The video every 3rd gen owner wanted.
Discussion in '3rd Gen Tundras (2022+)' started by mayan, Mar 29, 2025.
  1. Mar 29, 2025 at 10:40 AM
    mayan
    mayan [OP] One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
  2. Mar 29, 2025 at 12:28 PM
    lapoolboy
    lapoolboy New Member
    Doesn't give the warm fuzzies.
  3. Mar 29, 2025 at 1:31 PM
    Daedalus
    Daedalus New Member
    I’ve seen worse things.
    mayan[OP] and TheDo114 like this.
  4. Mar 29, 2025 at 2:11 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I enjoyed the video.
    But, why would someone donate this engine to this guy, and not give him the specifics on mileage and the "event" that took it down?
    I'm still not convinced the engine failures aren't related to the main bearing girdle design, versus having individual main caps. The lack of bearing locator tabs also is suspect to me. That seems like an invitation to have the bearings walk.
    ramnj, Sisu87TRDOR, Zudrick and 2 others like this.
  5. Mar 29, 2025 at 3:16 PM
    Breathing Borla
    Northern Illinois
    Are locator tabs going to stop a bearing from walking ? He seems to say no
    but not sure what there is to gain , besides some entertainment from a motor that was oil starved and went boom and they don’t know why or how many miles
    would have been cool to see one pre and post bearing issues
    and a new one to see what Toyota changed
    BlackNBlu, mayan[OP] and woods like this.
  6. Mar 29, 2025 at 3:20 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Very cool - Heading there now. Thanks
  7. Mar 29, 2025 at 3:35 PM
    Redward 25
    Redward 25 New Member
    2025 SS red Tundra SR
    none....yet!
    Interesting indeed.
  8. Mar 29, 2025 at 3:56 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Absolutely tabs help prevent bearing walk, or at least prevent bearings from moving while installing the crank. You saw how he fumbled with that in the video.
    On older engines that I'm familiar with, every main bearing and cap had a specific location. A typical build included checking the oil clearance on every main bearing. I know this new girdle design has been around for a while, but I'm not convinced it's a better design.
  9. Mar 29, 2025 at 4:17 PM
    Matt2015Tundra
    2023 1794 CrewMax
    My theory is the strange coating this guy found on the main bearings is just a disposable coating that compensates for different oiling tolerances across all the main bearings due to the girdle design's lack of precision.
    Probably cheaper to build in a fudge factor than get every bearing's clearance tolerances precise.
    I'm no mechanical engineer, but I've re-built a few, and I know how important main bearing tolerances are.
    mayan[OP] likes this.
  10. Mar 29, 2025 at 4:48 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Very interesting ... steel caps molded into aluminum girdle, oil flow, and the 2 different part numbers for the four crank bearings. Design flaw? I also think bearing locating tabs are a thing of the past from what I read.
    mayan[OP], woods and Breathing Borla like this.
  11. Mar 29, 2025 at 9:54 PM
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    All I know is, I’m not too worried. I changed the oil at 900 miles and plan to do it every 5k. I’ve also got the platinum 10 year / 125k mile warranty if anything ever arises. I do like that the car care nut owns an iForce max tundra and gives real world updates on his truck.
  12. Mar 30, 2025 at 2:01 AM
    wing-2
    wing-2 New Member
    I did the same, and have the same warranty. I have 26k miles with nos issues and no worries. They claim they will give me a new motor with turbos and all this summer. I will likely have over 30k miles by then....
  13. Mar 30, 2025 at 5:55 AM
    mayan
    Mayan
    DFW
    I believe when the core was originally up for sale it didn’t come with any history. This could’ve been solved by a vin search to see what happened and when but I guess that’s gonna be a mystery for all of us.
    Yeah not having locator tabs is concerning especially considering how much vibration and thermal expansion happens in those areas. And his video showed the deformed bearing and seized oil rings so I’m really curious about the owners maintenance and driving habits as well because things aren’t adding up but who knows at this point.
  14. Mar 30, 2025 at 7:22 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Great video!
    design flaw: 1000
    machining debris: 0
    Redesign incoming.
    DimSum07 and Ponderosa_Pine like this.
  15. Mar 30, 2025 at 7:27 AM
    Breathing Borla
    Northern Illinois
    And from that what is the design flaw?
