The hybrids are involved in the engine recall, imo
Discussion in '3rd Gen Tundras (2022+)' started by Mookie, Jun 14, 2024.
  1. Jun 14, 2024 at 12:13 PM
    Mookie
    Mookie [OP] New Member
    The hybrids are of course involved in the engine recall, in my opinion, because they have the exact same engines. However, since the hybrids can be driven after a catastrophic engine failure, my guess is that is why they are not included in the SAFETY recall. It’s also my guess that Toyota will leave the hybrids off the recall and handle them under warranty as necessary.
    With 98,000 recalled and call it 200 (idk) failures, that’s a 1 out of 490 chance of failure. Less than ideal, but I’m not going to worry about it.
    Yes, I bought a 2022 hybrid because my utter pos F-150 gave up the ghost and I needed a truck. Used Gen 2s were no bargain, so I got the Gen 3 and an extended warranty as a first model year cya. The truck has been flawless for the first 26,000 miles (knock on wood) and per my habit I’ll keep it another 200,000 with any luck.
    23MAXBlue, Jtundra81, Balzac and 3 others like this.
  2. Jun 14, 2024 at 12:49 PM
    raylo
    raylo not so new member
    Frederick, MD
    Well, no, they are not in the recall. At least not yet. Now, they may have the same underlying problem, but that is an entirely different matter.
    Hella Krusty, Terndrerrr and GODZILLA like this.
  3. Jun 14, 2024 at 1:01 PM
    smileytn1
    smileytn1 New Member
    Why don't you soothsayers wait till the end of July comes and get the true story from Toyota instead of your false speculations!
  4. Jun 14, 2024 at 1:09 PM
    kkkk2023
    kkkk2023 New Member
    2023 Sequoia Capstone
    With TRD PRO suspension and 265/70r18 Tires
    Owner of 23 Sequoia Hybrid which was manufactured in Dec 22, so I cut my oil filter yesterday. Trying to figure out if there are any metal shavings in the filter, but it looks pretty fine.
  5. Jun 14, 2024 at 1:12 PM
    mass-hole
    mass-hole New Member
    Was that your first filter change?
  6. Jun 14, 2024 at 1:16 PM
    Batpig
    Batpig New Member
    2023 Tundra Capstone
    There really isn’t much speculation to do. If you read the NHTSA report, they flat out say that if the failure occurs on a hybrid engine, the vehicle still has motive power for limited distances. That’s why they aren’t included in the recall.
    The speculation would be whether they eventually include them, which I believe they will. Either way, it doesn’t concern me much. The odds are I won’t ever have a problem, and if I do, that’s what my warranty is for.
    sandiegosteve, Balzac and mrfreeman like this.
  7. Jun 14, 2024 at 1:17 PM
    kkkk2023
    kkkk2023 New Member
    No, it was the 5th filter, OCI is 5K miles. For now 27k miles on it.
    Tundrastruck91 likes this.
  8. Jun 14, 2024 at 1:31 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  9. Jun 14, 2024 at 1:31 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I changed my oil at 1000 miles but from my understanding the block castings are different among the hybrids and nonhybrid models. I have a 10 year 150-thousand-mile warranty so I really don't want Toyota tearing a perfectly good engine and block down if not necessary.
  10. Jun 14, 2024 at 3:26 PM
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    my dog's name is Mookie!
    cartage1, raylo, Kap1 and 2 others like this.
  11. Jun 14, 2024 at 3:39 PM
    Retired...finally
    Looks like floor sweepings from the Huntsville plant there in the bottom of the filter can.
  12. Jun 14, 2024 at 3:41 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    You might want to double check that. Best extended warranty you can get is 10/125,000. No option for 10/150,000. Only thing covered that has 10/150,000 is the hybrid battery pack.
  13. Jun 14, 2024 at 4:08 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    You read that online…..
    Hella Krusty likes this.
  14. Jun 14, 2024 at 4:10 PM
    PATundra13
    PATundra13 New Member
    Pittsburgh, PA
    2024 Tundra 1794 I-Force Max, Smoked Mesquite
    RC running boards and RC hard tonneau cover, TRD air filters, Mace MFG knobs, Beat Sonic amp, TVD decals, front windows tinted.
    That filter should not have that much metal in it.
    Black Wolf and Retired...finally like this.
  15. Jun 14, 2024 at 4:25 PM
    Tb2
    Tb2 New Member
    James
    I to have. 22 hybrid 1798 22 k miles not issues trouble free oil analysis are all good . I would. Like toyota to give an extended warranty on engine as a precaution
    TRDoffroadPRO likes this.
  16. Jun 14, 2024 at 5:35 PM
    TRDoffroadPRO
    Assurant platinum coverage is 150 thousand miles or 10 years.
    Rockpig[QUOTED] likes this.
  17. Jun 14, 2024 at 6:44 PM
    nodak67
    nodak67 New Member
    JR
    he is talking about the oem vsa, not a 3rd party warranty service.
    Kap1 and Tundrastruck91 like this.
  18. Jun 15, 2024 at 7:26 AM
    Hella Krusty
    Hella Krusty New Member
    I ran my VIN, no they are not part of the recall
  19. Jun 15, 2024 at 7:48 AM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    If that is the same Assurant that did the extended warranty for my LG fridge, run run far away. I have horror stories.
  20. Jun 15, 2024 at 9:26 AM
    Hella Krusty
    You bought an extended warranty on a fridge?????
  21. Jun 15, 2024 at 10:17 AM
    kirkb
    DFW
    yup and if you haven't already, do a search on LG refrigerators and linear compressors ;)
  22. Jun 15, 2024 at 11:33 AM
    Hella Krusty
    My wife’s drunken friend called me Mookie
  23. Jun 15, 2024 at 11:49 AM
    TRDoffroadPRO
    Yep I had one, a series kenmore rebrand with that exact compressor. It went out and replaced it with a whirlpool. This assurant warranty was offered through the dealer and at any dealer network selling them they don't have a deductible. Some of the dealers say that Assurant claims process is better and easier than toyotas. From what the service managers have told me who deal with both. I imagine the dealers wouldnt sell them if they denied claims, and wouldn't process them. The contract specifically spells out what they cover and what they don't.They might be more expensive but they are bumper to bumper warranty coverage for 150 thousand miles on toyotas.
