Tie Down Anchors
Discussion in '3rd Gen Tundras (2022+)' started by bballbk, Jul 5, 2023.
  1. Jul 5, 2023 at 1:45 PM
    bballbk
    bballbk [OP] New Member
    Hi group! New proud tundra owner here!
    I have a 2022 Tundra hybrid model with a tri fold tonneau cover. I need to travel to the beach in the following month with strapping things ontop of the cover. I will have to much gear to/stuff to fit inside the bed with the cover down. Are there any hooks or tie down anchors you can install on the truck bed rails? Looking at the inside of the bed, this doesnt look easy. I need something like this:
    https://www.amazon.com/Tigeracing-R...&sr=8-11-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY
    I am worried that something like this will not be sufficient to hold a few hundred pounds and wind resistance:
    https://www.amazon.com/Jawmoy-Ancho...----1---4&vehicleName=2022+Toyota+Tundra&th=1
    Thoughts?
  2. Jul 5, 2023 at 1:50 PM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    I added these to the rails of my '19. I don't know rails are the same for 2019 vs 2022, but there's probably anchors that fit 2022's if they are different.
    Rings:
    https://www.amazon.com/dp/B07Q2H38F6?ref=ppx_yo2ov_dt_b_product_details
    Anchors:
    https://www.amazon.com/dp/B097MZZKB8?ref=ppx_yo2ov_dt_b_product_details
    The anchors come with stainless bolts - I added the flat and split washers from my stash. These anchors will slide over the stock rail bolts.
  3. Jul 5, 2023 at 1:57 PM
    bballbk
    I need them to be on the exterior of the bed cover, not interior. I dont think these would work. Ideally would have some sort of hooks in the circled areas.
  4. Jul 5, 2023 at 2:17 PM
    RobertD
    Robert
    DFW, Texas
    Not familiar with Tigeracing, but Bull Ring makes a similar product that folks on the forum have used. Not sure about weight limits or of you have stake pockets but that will be your best case scenario.
    Depending how often you need to load above the cover, you may want to look at a Diamond Back or a Retrax XR (retractable with rails on top). Both are definitely costly but I would trust those more for more frequent use.
  5. Jul 6, 2023 at 1:31 PM
    Swanie80
    Swanie80 New Member
    B
    2023 Tundra 1794 TRD OR
    3" Lift, 35" Tires, Fuel Rims
    Seems dangerous strapping to the top of the cover, interested to hear how it goes and if everything comes back
