Thoughts on Meguiar's Ultimate Liquid Wax?
Discussion in 'Detailing' started by TILLY, Nov 7, 2019.
  1. Nov 7, 2019 at 11:11 AM
    TILLY
    TILLY [OP] Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Need to get some wax on the truck while we still have some good weather, anyone here try this stuff, any good? :notsure:
  2. Nov 7, 2019 at 11:15 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    yep, have used it quite a bit. works good enough.
  3. Nov 7, 2019 at 11:21 AM
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    I've used the black liquid wax and it's not bad, pretention longevity is the issue. Doesn't last near as long as other sealants out there
  4. Nov 7, 2019 at 11:43 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Meguiar's makes good stuff. I am sure its good as well. Key is to apply a few times a year, stay away from (brush type) car washes, and use a good car wash soap when washing.
    Currently use Tech 2.0 with great results.
  5. Nov 7, 2019 at 12:41 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I use it with Ultimate Fast Finish and it lasts pretty well. A while back I used Purple Power Vehicle and Boat Wash to strip off the ULW and UFF and found, to my amazement, that it still beaded really well. I also follow each wash with Ultimate Quik Wax/Synthetic X-Press Wax.
    War Machine likes this.
  6. Nov 7, 2019 at 5:22 PM
    TILLY
    Massachusetts
    OK, thanks for the input, i appreciate it. Whatever crap they sprayed on at the dealership has completely washed off, so I'll give this a go and see how it works out. ;)
  7. Nov 8, 2019 at 6:12 AM
    briarpatch
    briarpatch New Member
    Megs Ultimate Liquid Wax is not actually wax...it's a polymer based sealant. I've since moved on to other sealants, but when I used it, it had very good longevity and very good gloss. The only thing I didn't like about it was that the color of my truck looked muted and lacked depth, which can be typical of some sealants. Topping it with a carnuba based product, in my case Pinnacle Sovereign paste wax, improved that issue somewhat.
    Pudge and War Machine like this.
  8. Nov 8, 2019 at 7:37 AM
    War Machine
    War Machine SSEM # 5 3MW
    I read or heard somewhere that some companies market sealants as waxes. It’s because the average consumer doesn’t know what a sealant is, but everyone knows what wax is.
  9. Nov 8, 2019 at 8:12 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    I believe I’ve read the same directly from Meguiar’s about a few of their products. If I remember correctly it was the NXT 2.0 and maybe one of the ultimate line waxes. I use the NXT wax also, and Meg’s made it sound more like a hybrid of a wax and sealant.
    Trooper2 and War Machine[QUOTED] like this.
  10. Nov 8, 2019 at 8:14 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    This is my experience too, much easier and faster to apply than my typical mother’s carnuba wax, just doesn’t do quite as well of a job and doesn’t last as long.
    Trooper2 likes this.
  11. Nov 8, 2019 at 8:16 AM
    briarpatch
    That's exactly what someone from Meguiars told me
  12. Nov 8, 2019 at 8:39 AM
    War Machine
    It makes sense. I was doing a couple of trucks for some guys earlier this year while on a trip. There were about a dozen people hanging out while I was doing it, and I could not get it through their heads that I was applying sealants, not waxes. I gave up correcting them eventually.
    Since they’re actually giving you a product that’s better than advertised, nobody is going to call them out on it.
    2Tall[QUOTED] and Trooper2 like this.
  13. Sep 12, 2022 at 4:29 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    X2 on the turtle wax ice, it isn't your dads turtle wax. I also like that you can use it on plastic trim without it turning white.
