The 4 and 5 inch lifts use lift blocks for the rear
Discussion in '1st Gen Tundras (2000-2006)' started by T-bone Tundra, Feb 27, 2022.
  1. Feb 27, 2022 at 1:32 PM
    T-bone Tundra
    T-bone Tundra [OP] New Member
    04 sr5 access cab tundra
    Hello, I’m looking at lifting my 04 tundra sr5 access cab. I don’t really do any off-roading just logging trails and a some different atv trails so I’m not planning on dumping a bunch of money into it. I just want to be able to fit bigger tires and have more clearance. I’m looking at the tuff country lifts (4 or 5”). The only thing I’m worried about is both the 4 and 5 inch lift uses lift blocks for the rear and I’m worried about axle warp. I don’t know if I can get away with it or not. Any advice?
    Thanks…
  2. Feb 27, 2022 at 3:00 PM
    Nope. Nothing that hasn't been posted a dozen or more times already.
    But good luck and welcome to the forum.
  3. Feb 27, 2022 at 3:04 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    If you don’t want to use the blocks you can add more leafs to the leaf pack. I think you can find you can find longer shackles too if you really want to jack it up. I was getting axle wrap when I tried some 2.5 or 3 inch blocks. I ended up using a 1.5 inch block and added a leaf that lifted about 1.5ish inches. No more wrap. I have about 3+ inch lift in the rear. You can add more leafs for more lift.
  4. Feb 28, 2022 at 11:07 AM
    T-bone Tundra
    Okay, thanks.
  5. Feb 28, 2022 at 11:56 AM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    When I bought my tuffcountry lift (8 years ago?) the 5" came with the new beefier spindles. The 4" did not. That was my deciding point.
    I have had zero issues with it with. But I have no friends with the same off road truck & different list to compare too.
    Darkness likes this.
  6. Feb 28, 2022 at 12:40 PM
    T-bone Tundra
    Sweet, that’s what I was thinking too. Thanks for the help.
  7. Feb 28, 2022 at 1:13 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome to the tundra forum
  8. Feb 28, 2022 at 2:40 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If doing a bracket lift like that, definitely pay extra for the taller spindles. They make a kit with scary adapters for the upper ball joints, I wouldn't put that on any truck. The taller spindles are good though.
    For the rear, shackles won't work on these trucks. You're going to need leaf packs if you don't want axle wrap, or use blocks and look into a traction bar. That may be cheaper, and adding leafs may not get you as high as you need to be.
  9. Feb 28, 2022 at 2:55 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Are you open to a smaller lift? Something like 2-2.5 inches is really easy to do and based on your usage, 4-5 may be kind of overkill
  10. Feb 28, 2022 at 3:11 PM
    T-bone Tundra
    Yeah I’m going with the 5” even tho it cost more it’s a more complete kit. I couldn’t find a traction bar that fit my truck so I think I’m going to buy mounting hardware for one and fab something up myself.
  11. Feb 28, 2022 at 3:19 PM
    T-bone Tundra
    Yeah I’m might go with something smaller just so I can so I can save money. But I like the looks of the higher lifted truck. I still can’t decide. Either way I want to run 33’s so I can still have good articulation in the rear.
  12. Feb 28, 2022 at 3:50 PM
    rock climber
    If that's what you want go for it! 285's look so good on these trucks.
  13. Feb 28, 2022 at 3:58 PM
    T-bone Tundra
  14. Mar 1, 2022 at 12:27 PM
    T-bone Tundra
    Is the old man emu suspension lift any good?
  15. Mar 1, 2022 at 1:14 PM
    rock climber
    I think it's the best bang for the buck! I loved it on my old truck, never tried bilstein but have only heard great things about their 5100 shocks.
  16. Mar 1, 2022 at 1:21 PM
    T-bone Tundra
    Yeah I’m debating bilstein or the emu. Thanks for the help!
  17. Mar 1, 2022 at 5:52 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    OME is good but they are more geared more towards expeditions and touring. They'll give you 2-2.5" of lift at max. They are great at handling heavy load and are durable shocks but not the most comfortable. I don't think they're the best option for you if you're looking for a 4-5" lift.
  18. Mar 1, 2022 at 6:39 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How about a Combo Lift?
    3" body lift and 2" suspension lift.
    The huge advantage is the center of gravity is not being raised near as much, so cornering and highway speeds designed curves are cause less lean and of course far less stress on the suspension from the lift changing the dynamics of how all the parts work together to suspend in the first place. Luck deciding.
    KNABORES likes this.
