles with ease by locking your rear differential whenever you need it.
    • Automatically Turns off Traction Control : No need to Press another Button to get traction control turned off, let the Freedom Locker do it for you.
    • Off-Road Freedom: Say goodbye to factory limitations and hello to total control over your vehicle’s capabilities.
    The Freedom Locker is the essential upgrade for Toyota owners who demand more from their vehicles. Whether you’re exploring backroads, conquering rugged landscapes, or just looking for added control in everyday conditions, the Freedom Locker has you covered.
    Unleash the full power of your Toyota. With the Freedom Locker, you’re not just driving—you’re dominating
    https://rogue-offroad.com/Freedom-Locker--22-Tundra_p_22132.html
    Yaboy and ScottieBones like this.
  2. Mar 18, 2025 at 3:56 AM
    Daedalus
    Daedalus New Member
    That is a major frustration with this platform. My F150 would allow it to be engaged at any time under 20/25mph. Regardless of drive state.
    Very handy, especially if you didnt need to be in 4 wheel drive.
  3. Mar 18, 2025 at 5:43 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    My Ford F250 would lock anytime, I mostly used it in gravel when I didn't quite need 4wd. It comes in handy.
    Daedalus likes this.
  4. Mar 18, 2025 at 9:20 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    How do I know if my truck has a Factory installed E-Locker or not?
  5. Mar 18, 2025 at 10:58 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    I believe all TRD Offroad & TRD Pro models have the e locker - not sure if any add on packages in the US add it or not.
  6. Mar 18, 2025 at 11:04 AM
    gmcguire7220
    Ontario Canada
    It says plug and play, but where does it get plugged into - to the locker switch & ? Behind the Dash Console?
  7. Mar 18, 2025 at 11:06 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Dont think 2023 Platinums had elockers available
  8. Mar 18, 2025 at 11:19 AM
    Wolfhound89
    Wolfhound89 New Member
    2024 Tundra TRD Off Road
    I just got off the phone with them. Sounds like all behind the dash for plugging it in and then its got its own light you install to indicate the locker is engaged.
    They also ship to canada.
    Yaboy and gmcguire7220[QUOTED] like this.
  9. Mar 18, 2025 at 11:31 AM
    Daedalus
    Daedalus New Member
    But we have a button already....
    I may browse the wiring schematic and see if there is something there we can bypass....maybe
  10. Mar 18, 2025 at 11:35 AM
    Daedalus
    Daedalus New Member
    P22 is the solenoid....now the trick is finding how to trigger it.
  11. Mar 18, 2025 at 11:39 AM
    Daedalus
    Daedalus New Member
  12. Mar 18, 2025 at 5:51 PM
    Wolfhound89
    I've edited my earlier post about the button/lights included with this.
    Really good install video on the manufacturers website.
    I'll probably be ordering this shortly as I often want the locker in 2x and 4hi.
    https://experimentalinc.com/products/anytime-locker-1
  13. Mar 18, 2025 at 6:57 PM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
  14. Mar 18, 2025 at 8:04 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    BlackNBlu likes this.
  15. Mar 18, 2025 at 8:07 PM
    Retroboy1989
    Northern Utah
    The kit uses the factory button, but it comes with a separate indicator light. My guess would be you have to fool some _CM to get the dash light to come on when you lock in 2/4HI. That would be perfect.
    I also like that F150 unlocks automatically above 25mph. Toyota could have taken a cue from Ford on that one.
    Edit: this was discussed here as well:
    https://www.tundras.com/threads/trd-or-locker-control.122704/
    Daedalus[QUOTED] likes this.
  16. Mar 19, 2025 at 5:56 AM
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    Glad you liked my install video and found it helpful! Its a great unit!
    Wolfhound89[QUOTED] likes this.
  17. Mar 19, 2025 at 6:11 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Correct. TRD Offroad not available on Platinums until '24. Truck must be/have either TRD Pro or TRD Offroad.
    eddiefromcali[QUOTED] likes this.
