Thoughts about Diode Dynamics Stealth LED Bumper Light Kit?
Discussion in '3rd Gen Tundras (2022+)' started by MrKABC, Nov 22, 2023.
  1. Nov 22, 2023 at 11:41 PM
    MrKABC
    MrKABC [OP] Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Pottsy and Kap1 like this.
  2. Nov 23, 2023 at 3:49 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    I don’t have a 3rd gen, and I don’t have the stealth bar for my 2nd gen, but I have all DD lights. I cannot recommend them enough. No the lights will not be weak. I had them on my Tacoma and now on my tundra and I couldn’t be happier with them.
  3. Nov 23, 2023 at 4:00 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Mounts suck,light wiggles when you hit a bump, light is great but my mounts broke less than a year after install.this is on the 30". 2.5 gen
    iiawah808 likes this.
  4. Nov 23, 2023 at 6:35 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Mounts are different on this kit. As they bolt into the crash bar.
    my bar has been good. I have a combo down there and a driving in my grille. They light up quite a bit.
  5. Nov 23, 2023 at 3:19 PM
    WITCHBANE
    WITCHBANE New Member
    Joseph
    2024 Tundra Platinum TRD Off Road
    I have all @Diode Dynamics lighting on my current Tundra and also on my previous TRD Pro Tacoma. I love their lighting and would recommend them hands down. As far as the stealth light bar though, I think the positioning is off to prevent a clear projection from the location it is mounted. I may be wrong, but it seems to be about a quarter inch to high, cutting off some lighting potential. Other then that, I like it a lot.
  6. Nov 23, 2023 at 7:44 PM
    Keeptipsup52
    Keeptipsup52 New Member
    22 SR5 TRD OR
    Do you have to remove the whole grill to install this one or can you install from underneath?
  7. Nov 23, 2023 at 11:17 PM
    WITCHBANE
    Joseph
    You'll have to remove your front end bumper portion to install the stealth lightbar.
    Keeptipsup52[QUOTED] likes this.
  8. Nov 24, 2023 at 1:23 PM
    MrKABC
    Art
    Corona, CA
    Thanks for the feedback fellas! Just picked it up from @memario1214 . (ORDER #5906!)
    Rock and roll!!! Happy Black Friday to all! :thumbsup:
    dherring256 likes this.
  9. Nov 25, 2023 at 1:21 AM
    Tundra009
    Tundra009 New Member
    Concord, CA
    Totally agree w/ the the bracket being slightly higher and not centered in the bumper whole. I had to modify it so I can adjust its positioning. Basically made the whole bigger so I can adjust it. I originally bought the amber but thought the output was not as bright as I wanted it. I spoke to DD and they said to replace it w/ their clear lens. Problem solved! Much brighter
    WITCHBANE[QUOTED] and Ipaddick like this.
  10. Nov 26, 2023 at 5:05 PM
    Keeptipsup52
    22 SR5 TRD OR
    I see. So just the lower section, much easier than taking the whole thing apart.
    WITCHBANE[QUOTED] likes this.
  11. Nov 28, 2023 at 11:24 AM
    WITCHBANE
    Joseph
    You'll have to remove the entire bumper portion to access the front crash bar. Once that's done, you'll see the oem black brackets connected to the crash bar with purple bolts. You'll only need to remove one purple bolt on the top section of the oem bracket, and one underneath the crash on the oem bracket. Install the @Diode Dynamics brackets (keeping the purple bolts slightly loose, attach the light bar, adjust light bar for beam projection, then tighten down the purple bolts and bolts into the light bar). Test connection, and then reassemble the front bumper onto the truck. Here are a couple links from @Diode Dynamics and Yota Expedition for ya.
    https://youtu.be/zm9nrNRiNxU?si=_7yX1qCJQ0FT_VSG
    https://youtu.be/cz0S-cY7Bhk?si=ESb2regAvzbcp-Wc
  12. Nov 28, 2023 at 1:29 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    How easy or difficult to adjust beam height once installed? Can the adjustments be access with removal of the fob light bezel/trim?
