Temperature gauge
Discussion in '1st Gen Tundras (2000-2006)' started by Foxhunter, Nov 16, 2022.
  1. Nov 16, 2022 at 10:02 AM
    Foxhunter
    Foxhunter [OP] New Member
    Ashley
    02 Tundra 4x4
    My temperature gauge pops up half way when I start the truck and stays there. I replaced the thermostat and coolant temperature sensor so far. Any ideas what else would cause it to do this?
  2. Nov 16, 2022 at 10:14 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I wish mine would do that but realistically. Mine only ticks up to that point after driving 5 highway miles; just enough to pull into a parking space at work. I would think the coolant temp sensor you replaced is faulty. Maybe put back in the old one to check or is that a PIA?
  3. Nov 16, 2022 at 10:28 AM
    Which temperature sensor did you replace? There are two, right next to each other: One for your gauge, and one for the ECM to read temperature. Do you have the part number you installed, so we know which you actually replaced?
  4. Nov 16, 2022 at 11:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here's the OEM part numbers for the temp sensor, and temp sender from my 2000.
    Verify these part numbers fit your truck.
  5. Nov 16, 2022 at 12:58 PM
    Foxhunter
    Ashley
    02 Tundra 4x4
    The green one above i replaced today. I'll check on that other one above it and try that
  6. Nov 16, 2022 at 1:17 PM
    The black one is for the dash gauge ("Gage"). That's the one you need to swap.
    I checked Toyota's Parts system, it shows that part (8342020040 or 83420-20040 using the old style numbering) fits all 2000-2004 Tundras.
    Be careful, buying on scAmazon or fleaBay, you're gonna get a counterfeit part. This isn't a part you want to fail on you.
  7. Nov 16, 2022 at 1:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What brand did you replace with? If not OEM, I would strongly reccomend that you order it also. Our trucks don't like Aftermarket electric parts
    Mike59 and Foxhunter[QUOTED][OP] like this.
  8. Nov 16, 2022 at 2:31 PM
    Foxhunter
    Ashley
    02 Tundra 4x4
    Tundra 2 it was oem part from toyota. Shifty ill change that part now and hopefully that needle will read something besides the half way mark
    Tundra2 and shifty` like this.