  19. Mar 1, 2022 at 7:24 PM
    T-bone Tundra
    I’ve heard mix things about body lifts but I was thinking that I can still get up but I won’t mess up the angles of the front end components. What are peoples thoughts on the body lift?
  20. Mar 1, 2022 at 7:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My neighbor has 33s on a 6" lift and it looks like a big dog with little legs.
    Hi06silver, bmf4069 and sn_85 like this.
  21. Mar 1, 2022 at 7:54 PM
    tyler-brown
    Canada, B.C.
    You sound unsure of what you want, and your needs. I hope that doesn't sound harsh. But asking people on the internet will warrant all types of answers. You'll have the "purists" let's call them, that will say only Toyota shocks, leave it stock, nothing will ride better. The money bags, who'll spend the most amount of money on a lift kit, the fuck it this'll work group, and the fabricators who are able to build completely amazing rigs. There's too many variables.
    I think most(?) Of us can agree if you have the money, the 6" RCD is a nice lift kit, if you wanna go high in a kit form.
    The 5" tuff country, which I opted for, because money is always depending, I was comfortable with because it gave me a good platform to upgrade and fix things along the way.
    And the Bilsteins seems like the most popular option for a 2-2.5" lift.
    Or if you want to go high and still be the most useful offroad. SAS it.
    I think a budget needs to be formed, and also plans on what you want to do with the truck. If it's a daily driver, IMHO lifts sucks. I've had them on all sorts of gas and diesel trucks, all different kinds. They get tiring. They're cool to look at, but impractical. Climbing into, loading and unloading things out of your truck, if...well..y'know, you use your truck as a truck. Once again. This is just my opinion. I've been fortunate enough to now afford another truck, that's staying stock for a daily, (except for go fast parts, obviously) and the Toyota as a mostly offroad truck. Which I used to daily, and it was fine. For an underpowered, thirsty, lifted truck. But I digress.
    1) needs and wants of your truck
    2) budget
    That should give you a better path
    (I've also never had axel wrap in this truck, I don't think they make enough torque, lol. Maybe if I changed gearing?)
    Hi06silver and bmf4069 like this.
  22. Mar 1, 2022 at 8:25 PM
    T-bone Tundra
    Yeah I know I sound indecisive (and I am lol) but Im just trying to weigh my decision. It kinda also depends on the construction season this summer if I get the money I will go for something nicer. Im young and I know for the most part any lift above 2.5” is usually impractical but you only live once right.
  23. Mar 1, 2022 at 8:27 PM
    tyler-brown
    Canada, B.C.
    Only impractical depending on YOUR needs.
  24. Mar 1, 2022 at 8:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I think fox makes a 2-3" coilover and archive garage can set your rear, email Eric. Nothing you plan on doing needs more than that and you will save money. You can put some nice size tires in there.
    rock climber likes this.
  25. Mar 1, 2022 at 9:47 PM
    T-bone Tundra
    Ok I will, thanks.
  26. Mar 1, 2022 at 10:37 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I say go for a solid axle front end and convert the rear to independent.
    des2mtn and bmf4069 like this.
  27. Mar 1, 2022 at 10:38 PM
    alb1k
    Left Coast
    It's good
    I should have started with solid front axle.
    Sirfive likes this.
  28. Mar 1, 2022 at 11:22 PM
    T-bone Tundra
    What the range for price that you could expect doing that?
  29. Mar 1, 2022 at 11:22 PM
    T-bone Tundra
    Or I guess I could do my own homework on that lol
    des2mtn likes this.
  30. Mar 2, 2022 at 3:12 PM
    rock climber
    Way too much and need to be able to fabricate. It would be cool, but not really realistic (fun to dream about)
    Here are the options in cost order (excluding bracket lifts because I know nothing about them)
    Bilstein on stock coils roughly 1.5 to 2 inch lift, pretty solid offroad and rides nice. Truck should sit level if not, rear add a leaf or 1 inch block (then need new rear shocks). $500-$800
    OME, same as above but a stiffer tune on the shock (I loved that it was stiffer and more controlled, ymmv) $700-$1,100
    Coilover shocks with reservoirs. Same as above but Fox, Icon or King shocks. Really cool, expensive and overkill unless you do a lot of offroading (nothing wrong with overkill if you have the money). $2,500 - $3,500
    Solo mid travel kit, super awesome, expensive. $5,000
    Solo long travel kit, really awesome, expensive. $7,000 (probably more) Make a killer offroader
    Solid axle swap, the grand daddy of cool, very expensive