  13. Nov 29, 2023 at 6:05 AM
    Ipaddick
    Ipaddick New Member
    Canada
    You can make adjustments. It’s a pita but you can do it. Easiest way I’ve found is take off the fog bezel and fit a ratchet in there. Then you can loosen and adjust.
  14. Nov 29, 2023 at 6:52 AM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Did you replace it with the clear lens on amber stealth? or did you do the just all Driving lens on the amber LB?
  15. Jan 30, 2024 at 11:38 AM
    Bailey1794
    Houston
    I think he swapped the amber stealth lens to clear. I'm in the process of doing that as well as its not bright enough.
  16. Jan 31, 2024 at 4:45 PM
    jctmundra
    Northern VT
    Here is a comparison, shows the OEM's are pretty good too.
    freaksavior, Ipaddick and Bailey1794 like this.
  17. Jul 6, 2024 at 9:31 AM
    WillJoe
    WillJoe New Member
    2024 tundra limited
    Hello all. Thinking of getting the DD stealth light bar but keep hearing about bracket issues one guy used a hammer to correctly align the light bar. this is from older posts. Anyone buy one in the last year and have issues with the brackets.
  18. Jul 6, 2024 at 12:42 PM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I have the bar on my current truck, I also installed and removed it from my 2023 1794.
    I had no issue with the brackets, just follow the instruction videos on YouTube and you can’t go wrong.
    WillJoe[QUOTED] and Ipaddick like this.
  19. Jul 6, 2024 at 4:40 PM
    PATundra13
    PATundra13 New Member
    Pittsburgh, PA
    2024 Tundra 1794 I-Force Max, Smoked Mesquite
    RC running boards and RC hard tonneau cover, TRD air filters, Mace MFG knobs, Beat Sonic amp, TVD decals, front windows tinted.
    has anyone wired one of these to a iforce max? I'm asking because the video shows how to wire with the battery under the hood. I am wondering if there were any challenges wiring with the battery under the rear seat?
  20. Jul 6, 2024 at 4:43 PM
    Ipaddick
    Ipaddick New Member
    Canada
    You can either use the positive post in the fuse box and the ground next to it (search up DD ditch light install) or run them to the battery in the back.
    PATundra13[QUOTED] likes this.
  21. Jul 6, 2024 at 7:13 PM
    WillJoe
    WillJoe New Member
    2024 tundra limited
    Thank you, 75tranzam
  22. Jul 7, 2024 at 6:16 AM
    jctmundra
    Northern VT
    The stealth bar works. I suggest since you will be removing the bumpers for install, pick up the DD fogs, do both at the same time.
  23. Jul 7, 2024 at 6:19 AM
    jctmundra
    Northern VT
    Been there done that. Not difficult, takes a bit of time.
    If you want the light bar to come on with highbeams, will need the canbus module.
    Mounted next to battery:
  24. Jul 7, 2024 at 7:04 AM
    Ipaddick
    Ipaddick New Member
    Canada
    What is this picture of?
    my grill and stealth bars are wired to a canbus module which is nice. Might get some morimoto big bangers and add them to a canbus as well. That would be mad light.
  25. Jul 7, 2024 at 9:06 AM
    WillJoe
    WillJoe New Member
    2024 tundra limited
    Thank you, jctmundra
    I did pick up the DD fogs in amber.
  26. Jul 7, 2024 at 9:09 AM
    jctmundra
    Northern VT
    Power and ground panels for the 12v accessories.
    30,000 ft view:
    RatPanda and PATundra13 like this.
  27. Jul 7, 2024 at 9:15 AM
    jctmundra
    Northern VT
    When I installed, the fogs were aligned ok. The stealth bar, thought I had level at install. After all together the beams were low. Adjusting through the grill opening can be done with much patience. My suggestion is to mount it up a degree or two as it will be easier to adjust down that up.
    WillJoe[QUOTED] likes this.
  28. Jul 7, 2024 at 9:18 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Those who removed the grill in front of the stealth bar can you show how.
    WillJoe likes this.
  29. Jul 7, 2024 at 9:19 AM
    Ipaddick
    Ipaddick New Member
    Canada
    All to one switch or to a switch panel?
  30. Jul 7, 2024 at 9:39 AM
    jctmundra
    Northern VT
