The dreaded Secondary Air Injection issue on my 1st Gen, tips?
Discussion in '1st Gen Tundras (2000-2006)' started by RidgeRunner, Jul 25, 2019.
  1. Jul 25, 2019 at 5:02 PM
    RidgeRunner
    RidgeRunner [OP] New Member
    2006 Tundra SR5
    Planning a truck build for after my house is built
    Hey guys! Ok so my truck is coding off and on about the secondary air injection issue. It's been doing it sporadically for about a year and a half. It has not gone into limp mode YET so I've held off on fixing it.
    I am going to do the job myself. The only thing I don't do is tires because I don't have a high speed balancer, haha. So, have any of you changed this out yourself? If so, what can you tell me about it and what do I have to look forward to?
    And, a picture of my truck because I haven't posted one here yet.
    2006 Tundra, SR5, 4.7L, Leer Camper Shell, BFGoodrich AT KO2 10-ply tires
    hammeron, Black Wolf, bmf4069 and 2 others like this.
  2. Jul 25, 2019 at 5:24 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Welcome. I can't help but we have some people here that can. I know most people do the bypass rather than repair but I like all my stuff to work so I would be tempted to fix it.
    Black Wolf and RidgeRunner[OP] like this.
  3. Jul 25, 2019 at 5:30 PM
    RidgeRunner
    2006 Tundra SR5
    Bypass you say??? LOL I prefer it all to work properly, but I am also trying to build a homestead, so if I can bypass it for now and buy some time that would be awesome. We are way behind schedule and I want to get this project done.
  4. Jul 25, 2019 at 5:33 PM
    Mnorris1206
    08 tundra
  5. Jul 25, 2019 at 5:35 PM
    RidgeRunner
    2006 Tundra SR5
    Awesome, thanks!
    Mnorris1206[QUOTED] likes this.
  6. Jul 25, 2019 at 6:03 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    My Hewitt is in transit so hopefully it arrives by Saturday. I'll post an update if I'm able to get it installed this weekend. Internet seems to like the Hewitt systems, lots of posters saying years of service with no issues. I think Hewitt discusses intermittent codes due to moisture/corrosion/gunk build up in the valves.
  7. Jul 25, 2019 at 7:03 PM
    simonmiles
    simonmiles New Member
    I installed the Hewitt bypass kit about 6 months ago. I was not getting any codes but the truck would make a vacuum-like noise for about 20 seconds on start-up which is a sign that the SAIP pump might be going bad. The install is pretty straight forward. I didn't even put on the block-off plates until about two months ago since I wasn't getting any CEL codes. I decided if I was going to do the bypass then I might as well do it right. It hasn't affected any of my smog inspections in Texas. Hope this helps.
  8. Jul 26, 2019 at 4:30 AM
    RidgeRunner
    2006 Tundra SR5
    I'm getting the same vacuum-like noise. Ordering mine today, haha.
  9. Jul 28, 2019 at 9:54 PM
    remington351
    2006 SR5 DoubleCab
    I just installed the Hewitt plug and play this weekend. Truck is running and no CEL. I can tell the pumps are no longer operating at start up as mine would make a groaning sound about a minute after startup. That sound is now gone.
    In order to install the block off plates I needed to remove the hood, the hood hold-up pistons were directly in the way of reaching the nuts on the flanges, at least for me. I also would recommend getting an box end wrench, 12 point 10mm offset stubby. There's not much room once you reach your hand wrenching near the flange. Some manner of small head ratchet with elbow extensions may help also. The nuts were not very tight, but they are soft 10mm and once you slip off a couple of times you'll begin to round them. Good luck.
  10. Jul 29, 2019 at 5:29 AM
    Professional Hand Model
    Hand Protectors
    I’ve also had success using the six point high impact sockets as it seems they have a sharp edge on them which catches the bolts real nicely. Good on ya for the repair success!
  11. Aug 1, 2019 at 7:59 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I installed the Hewitt bypass a few months ago and used a rachet type wrench, I didn't take the hood off but it is the way.
  12. Aug 1, 2019 at 8:10 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Had one on my 06 worked perfect
  13. Aug 1, 2019 at 9:32 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Interesting. I just attacked it from below and didn't need to remove the hood. Like you said, extensions and universal joints was all I needed.
    flyfisher likes this.
  14. Aug 2, 2019 at 12:05 AM
    akhero
    akhero New Member
    2005 Toyota Tundra
    I have the same issue on my 2005 and i will use the kit!
