Tire Pressure
Discussion in 'Wheels & Tires' started by Manny66, Sep 14, 2022.
  1. Sep 14, 2022 at 9:17 AM
    Manny66
    Manny66 [OP] New Member
    Manuel
    2021 white Tundra SR5
    What tire pressure are you guy’s running? I got 35” x 11.5” tires put on recently and can’t find a sure way to calculate what psi should be.
    TundyMcTunra likes this.
  2. Sep 14, 2022 at 9:21 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    What load rating are your tires? I run my 33x12.5 E-rated at around 32 psi
    Manny66[OP] likes this.
  3. Sep 14, 2022 at 9:38 AM
    Search...there is about a hundred threads on tire pressure...lol.
    snivilous and BravoDeltaRomeo like this.
  4. Sep 14, 2022 at 9:44 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    101 now.
  5. Sep 14, 2022 at 9:49 AM
    Tire pressure, mpg, and what is the largest tire that will fit threads should auto delete as soon as they are posted lol.
  6. Sep 14, 2022 at 10:41 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Here is a great tool to get you in the ballpark when changing from stock size or a tire with different load rating. Then air up or down a few lbs based on how your truck is loaded/driven. But it gets pressure really close. Input stock tire info and pressure, then new tire info, load rating, etc.
  7. Sep 14, 2022 at 10:53 AM
    Retired...finally
    Don't forget whats the best motor oil, how often should I change my best motor oil and any thread mentioning 5 wheel trailers.
  8. Sep 14, 2022 at 11:03 AM
    Lol...and the cold air intake......
  9. Sep 17, 2022 at 1:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I searched. lol
    I took my Sequoia to the dealer, they gave it back with 36lbs in all 4 tires, the sticker says 30 front, 33 rear.
    Who is right?
    TK1979 likes this.
  10. Sep 17, 2022 at 1:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    The plate is based on stock tires. If they aren't stock, the pressure will be different.
    TK1979 likes this.
  11. Sep 17, 2022 at 1:59 PM
    e30cabrio
    They are 2018 Tundra 20" Michelins currently
    TK1979 likes this.
  12. Sep 17, 2022 at 2:36 PM
    Retired...finally
    I'm currently running 40-43 instead of 30-33. Tires are wearing beautifully and MPG is up.
  13. Sep 17, 2022 at 2:49 PM
    e30cabrio
    Stock rims& tires?
  14. Sep 17, 2022 at 2:54 PM
    Terndrerrr
    Terndrerrr 928000 miles to go
    Music City
    6UR-FE
    Which oil brand, MPGs, and ATs will give me the best level and tire pressure?
    BravoDeltaRomeo likes this.
  15. Sep 17, 2022 at 2:57 PM
    Retired...finally
    Yup. Max load at 51PSI. Mine is used mostly for towing a 3 ton travel trailer.
  16. Sep 17, 2022 at 4:34 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra Cement DC
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    This calculator is good, it will get you very close. Then you find a flat area and do the caulk test to be dead on the right pressure. Most load c and d will be near stock pressures with stock loads.
  17. Sep 17, 2022 at 5:29 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    E Rated Wildpeaks. 305/65-18 @ 30psi
