timbren or sumo
Discussion in 'Suspension' started by 9am53, Dec 13, 2019.
  1. Dec 13, 2019 at 5:25 AM
    9am53
    9am53 [OP] New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I thought this would be a common question and searched, and there seems to be literally nothing on the topic.
    Having had older toyota trucks I am well aware that they are always undersprung in the rear, and my 2015 is no different. I have 400 pounds of sand in the back and it leveled my truck. with an atv or bike in the back it will look like I'm overloaded, and when I tow my boat trailer (8000 pounds) it may actually be dangerous. Ive used old fashioned add a leaf before, on the T100 I added a helwig spring healper, both of which helped the sag, but both of which had drawbacks I'd rather avoid. The sumo/timbren solution looks to be up my alley, but which one? they are similarly priced, and similarly easy to install, I guess my question is which one engages sooner? I dont want to be bumping onto it with very little load, I think if it could engage right about when the truck is level, so like 400 pounds would be perfect...does anybody have experience with either of these on a tundra?
  2. Dec 13, 2019 at 8:32 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I can’t tell you which one is better but, for what it’s worth, the timbrens are made to help provide a better ride as well as load control. It really wouldn’t be a bad thing if you are engaging it a lot even unloaded.
    Timbrens have good warranty and customer service. I have no experience with Sumo.
  3. Dec 13, 2019 at 8:37 AM
    9am53
    adam
    2015 Black RCLB 4x4
    Timbrens dont do anything when unloaded...thats one of the things thats nice about them. both sumo and timbrens are essentially a big bump stop, so unloaded its totally stock, but when you load up the bakc of the truck, eventually the truck sits down and the timbrens or sumos start taking up some weight. I just want to know from people with experience if I put a couple of lawn mowers or something in the bakc of the truck if its going ot be bouncing off the timbren/sumo, of if they require more of a squat to engage...to make a short story long I want to know how much squat till the truck sits down on them.
  4. Dec 13, 2019 at 9:11 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
  5. Dec 13, 2019 at 8:46 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I have the SumoSprings and so far so good. I would say they are softer and more forgiving than the Timbren. I tow a 5000k pound boat and the rear handling and control feels good while under a load. I also do not notice they are there when unloaded.
  6. Dec 14, 2019 at 11:01 AM
    9am53
    adam
    2015 Black RCLB 4x4
    How much weight can your truck have in the back before it sits down on the sumo? What colour sumo did you get?
  7. Dec 14, 2019 at 1:01 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    I would say they contact the frame with about 350-400 pounds. I got the blue SumoSprings.
    woods, Bad Cow and OR18TRD like this.
  8. Dec 14, 2019 at 1:19 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I have timbrens and you can’t tell they are on there until you put a load on it. I have a pondtoon weights 5200 and camper about 5000. They work great. The only time I notice them is when you hit a speed bump fast and you can feel it then. @Mnorris1206 has some also.
    woods and Mnorris1206 like this.
  9. Dec 14, 2019 at 1:40 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Can’t answer what weight they engage but Timbrens are solid hard bumpers. If you’re not hauling lots or have a high tongue wt such that you permanently ride on them, they don’t feel good lifting off smacking them again on a bounce.
    Sumos come in different ratings but the light duty ones act more like accordions. And since they compress, will be more forgiving if you smack them unloaded, like when going over a speed bump or hitting a pothole.
    I have Timbrens but I use spacers to account for my 1.5” shackles. So when I don’t tow our trailer, I take the spacers out and there’s plenty of room before the frame hits the Timbrens driving unloaded.
    Mine (with spacers on):
    I should add with Sumos and greater compression, there’s potential for more sag with heavy loads over Timbrens. Of course this is less sag than no support. If you get the higher rated Sumos that don’t compress as much, I think they will act like Timbrens in theory.
    r1-superstar and OR18TRD like this.
  10. Dec 14, 2019 at 5:44 PM
    9am53
    adam
    2015 Black RCLB 4x4
    Thanks. I think I may consider the mid level sumos. 350 pounds before engagement isn’t too bad, and I presume with my regular cab it may be a bit higher
  11. Dec 14, 2019 at 5:56 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I got Timbren based on 2 different experienced installers. One recommended SuperSprings or Timbrens, proving he wasn’t basing his recommendation on brand and was aware of both brands.