    WindChillYeti75 likes this.
  16. Mar 30, 2025 at 7:30 AM
    WindChillYeti75
    Don’t feed into it. Just another insecure 2nd gen owner who’s here to tell us how superior his engine is.
  17. Mar 30, 2025 at 7:46 AM
    Matt2015Tundra
    2023 1794 CrewMax
    It's my understanding that Ryan got a brand new short block to tear apart and study, so I don't think this was his engine. I could be wrong.
    Yeah, this video would have been much more informative with the history of the engine and how it failed. What I can't figure out is what caused the outer diameter of the #1 main bearing to shrink and fit so loosely in the cradle? That doesn't seem consistent with "machining debris".
    AZBaldy likes this.
  18. Mar 30, 2025 at 7:51 AM
    WindChillYeti75
    I’m trying to find the part when he said in the video that this particular engine had an event that wasn’t part of the recall. I thought I heard in the video somewhere that something along the lines of it seeming like this event could have been prevented or there was a preventative maintenance mistake.
  19. Mar 30, 2025 at 8:04 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I don't think he ever offered any explanation of what caused this engine to fail. He repeatedly just called it the "event". The #1 piston was missing, so the event was probably related to that cylinder.
    One thing is clear, the event may not have been related to the main bearings, but that #1 bearing was on its last leg, and undoubtedly would have failed.
    mrlittlejohn likes this.
  20. Mar 30, 2025 at 8:06 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    Man, did you watch the whole tear down? The failed bearing? Evidence of differences in wear rate and load patterns front to back? If you’re suggesting any of that discoloration from heat (the bluing he talks about) and wear is “normal”, we’ve got a different set of expectations.
  21. Mar 30, 2025 at 8:08 AM
    Breathing Borla
    Northern Illinois
    if it was oil starved wouldn’t the heat generated during the event deform that? Seems like it would
    PNW Tundra Mike likes this.
  22. Mar 30, 2025 at 8:08 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    Can you point me in the direction of the kool aid stand please?
  23. Mar 30, 2025 at 8:09 AM
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    He sorta did, said it was a non-recall event resulting in it being oil starved causing issues to #1 piston. So some info, but not really what happened. Problem is an oil starved engine is going to have significant wear issues, so it’s hard to say what is regular wear and what was caused by the oil issue.
  24. Mar 30, 2025 at 8:10 AM
    Breathing Borla
    Northern Illinois
    nice try at the spin, your improving
    but , you said it was a design flaw, I asked what design flaw you saw
    and all that shit he saw was from a oil starved and failed motor, so you cant state the bearings were just worn normal and flawed , the event messed up all of that information
    VCheng and WindChillYeti75 like this.
  25. Mar 30, 2025 at 8:11 AM
    Zudrick
    Zudrick New Member
    None….so far
    Random guy on internet says it’s not debris, is a manufacturing issue, but cannot back it up besides pointing to an oil starved engine that wasnt related to the recall. You know being contrary to all existing info without any evidence. Can you point us to the troll cave?
  26. Mar 30, 2025 at 8:13 AM
    WindChillYeti75
    There’s ALWAYS one 2nd genner who feels the need to comment! Haha
    Raven67 and BlackNBlu like this.
  27. Mar 30, 2025 at 8:14 AM
    Breathing Borla
    Northern Illinois
    lol, ouch
  28. Mar 30, 2025 at 8:15 AM
    Zudrick
    Zudrick New Member
    None….so far
    100%, It’s usually the guy who heard from a former roommates friend that lives in his mother’s basement that everyone else is wrong. He may never gotten out of high school but he knows more than the engineers who developed it.
  29. Mar 30, 2025 at 8:15 AM
    Breathing Borla
    Northern Illinois
    I don’t mind the comments and discussions at all, normal truck stuff
    plus we get to know what the design flaw is now that whypat says he saw it in the video
  30. Mar 30, 2025 at 8:15 AM
    Matt2015Tundra
    2023 1794 CrewMax
    The last engine I tore down and rebuilt was a 1981 AMC 360 with unknown mileage. The original main bearings, crank, cylinder walls, and valves all looked better than the engine in this video.
    Here's the before and after.
