Tire pressure
Discussion in 'Wheels & Tires' started by Sumo91, Dec 26, 2021.
  1. Dec 26, 2021 at 12:50 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys, I got some Mickey Thompson Baja Boss A/T
    295/70r18 E rated tires
    I have my pressure at 36psi, and when performing the chalk test, I still have some chalk om the outer edge of my rear tires. 36psi seems about right seeing other people's pressures. My fronts are at 38 and pass the chalk test fine. Should I try 32-34? When I put my tire size into the load calculator, it showed 35psi for these tires.
  2. Dec 28, 2021 at 10:02 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I run slightly smalled 275/70 E load. 35 was too low for my truck. At 38ish front/rear was better, but still had slight uneven wear, less wear in center. For my truck and driving, 40-42 in front and 38-40 in rear has been the best, even wear pattern and felt best driving. Around 35 was cushier feeling, but more wallow in turns and again- wear pattern was not as it should be.
    You are in the ballpark, adjust up or down based on load and how you drive and check wear pattern every 500-1000 miles, you will be able to notice any changes in wear pattern.
    WILLINH likes this.
  3. Dec 28, 2021 at 10:27 AM
    Sumo91
    TN
    Yeah that's the size I previously has, and ran 40 all the way around and had great wear. Im just surprised these bigger tires need less pressure. I just figured it would be about the same pressure for these, as my last set, and this set, are load range E. 35 just feels low I guess
  4. Dec 28, 2021 at 10:29 AM
    I have 285/70/18 Ridge Grapplers and I run 44 psi on all 4.
  5. Dec 28, 2021 at 12:20 PM
    Sumo91
    TN
    When I ran them at 40 the outer treads weren't making contact eith the ground, I had a good 1in to 1.5in of chalk still on the outermost treads of the tires.
  6. Apr 20, 2022 at 7:22 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I just called Mickey Thompson, gave them stock size and stock cold PSI. Stock was 275/55/20 at 30PSI in front and 33PSI rear on my 2021 Platinum 4x4. I run 295/70/18 Baja Boss A/T now and tech told me to run 30PSI in the front and 35PSI in the rear. Definitely seems a little low? Tiresize.com says 35PSI for front and rear? Now more confused. Had Toytec Boss lift installed and ride is not great so trying to figure out ways to improve.
  7. Apr 20, 2022 at 7:30 AM
    I have basically the same size at 285/70 and I run mine at 44 psi.
    zasdds[QUOTED] likes this.
  8. Apr 20, 2022 at 7:35 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Falken Wildpeak AT3s 305/65-18 , 31 psi
    zasdds likes this.
  9. Apr 20, 2022 at 9:39 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
