Tapping into tail light to power camper shell’s 3rd brake light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Feb 9, 2022.
  1. Feb 9, 2022 at 10:48 AM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Searched the forums but couldn’t find any confirmation for which wires to tap into for powering my ARE’s third brake light on my 18 Tundra. Pictured are the wires for main brake bulb on left tail light.
    I need confirmation that the green wire is positive?
    can I tap into the black/white wire for my ground or do I need to ground off to the frame with a screw, bolt etc?
    Yotatrucks7 likes this.
  2. Feb 9, 2022 at 11:07 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (current)
    Taco-Spike likes this.
  3. Feb 9, 2022 at 11:11 AM
    Taco-Spike
    Two Trucks
  4. Feb 9, 2022 at 5:58 PM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    Deleting this post to avoid confusion.
  5. Feb 9, 2022 at 6:05 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Isn't there an open wire down on 7 prong trailer plug for hooking up brake light ? You can just plug into , or was that for power only?
  6. Feb 9, 2022 at 6:19 PM
    Tundra18overland
    Jesse
    GA
    I’m not experiencing this issue. I tapped into the blue wire and my 3rd brake light on shell now only illuminates when I press the brake pedal.
  7. Feb 9, 2022 at 6:23 PM
    Tundra18overland
    Jesse
    GA
    UPDATE
    Tapped into green originally due to false info given to me and I found my 3rd brake light was constantly on w headlights on. Tapped into blue wire and now my 3rd brake light only illuminates when I press brake pedal. Grounded via the black/white wire. Success.
    I did also use a detachable prong connection (dont know proper term) so if I have to remove shell, I don’t have to un-splice my wiring. Pics attached.
    Tundra family and JH520 like this.
  8. Feb 9, 2022 at 6:25 PM
    Tundra18overland
    Jesse
    GA
    not sure, I know leer sells a special harness that gives you multiple connections for accessories but it’s $110
  9. Feb 9, 2022 at 6:29 PM
    ddact
    ddact New Member
    Are you certain? Turn on the turn signal for the side you tapped into and then look at the 3rd brake light. Then press the brake with the turn signal still on. I may be wrong (hope I am actually), but I'm pretty sure that same wire is energized for both the turn signal and brake, so when the turn signal is on it's flashing.
    I'm sure there is a wire in the truck somewhere that only energizes when the brakes are pushed because the truck has a 3rd brake light. I just wouldn't expect the manufacturer to waste money running that light to the back harness. Could be wrong.
  10. Feb 9, 2022 at 6:52 PM
    Tundra18overland
    Jesse
    GA
    I did exactly what you said. No issue with the 3rd brake light blinking with turn signal. The 3rd brake light is only illuminating (and staying illuminated) while the brake pedal is depressed (even with left turn signal on. (i tapped into left tail light)
    Thanks
    JH520, Yotatrucks7 and BlackSheep like this.
  11. Feb 9, 2022 at 6:58 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Appreciate this thread. I had it figured out on my old cap, but since replaced it, and have yet to connect the brake light on it. Sounds like a good project for this weekend.
    Tundra18overland[OP] likes this.
  12. Feb 9, 2022 at 8:17 PM
    Yotatrucks7
    Yotatrucks7 New Member
    2017 DC Tundra
    I am doing this tomorrow. Glad to confirm I need to tap into the blue wire…thanks!
  13. Feb 10, 2022 at 3:47 AM
    ddact
    ddact New Member
    I stand corrected then. :hattip:
    Like most things I do, it looks like I did it the hard way! :D
    I understand now I think. Looks like the turn signals have their own bulbs.
  14. Feb 10, 2022 at 4:01 AM
    Tundra18overland
    Jesse
    GA
    i know the feeling :rofl:
  15. Aug 14, 2024 at 12:08 PM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    This helped a lot, sometimes the wiring is different colors. I’ve posted pictures of my set up and the wire difference:
    White/Black is the Ground
    Solid Green is the Running Light
    Green/White is the Brake Light IMG_0150.jpg IMG_0151.jpg IMG_0152.jpg
