Teq customs headlights
Discussion in '1st Gen Tundras (2000-2006)' started by Fieldnstreamer, Oct 16, 2024.
  1. Oct 16, 2024 at 10:23 AM
    Fieldnstreamer
    Fieldnstreamer [OP] Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    Has anyone bought these headlights and had the same issue as me? If so what did you do? So I bought these headlights from Teq customs but it wasn't till after I had purchased them and made some custom adjustments that I realized and I even emailed their customer service and they confirmed the problem that 2005-2006 double cab Tundras don't have any dark corner lights that are sold individually on their own to match the dark headlights I got from them. They only offer clear headlights but that would look goofy having clear Corner lights with dark headlights I feel like. If I have to I will buy the entire headlight assembly from Amazon or somewhere and then just resell just the headlights because I can only find headlight and corner light combos.Screenshot_20241016_132127_Google.jpg
  2. Oct 16, 2024 at 12:10 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Yea I don't think they sell smoked or blacked out corners separately.
    Fieldnstreamer[OP] likes this.
  3. Oct 16, 2024 at 12:16 PM
    Bake the corners open and finish the background in a matching black.
    JakeJake and Fieldnstreamer[OP] like this.
  4. Oct 16, 2024 at 12:40 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I bought spray lens tint for the corners. Not awesome, but not terrible.
  5. Oct 16, 2024 at 3:16 PM
    Fieldnstreamer
    Sam
    East Tn
    I emailed them and asked if there was a reason they didn't make them and they said that for some reason those do not play nicely when they are trying to do their custom work to it. I'm not sure what would be different between 05 and '06 versus 04 because they have them for 04s.
    Weagle likes this.
  6. Oct 17, 2024 at 1:57 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    is that yours in the picture? What options did you choose? There are quite a few options
    the corner lights in the picture look like they are dark
  7. Oct 17, 2024 at 2:52 PM
    Fieldnstreamer
    Sam
    East Tn
    That should be super close to what I ordered. That was a picture I found online but with the options I chose the best I can tell that's what mine will look like. Some of the options on their website weren't super obvious what it would look like as a final product and I also went with a BiLed instead of the Morimoto because it was a fairly large upcharge and I really couldn't see the added benefit since they said they had never see one of the leds burn out. It wasn't until after I had already bought them that I realized that they didn't offer a blacked out corner light. I made by one of the complete sets off Amazon or something and just sell the headlights since the only other place I can find Corner lights that are blacked out or in a headlight combo.
    G_unit3000 likes this.
