Tire Recommendations
Discussion in '3rd Gen Tundras (2022+)' started by greentundraman, Jan 11, 2024.
  1. Jan 11, 2024 at 3:51 AM
    greentundraman
    greentundraman [OP] New Member
    2023 Tundra CM SR5 TRD ORP Blueprint
    Looking for recommendations and thoughts on replacing stock tires. I have a ‘23 SR5 CM TRD OR with the 20” TRD wheels and stock Falken Wildpeaks. My driving consists on mainly on road with some off-road that is sand/beach. I need to have good wet road traction and some snow performance as well. I do not plan on adding a lift, leveling, or spacers. I like the wheels and will likely go with 275/60 or 275/65 size. My question is about your experiences with various tires and specs of those tires and what may work or what to stay away from. Appreciate the input. Thank you.
    Scotkulp and Tundra 4 life like this.
  2. Jan 11, 2024 at 8:36 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Michelin defender is a great road tire and excellent in sand. Very smooth, great tread warranty, M/S rated but have tame looks if that matters to you.
  3. Jan 11, 2024 at 8:44 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Ran a set on one of my 4Runners. Absolutely agree with this. They also were decent in the snow.
  4. Jan 11, 2024 at 8:55 AM
    raylo
    raylo not so new member
    Frederick, MD
    I third the road oriented Michelins recommendation. I had a set of LTX M+S on my Tacoma. Great wet traction, good snow traction, went off roading in the deep sand of the NC Outer Banks beaches, lasted 70,000 miles. I may not try to duplicate those beach runs in the Tundra, however, with stock sized tires because they are not any wider than those on my Tacoma, that weighed a lot less.
  5. Jan 11, 2024 at 9:16 AM
    Tundra 4 life
    Tundra 4 life New Member
    23 tundra
    2023 metallic grey sr5 crewmax
    Thank you I would like an aggressive looking tire but don’t want a rough ride.
    As for size I have a 2023 and would definitely like a size wider and bigger.The stock tires look awfully small.
    greentundraman[OP] likes this.
  6. Jan 11, 2024 at 9:18 AM
    raylo
    Frederick, MD
    Unless you are doing serious off roading "aggressive looking" tires are a total waste. Worse ride and MPG, for what??
  7. Jan 11, 2024 at 9:29 AM
    Tundra 4 life
    23 tundra
    Raylo thank you I don’t do any off reading and not sure I would.Just want something that looks good and a smooth ride.
  8. Jan 11, 2024 at 9:59 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  9. Jan 11, 2024 at 10:03 AM
    Tundra 4 life
    23 tundra
    Thank you Nick.second don’t know what size to put on her I just know those stock tire look awful small.
  10. Jan 11, 2024 at 10:04 AM
    Tundra 4 life
    23 tundra
    Plus I have 20 inch trd rims on her.
  11. Jan 11, 2024 at 10:29 AM
    Breathing Borla
    Northern Illinois
    Cooper AT3 4s is what I have and recommend
  12. Jan 11, 2024 at 10:48 AM
    iforceAZ
    iforceAZ New Member
    Michelin Defender Platinum
  13. Jan 11, 2024 at 10:55 AM
    Tundra 4 life
    23 tundra
    I have used Michelin exclusively in my past on my Mazda speed 3.
  14. Jan 11, 2024 at 11:35 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
  15. Jan 11, 2024 at 12:05 PM
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    ReadyLift 2” Mickey Thompson 275/65/r20
    May not like the aggressive "off-road" look but I am really loving my Mickey Thompson Baja Legend EXP in 275/65 on my 20" 1794 rims. They are very smooth and little to zero road noise. Way better ride than the factory junk.
  16. Jan 11, 2024 at 6:16 PM
    greentundraman
    Most of my off-road is OBX and have had my 2.5 gen Tundra out there with all terrains but aired down to 18 psi and floated on top. The Defenders look interesting. I will check them out. Thanks for the reply.
  17. Jan 11, 2024 at 11:03 PM
    dmash
    dmash New Member
    I just picked up the new Falken Wildpeak A/T4W for my ‘24 Platinum with stock suspension. Went with 275/60r20 as it seemed the best size for my situation. I’m exactly like you, just wanted to feel out the wheel well and look a bit more aggressive (while sticking with SL and not going to E). Wildpeak A/T3W got great reviews and the brand new A/T4W should be even better (with a longer warranty to boot). Plus at the deal of $280/tire, it was cheaper than other options!
  18. Jan 12, 2024 at 1:22 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Have you used them in the snow yet?
    The reason I ask, is because I am really interested in this tire but the winter performance seems to get mixed reviews.
