Ticking/diesel noise from driver side engine
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ninjaman23, May 5, 2022.
  1. May 5, 2022 at 6:22 PM
    Ninjaman23
    Ninjaman23 [OP] New Member
    Hello there,
    Pretty frustrated here lol, I have a 2016 5.7 Tundra with 140000KM on it.
    I hear a ticking noise at random times, sometimes at start up when idling and even sometimes it still happens as I drive. It doesn’t matter if it warm or cold outside. I find it happens more when I do multiple starts and stops where I turn my engine on and off, it doesn’t happen at the first stop or two but the other 2 or 3 starts it happens! It only may happen twice a week.
    I’ve had my experienced mechanic look at it multiple times now as I had an extended warranty. He said the noise seem to come from driver side where the tensioner is. So he tore it apart replace the chains, tensioners, Sprockets, seal, etc. week later happened again, poor guy took it apart again and rechecked everything again, it was fine.
    So I researched the issue and said he maybe the oil I use(Mobil 1-0W20) so I switched to OEM toyota oil, that didn’t work.
    I heard people talking about lifters being stuck but these truck don’t have lifters!
    I ran some seafoam through it too, didn’t work.
    I’m lost for answers and so is my mechanic, he said he was going to try to replacethe VVT solenoids one by one.
    I know this is a very popular issue and now just wondering if it’s a normal sound, but I have only heard it the last 20000-30000km.
    any other ideas?
  2. May 5, 2022 at 7:42 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
  3. May 5, 2022 at 7:45 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Is it possible for you to post a Vid of the noise? It may help people here with a diagnosis of a problem, or just normal clatter.
    HulkSmurf14 likes this.
  4. May 5, 2022 at 8:04 PM
    Ninjaman23
  5. May 5, 2022 at 8:17 PM
    eick
    eick New Member
    Ok that’s not the normal ticking imo
    oil pressure good? Check all pulleys? Check for exhaust leak? Spark plugs?
  6. May 5, 2022 at 8:18 PM
    Ninjaman23
    I would think my mechanic would have checked all those easy things. The sound is not as bad as it seems lol. The phone amplifies it! Especially sense he has taken everything apart twice lol
  7. May 5, 2022 at 8:29 PM
    Blueknights75
    Ron
    Clayton, NC
    Definitely not the normal ticking sound that these engines produce. How is compression on all the cylinders?
  8. May 5, 2022 at 8:39 PM
    Ninjaman23
    Not sure if he has checked any compressions but I will ask.
  9. May 5, 2022 at 8:44 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Not normal; sounds like an exhaust leak
  10. May 5, 2022 at 9:35 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    That's definitely a louder tick than I've heard but when the normal tick goes away when you switch to a heavier oil. I run 5w30 in the winter and 15w40 in the summer. Might be worth a shot just to see if it quiets down at all.
  11. May 6, 2022 at 3:25 AM
    PermaFrostTRD
    Northern NY
    the normal tick of these engines is audible in that video, but there’s also another louder thing going on that that became less noticeable as soon as you placed the phone down by the driver’s side of the engine block.
    As another member suggested, exhaust leak?
  12. May 6, 2022 at 4:48 AM
    Oklahoman
    Oklahoman New Member
    Moore
    2015 White Tundra 4x4
    Leveling Kit TOYOTA grill
    Mine sounded similar. Toyota replaced the 32 valve adjustment assemblies, thankfully under warranty.
  13. May 6, 2022 at 5:00 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    He replaced the timing chain tensioner? Because that’s exactly what it sounds like. If you run it with the oil filler neck removed you can probably see the chain flopping around in there with a flashlight. (A little oil is going to spray out while the engine is running with the filler neck removed).
  14. May 6, 2022 at 6:12 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Mine makes the same sound every now and then but it is few and far between. I'm leaning between oil pressure or one of the VVT solenoids. I haven't noticed any issues with the truck though. Let me know if yours goes away for good.
  15. May 6, 2022 at 6:36 AM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    Mine also makes this sounds. I'm curious what the OP finds out. Mine seems to go away above 1500ish RPM. Similarly, it doesn't do it all the time and doesn't appear to matter whether it is hot or cold.