    I haven’t loaded them yet, but I have appreciated the bottom out resistance provided by Timbren on larger bumps.
    I honestly think you’ll be happy either way. steered away from airbags due to maintenance requirements.
  12. Dec 14, 2019 at 7:09 PM
    9am53
    adam
    2015 Black RCLB 4x4
    So with the timbrens going over big bumps it does make contact?
    I want one of these over air bags for the same reason I want a truck with a v8 with no start stop no cylinder deactivation no turbos...its a simple tool, that’s what I want. Thanks for all yours help guys
    Midnite72 likes this.
  13. Dec 14, 2019 at 7:31 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
  14. Dec 14, 2019 at 7:52 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yes it does make contact, it is basically an oversized bumpstop.
    Tundyfundy and WNY PAT like this.
  15. Dec 14, 2019 at 8:07 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I’ve had Timbrens on my work trucks in the past... they honestly feel best when they’re in use. As others have said, the truck will slap off of them when you’re driving unloaded. That said, I never had a single problem with them through a lot of abuse and a lot of road salt. At this point though, I just use the headlight adjustment on my 2019 (use it to tow and haul a lot) and don’t worry about the sag.
  16. Dec 14, 2019 at 8:09 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    If you hit a speed bump fast yes. Where the road meets the bridge no.
  17. Dec 14, 2019 at 8:19 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Depends how fast and how big (what she said)
    There’s not much space between the top of the Timbren and the frame. A member here switches out his Timbrens with shorter Superbumps when not towing. It’s the same boot so it doesn’t take long.
    Some members here have posted they don’t like the shudder of Timbrens at all and decide not to use them. I left my spacers in once between camping trips, I smacked sometimes but not often. It was mainly over big speed bumps in our suburbs and me trying to break my record at the street sign that measures your speed (jking).
    DM 2018 Tundra likes this.
  18. Dec 16, 2019 at 6:27 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    How well do the sumosprings work with add-a-leaf and shackle kits? Can you add spacers?
  19. Dec 17, 2019 at 7:02 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    SumoSprings made me a custom set to accommodate my 1.5 inch rear lift. If you call them they can customize to your needs.
    r1-superstar, Skey44 and DZ_ like this.
  20. Dec 17, 2019 at 7:12 AM
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    Why do you keep 400 pounds of Sand in the back?
    Tundyfundy likes this.
  21. Dec 17, 2019 at 7:20 AM
    9am53
    adam
    2015 Black RCLB 4x4
    becasue regular cab long box trucks have zero weight in the back. In wintertime they become unsafe and frustrating to drive without added weight. I have 4x4 but I can’t drive around in 4x4 all the time. My last truck went off the road and got destroyed because i hit black ice and the truck went into a spin.
    Hbjeff likes this.
  22. Dec 17, 2019 at 7:25 AM
    15whtrd
    15whtrd Mr. Blonde
    I’ve read that the Timbren can be unscrewed, leaving the cradle in place, a Superbump can be screwed in place. This will give you your articulation back when the extra load is absent.
    Hbjeff likes this.
  23. Dec 17, 2019 at 7:39 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Cats, the man has a lot of cats.....
  24. Dec 19, 2019 at 10:36 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Timbren will contact with 400 lbs. I just installed it, the whole thing is around 5-½ inches tall.
  25. Dec 19, 2019 at 10:46 AM
    9am53
    adam
    2015 Black RCLB 4x4
    Thanks.
  26. Dec 19, 2019 at 10:48 AM
    9am53
    adam
    2015 Black RCLB 4x4
    This sounds like a description of what it was like when I was dating fat chicks in highschool
  27. Dec 19, 2019 at 10:52 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    oh! and i got the
    TTORTUN4
  28. Dec 26, 2019 at 10:02 AM
    aussieaarons
    Installed my Sumosprings, they sit flush unloaded but after a 200kms drive I’m definitely saying they make the ride ALOT rougher
  29. Jan 1, 2020 at 11:35 AM
    aussieaarons
    Well they were returned within 24hrs, wife said it was Far to rough and I agreed, felt like their was virtually zero rear suspension. Might try the blue Sumosprings but we will see once spring hits and camping season starts again.
  30. Jan 1, 2020 at 11:37 AM
    9am53
    adam
    2015 Black RCLB 4x4
    I wonder why they sat flush on your truck? I can’t imagine your suspension already sagging that much
