TCM location in 2011 Tundra?
Discussion in '2nd Gen Tundras (2007-2013)' started by Kspencer33, Jan 7, 2024.
  1. Jan 7, 2024 at 10:38 PM
    Kspencer33
    Kspencer33 [OP] New Member
    Kevin
    2011 Tundra 2wd
    Does anyone know if the 2011 tundra /sequoia have a TCM if so ..where is it located? Is it a separate unit from the ECM?
  2. Feb 5, 2024 at 11:29 AM
    Ssheets
    Ssheets New Member
    Stacie
    2012 toyota tundra rock warrior
    Looking for it too on 2012 tundra
  3. Feb 13, 2024 at 11:22 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    99% certain it's one w the ECM ECU.
  4. Apr 19, 2024 at 12:31 PM
    Adamkhan
    Adamkhan New Member
    2011 Tundra
    Under the Right hand forward kick panel on the side. Remove the bottom door threshold, lower glove compt cover, kick panel and it's mounted on the RH upper side. 2 connectors & one 10mm bolt.
  5. Dec 27, 2024 at 4:36 AM
    Mynikk77
    Mynikk77 New Member
    Nsikak-Abasi Otoh
    Blizzard Pearl White 2010 Toyota sequoia
    Headlight
    I don't think that's TCM.
  6. Dec 27, 2024 at 8:32 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    The OP has a 2WD in his signature line. That looks like a 4WD module? Or am I missing something?
  7. Dec 27, 2024 at 1:29 PM
    Mynikk77
    Mynikk77 New Member
    Nsikak-Abasi Otoh
    Headlight
    4 wheel Module is different from the Transmission Control Module aka Shift lock sub assy computer which is placed under center console. It's right under the shift column.
    Whereas the 4 wheel computer is under the dash on the passenger side. I just replaced both on my 2010 toyota sequoia.
  8. Dec 27, 2024 at 1:56 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    What would cause you to require replacement of both modules? Is your Sequoia AWD or proper Hi/Lo case? Just curious. Learn as we go.
  9. Dec 27, 2024 at 2:16 PM
    Mynikk77
    Mynikk77 New Member
    Nsikak-Abasi Otoh
    Headlight
    It's 4 Wheel. I had shifting issues with my transmission and also 4 wheel won't stay engaged.
  10. Dec 29, 2024 at 8:28 PM
    lr172
    lr172 New Member
    07 DC
    Sorry but that isn’t the tcm either. It is just simple logic for shift interlocking and gear select data output onto canbus. Toyota doesn’t use dedicated tcms. That function is built into the ecm. The tcm uses a lot of engine data, so mosy makers just handle the trans stuff in the ecm/pcm. Gm or ford is one of the exceptions.
  11. Dec 30, 2024 at 6:12 AM
    Mynikk77
    Mynikk77 New Member
    Nsikak-Abasi Otoh
    Headlight
    Oh ok I was wondering why tundra or sequoia does not have a dedicated TCM.