  16. Sep 1, 2022 at 7:59 PM
    ifithaswheels
    ifithaswheels New Member
    Karl
    White TRD Supercharged
    Arb bar, arb air lockers, lift kit, wheels
    10tundrast5. Did you work out if it was the vet solinoid ? Or timing chain tensioner?
  17. Sep 1, 2022 at 8:04 PM
    Ninjaman23
    Switch out all the Solenoids 1 by 1 wasn’t it. All pullys, chains, guides replace wasn’t it. Ran seafoam and then another product in the oil nope not it. And still dealing with the noise lol. There is zero wrong with the drivability, no error codes or anything like that, drives fine except for that noise!
    k0diak8o8 likes this.
  18. Sep 1, 2022 at 8:17 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Ninjaman23 did you ever try changing to a heavier weight oil? Mine had a similar noise, 5.7L w/78k miles, but after switching from Mobile 1 0W20 to 5W30, I haven't heard it since. I actually forgot about it until I came across this thread.
    jgullace likes this.
  19. Sep 1, 2022 at 9:00 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Hate to say it but it sounds like bad rod bearings
  20. Sep 1, 2022 at 9:29 PM
    Ninjaman23
    16CMTXED this is what I was going to try next but I’m a little hesitant as I live in Alberta, Canada where it gets to -50C in the winter some days lol even though I have a block heater!
    2020DC how would diagnose bad rod bearings? And would the truck be throwing codes and would the drivability be off?
    16CMTXED likes this.
  21. Sep 2, 2022 at 1:46 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    bad rod bearing would show lower oil pressure at higher rpm if clearances are large enough.
  22. Sep 2, 2022 at 1:47 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    oh and it would keep getting worse, it not go to level off for years. It will get worse till fails
  23. Sep 2, 2022 at 9:52 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    The truck will not throw a code because it is a mechanical failure and will get worse over time. I had a 1987 chevy truck with the same problem with the exact same noise as you. I toke the engine apart and found the connecting rod bearings spun. Go google bad rod bearing noise. And also the noise will be more apparent from the oil pan. Put a stick from your ear to oil pan.
  24. Sep 3, 2022 at 5:58 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Wouldn't a spun bearing knock all the time, not come and go?
    I had an ac compressor that sounded like this a while back. On a tacoma
    Mdjamesd likes this.
  25. Sep 3, 2022 at 8:10 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Sounds like the timing chain tensioner. After you do an oil change does it go away at all?
    mines been clacking like that for the last 50k miles, but it goes away after I change oil. She clacks when she wants new oil :D
  26. Sep 4, 2022 at 1:56 AM
    Ninjaman23
    Truckytruck, I had everything replaced as I thought and my mechanic thought the same. Replaced all the chains, guides, sprockets, etc. didn’t fix the problem!
    Endagon, I would think a rod noise would be all the time also. But this noise I hear happens at random times. I can go a few days and nothing for noise. I do notice it more when I make frequent short stops, for example if I drive to 3 convenience stores fescue for 5 mins and get back in and start it I hear more during these times.
    2020DC I’m hoping this the issue lol. I maintain the truck very well, all reg oil changes etc and it only has 150,000KM on it.
    and just so everyone knows the video I posted sounds way worse than it do in person but the phone volume intensifies it lol. It sounds to me like a Diesel truck almost!
  27. Sep 4, 2022 at 7:10 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Have you put in 5w30 oil?
  28. Sep 4, 2022 at 12:05 PM
    Ninjaman23
    I have tried the 5W30 yet, this is what I was going to try next but I’m a little hesitant as I live in Alberta, Canada where it gets to -50C in the winter some days lol even though I have a block heater!
  29. Sep 4, 2022 at 12:13 PM
    ZPhilip
    Philip
    West Chester, PA
    It’s a cheap thing to try just to see if the noise goes away. It can be an inexpensive diagnostic tool. You can go thinner for the winter months.
  30. Nov 28, 2022 at 10:12 PM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    Check for an exhaust leak.
    I have an issue (though it does not sound like this) and it is the exhaust. Exhaust leaks sound very different based on where it is leaking. Fairly easy to check for, worth a shot.
