Timing belt/Water Pump Replacement
Discussion in 'Performance and Tuning' started by CyTundra2000, Feb 7, 2025.
  1. Feb 7, 2025 at 11:42 PM
    CyTundra2000
    CyTundra2000 [OP] New Member
    2000 Toyotabtundra
    HI new member here and hppe this hasntvalreqfy b3en psoted, Im trying to fix My cylinders misfiring and have been told if i replace my timinmg belt i need to replace the water pump to also get rid if sqeaking whem RPMS change or when it is idling to long but is it nessescary or should i just replace the timing belt Please and thanks in advance for any advice
  2. Feb 8, 2025 at 4:36 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome! To assist you further, we need more info on your truck and your symptoms.
    Here’s some broad info that will apply to all 1st gens: The water pump is cheap insurance. When you replace the timing belt, the water pump is right there. Change it out too. Takes an extra 2 seconds. More info HERE. <THIS THREAD HAS ABOUT ALL THE INFO YOU’LL NEED ON YOUR TRUCK!
    • TIMING BELT. This is huge. The 2UZ-FE specifically is a low-interference engine. If it snaps, above idle/low RPM, the engine may become a boat anchor. Toyota recommends changing @ 9yrs or 90k miles. Sure, you may eek out 100k, 120k, 10-15 years w/o change. Hell, we've seen some make it 200k on what could be the original. However, we've also seen members w/barely 100k snap the original belt. Do yourself a favor, take a 10mm ratchet to loosen & look behind a timing cover, inspect the belt. If you find cracks, don't drive, it may be your last ride on that engine. Don't trust belt change stickers under the hood on new-to-you trucks, take 5mins to verify the belt. Those stickers cost $1-2 online, anyone can slap one on as a selling point. Belt change videos for DIY'ers are here. Shops charge $1k-2k parts & labor to to replace w/new-OEM brand (Toyota/AISIN). Aim for mechanics specializing in Toyota, dealerships charge anywhere 20%-40% more than a private shop. Don't use non-OEM parts here, and change the water pump, pulleys, tensioner while in there.
    Also, read this on more TB info https://www.tundras.com/threads/timing-belt-master-thread-sticky.107240/
    ... come hang out with us on the 1st Gen forum. We're absolutely freaking nuts.
    FrenchToasty likes this.
