Tensioner Pulley Replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by belairbrian, Jul 31, 2023.
  1. Jul 31, 2023 at 3:57 PM
    belairbrian
    belairbrian [OP] New Member
    2016 Crew Max 4x4 TSS
    Will be hitting 100K miles soon. So while I'm doing the oil change, I'm planning on doing the serpentine belt. Looking at some videos, it seems like every time someone has a bad tensioner pulley, they replace the entire tensioner vs just the pulley. Is there a reason for this?
    Normally I would just swap the pulley.
  2. Jul 31, 2023 at 5:34 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    I’m so old school, I don't even replace the pulleys , I replace the bearings in the pulleys. Only if the pulley is damaged or exceedingly rusted, will I replace the pulley.
    2mchfun likes this.
  3. Jul 31, 2023 at 11:58 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Because thats how it comes as a part.
    HulkSmurf14 likes this.
  4. Aug 1, 2023 at 10:45 AM
    belairbrian
  5. Aug 1, 2023 at 11:59 AM
    2mchfun
    The tensioner has a spring that sees many heating and cooling cycles plus is always flexing when the truck is running. Can you just replace the pulley? Yes
    Should you? Kinda depends on how long you intend to keep the truck and how old the current assembly is. Not really a one size fits all!
    WFD473 likes this.
  6. Aug 2, 2023 at 7:48 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    It’s enough of a PITA to replace, that I did the entire unit. Didn’t want to have to do it again.
    WFD473, AZBoatHauler and HulkSmurf14 like this.
  7. Aug 2, 2023 at 10:57 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Much easier to just replace the pulley. I just did this. Replaced the tensioner pulley, idler pulley and belt. Dont have to mess around with the stupid hex key on the tensioner assembly...
