Time to replace 285/55/20 KO2's on '18 TSS 4x4
Discussion in 'Wheels & Tires' started by Polished Rock, May 11, 2024.
  1. May 11, 2024 at 3:59 PM
    Polished Rock
    Polished Rock [OP] New Member
    Charlie
    Grand Junction, CO
    2018 SR5/TSS Off Road, 285/55/20" KO2s, +Roadmaster AS
    none yet
    Greetings Gents,
    This is a request for tire size info, not specific tire options.
    I've already scanned all the related threads addressing tire size and didn't find the exact info I need. I've got about 55K miles on my current KO2's and am needing to replace before full trailer towing season. I was hoping to upgrade to the new KO3's but BFG has released a schedule for size releases this year and the 285/55/20's are not on the list for 2024.
    My question is... on a stock 2018 TSS can I run 275/65/20 or 285/60/20's on these wheels without any (or any severe) rubbing? Discount Tire tells me that the 275/65's will be about 1 inch taller which should most surely rub on the front.
    JPritch likes this.
  2. May 12, 2024 at 1:49 PM
    chance03
    chance03 New Member
    Haha I’m doing the EXACTAM same shopping let me know if you find anything!
    JPritch likes this.
  3. May 12, 2024 at 2:15 PM
    redrum448
    redrum448 New Member
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
    • 20″ rims: 275/60 R20 – one inch taller but same width as factory
    1.5 – 2″ Leveling Kit (or less)
    When installing a leveling kit, you might be able to fit some wider tires than what we have listed. It may require some trimming though, but it is possible.
    Max tire sizes are:
    • 18″ rims: 275/70 R18 – One inch taller but same width as factory.
    • 18″ rims: 285/70 R18 – 4/10ths wider and 1.7 inches taller than factory. Trimming may be necessary.
    • 18″ rims: 295/65 R18 – 1 inch taller, 8/10ths wider than factory. Trimming is probably needed due to width.
    • 20″ rims: 285/60 R20 – 4/10ths wider and 1.5 inches taller than factory.
    3″ Lift Kit
    With a 3″ lift kit, the options continue to get better. However, the wider the tire, the greater the likelihood of trimming.
    Max tire sizes are:
    • 18″ rims: 285/75 R18 – 4/10ths wider and 2.8″ taller than factory.
    • 18″ rims: 305/70 R18 – 1.2 inches wider and 2.8″ taller than factory. There are Tundra owners running this size, but trimming is required. Replacing the stock wheels with after-market 18′s that have less backspacing is recommended.
    • 20″ rims: 285/65 R20 – 4/10ths wider, 1.6″ taller than factory.
    • 20″ rims: 305/60 R20 – 1.2 inches wider and 2.4″ taller than factory. There are Tundra owners running this size, but trimming is required (it’s a tight fit).
    JPritch likes this.
  4. May 12, 2024 at 2:51 PM
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    I'll definately report back what I end up doing.
  5. May 19, 2024 at 4:04 PM
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    OK. Here's the latest update. I spent some time at Discount Tire. I had them order a KO2 in 285/60/20 to try it on for size. It's a smidge taller than the 285/55's and I wanted to see how much if any it would rub on my front wheel well. It did rub slightly. But well within heat gun range. Might even be able to keep the front mud flaps.
    So, this tells me I can put the KO3's on in 285/60/20 with just a bit of plastic reshaping/moving. If I can hold out until October. When that size in the KO3 is "expected" to be released.
  6. Aug 22, 2024 at 6:05 AM
    reprobation
    reprobation New Member
    Dallas, TX
    Update to his update.. I just purchased a set of new BFGoodrich KO3's in 295/65/20.. which is basically a skinny true 35" tire. Fits perfectly fine with no rubbing if you trim the fender liner and push it forward about an inch, then use a heatgun to shape the liner a bit (I used a football to push it in a bit). Other than that, I just had to bend the factory skidplate up a bit with some channel locks. No body mount chop needed. I'm running a 6112 in the front set to the top setting, a .25" shim on both sides. 5160's in the rear with a +3 coachbuilder shackle. Stock UCA. Gives a nice OEM+ look with just a smidge of poke.
    20240821_182413.jpg 20240821_182334.jpg 20240821_181839.jpg 20240821_181641.jpg20240821_182230.jpg