  15. Aug 2, 2019 at 3:22 AM
    saltyreefer
    saltyreefer New Member
    I feel pretty ignorant about this pump lol
    But I believe the code I have been getting off and on is because of it. I just looked up the pump and I am seeing it for 140-160$. Why is everyone bypassing it if it’s that inexpensive? Or am I looking at the wrong part?
    https://www.partsgeek.com/mmparts/air_pump/toyota/tundra.html
    Aerindel likes this.
  16. Aug 2, 2019 at 3:53 AM
    koditten
    Kirk
    Midland of the Mitten
    Teutonics and tvpierce like this.
  17. Aug 2, 2019 at 10:45 AM
    simonmiles
    From what I've read it's a pain to get to the pump. Even after the pump has been replaced I've read stories where the pump goes bad again. So rather than go through the aggravation it takes maybe an hour or so to do the bypass. Not many stories where the bypass didn't permanently take care of the issue from what I've seen.
  18. Aug 2, 2019 at 10:50 AM
    remington351
    2006 SR5 DoubleCab
  19. Aug 2, 2019 at 10:55 AM
    akhero
    akhero New Member
    2005 Toyota Tundra
    It's not a hard job just time consuming. You have to remove the intake manifold!
  20. Jan 4, 2020 at 7:12 PM
    truckee_mctruckface
    truckee_mctruckface New Member
    Charles
    Seattle
    2005 DC SR5 TRD off road Spectra Blue
    I bought the bypass a few months ago and finally had time for the install today. The block off plates on the drivers side went fine. I went through the wheel well to get access. Tight fit with the brake lines and steering column, but got the plate in. The passenger side was a disaster. Outer most nut sheared off. I didn’t attempt the inner one and didn’t install the plate. Hooked up the bypass into the starter relay and cleared the codes. It seems fine for now, but I am concerned about the lack of a blocker plate and missing nut on the passenger side manifold. Are the blocker plates critical to successfully keeping the codes from returning? Am I going to have an exhaust leak from the missing nut? I cannot see a way to drill out and repair what snapped without removing a lot from the engine bay. How screwed am I on this one?
    thanks for any help!
  21. Jan 5, 2020 at 5:37 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  22. Jan 5, 2020 at 6:03 AM
    Hand Protectors
    Good job on getting this far.
    Time for you to figure a way to make it happen. Switch to plan B. Complete the job per the instructions. My 2002 doesn’t have this air thingy bypass or else I’d try to help you. Never give up, as there is always a way.
  23. Oct 12, 2021 at 1:27 PM
    Bqe
    Bqe New Member
    2005 tundra
    Same happened to me. After shimming in the block off plate I used a piece of mechanics wire to wrap the two flanges together and twisting it tight. Its been holding tight for over two years
  24. Oct 12, 2021 at 3:46 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    A lot of people buy the bypass kit to run 00-04 aftermarket headers. The 00-04 headers don't have the air injection pipes and therefore are on average $300 cheaper vs 05-06 headers.
  25. Oct 12, 2021 at 5:47 PM
    Holy thread revival Batman!!! and way to bring up a sore topic, free Heather!!!!!
    2006Tundra, bmf4069 and koditten like this.
  26. Oct 12, 2021 at 8:16 PM
    koditten
    Kirk
    No worries.
    I still have the home made bypass file.
  27. Jul 15, 2022 at 6:57 AM
    budman007
    budman007 New Member
    Sorry to Re-revive an oldie, but got some questions. Recently bought 05 Seq with the 4.7 and it got just got the bypass kit installed(no patience for me) by a shop and I have noticed that when I have an incline it seems to mis or stall briefly/slightly. I have never noticed this before at any time. Could this be related? I have zero dash lights on. I know the kit has plates he said he had to install, he is a import repair shop, so thinking it was done correctly, but this engine now having this sputter/mis or whatever is a concern for me. Thoughts from the yoda pros?
  28. Jul 21, 2022 at 3:17 AM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    A well trained eye by a CA smog shop will catch this bypass kit every time and fail you......
    Fixing it right is a matter of pulling off intake manifold to get at the parts....most the time it is the little plastic vanes inside smog pump disintegrating and clogging the ASV #2 ....which are located behind the starter at the back of the engine....
    PITA but doable....ASV can be taken apart to unclog them....
    EvilMilkshake likes this.
  29. Jul 21, 2022 at 3:20 AM
    budman007
    Thank God I don't live in Californication!
    dbittle likes this.
  30. Jul 21, 2022 at 6:06 AM
    Here it comes…..
    des2mtn likes this.
