Thoughts on a High mileage Sequoia
Discussion in 'Sequoia 1st Gen (2001-2007)' started by QuicksandPNW, Mar 17, 2024.
  1. Mar 17, 2024 at 8:19 PM
    QuicksandPNW
    QuicksandPNW [OP] New Member
    Kevin
    Washington State
    2020 Quicksand Tundra SR5
    Bed Rail System Tonneau Cover
    Our commuter 2017 Ford Escape left my wife stranded for the 3rd time in the last year a few night back, so I’m looking to trade it in once it’s fixed. Luckily its still under extended warranty for 1 more week, so the fix should be covered.
    The dealer I’m calling tomorrow has a 2001 Sequoia SR5 that I’m going to take a look at with 245,000 miles. They’re asking for a little under $5,000. I’ll check it for rust on the frame and would get everything checked out by a reputable shop if interested in purchasing. I’m just looking for feedback on these and if there is anything I should be looking for?
    https://www.kendallfordmarysville.c...a-sr5-4wd-4d-sport-utility-5tdbt44a61s025798/
  2. Mar 17, 2024 at 8:52 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Timing belt water pump hx and if seals were done with them. Run the vin for frequency of oil changes. Manifolds. Ball joints. But it’s idling and the CEL, VSC and VSC trac lights are all lit. I would want the codes before I made the trip
    QuicksandPNW[OP] and dbittle like this.
  3. Mar 18, 2024 at 9:34 AM
    QuicksandPNW
    Kevin
    Washington State
    Thanks! I’ll check those and see about the codes.