    I am not looking for winter tire performance here. Just a decent showing like the Michelin Defender…but OP I will say for a highway tire the Defender is downright amazing at winter conditions. Not that it can compete with a winter tire, it can NOT, but it performs beyond great for a highway tire in the snow/ice.
    Edit: And in all honesty OP disregard what the tire looks like…
    Again using the Defender as an example. It will handily outperform the vast majority of the “more” aggressive looking tires on the market in the conditions you describe up till blizzard conditions (yet they still have always gotten me home).
    I appreciate performance over look’s especially with my little kids in the truck.
  19. Jan 12, 2024 at 8:54 AM
    NickBrewer
    I live in Alaska, but I only drove them in snow for a day or so, then I switched over to my winter tires (Bridgestone Blizzaks). They dealt with the snow about as well as any All Season tire that I have used before, which is to say that they will get you around, but you aren't going to have great control like a dedicated winter tire will give you.
  20. Jan 12, 2024 at 11:01 AM
    Scotkulp
    Scotkulp New Member
    Scot
    2024 Lunar Rock Plat
    Virgin
    I would look at Toyo AT3's 285/65/20's. Great tire...low road noise. LT rated. If you go to E rated tire, it will change the ride, they are heavy tires. LT's are the sweet spot if you don't "offroad" much and mostly highway.
    Hank Hill and Tundra 4 life like this.
  21. Jan 12, 2024 at 5:07 PM
    Tundra 4 life
    23 tundra
    Soctkulp will a 285 fit on there completely stock?
  22. Jan 12, 2024 at 5:29 PM
    DanSanDiego
    DanSanDiego New Member
    2019 Tundra Limited 4x4
    I recently purchased the Yokohama Geolander G015. Have been very happy with the purchase. Check them out at the Yokohama site.
    https://www.yokohamatire.com/tires/geolandar-a-t-g015
    They ride smoother than by previous BF Goodrich tires on highway, have a 3 peak rating, and can handle ok off-road. There is a really awesome review of all the top all terrain tires on YouTube that really helped me decide which tire most suited my needs. Have a look it may help you out as well.
    https://youtu.be/2hwYCc6YvYM?si=hZt2tGzjjyYJyh_R
  23. Jan 12, 2024 at 9:20 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I put Geo's M/T G003 285/55R22.
  24. Jan 12, 2024 at 9:52 PM
    Tom976
    Tom976 New Member
    Tom
    I got these tires (maybe a size larger...) I'll check the size tomorrow.
    Handles great, looks a bit more agressive and so far I like them. They dont weigh in too much more than stock so MPG wont be destroyed.
    Haavent gotten any snow yet so I cant comment on that.
    Tundra 4 life likes this.
  25. Jan 12, 2024 at 10:44 PM
    Morning_Rock
    Morning_Rock New Member
    Toyo OC ATIII load range C. Been great so far!
  26. Jan 13, 2024 at 2:48 AM
    Tundra 4 life
    23 tundra
    I was figuring the more aggressive tread pattern the better in rain,snow and ice.
    Blufin likes this.
  27. Jan 13, 2024 at 3:15 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The best 'wet' traction tire I've ran is Michelin LTX AT2s... I'm on the OR coast and spend most of my time driving on the 101, and these tires have yet to fail me in wet weather, and while I drive appropriate for the conditions I prefer to have good confident traction in my normal environment; these tires have always served me well. In snow and ice, they are probably a step down from something a bit more aggressive such as the Wildpeaks or Mickey Thompson AT. If you're going to spend any reasonable time in snow/ice, I'd suggest running dedicated winter tires such as the Blizzaks. For normal highway driving they are smooth, not noisy, easy to balance, and not a heavy tire which I believe you should factor.
    If you want to see them perform in a variety of conditions check out this video of a stock Tundra Pro (2.5 gen), w/stock suspension, and OE Michelin LTX AT2s. They run the truck in the sand, off-road, do a bit of rock crawling (fairly impressive w/a stock rig), highway, mud, water, etc...
    https://www.dailymotion.com/video/x3u3j0l
    At the 12 minute mark they take the truck to Hell's Revenge and do some pretty impressive crawling w/the OE Michelins, but the whole video gives you a good idea on the performance capabilities of the tire in a variety of conditions.
    Honestly, these tires will outperform most drivers' aspirations and abilities :thumbsup:
  28. Jan 13, 2024 at 6:48 AM
    Breathing Borla
    Northern Illinois
    not really, most AT and MT suck in those conditions
  29. Jan 13, 2024 at 6:52 AM
    Scotkulp
    Scotkulp New Member
    Scot
    Virgin
    You are pretty safe with stock rims and tires up to 295 width, <35" dia. For 20" rims, this would be 295/60r20 which are 33.9" nominally. 295/65r20 is 35.1", but that might be fine on a 3rd gen with no lift.
  30. Jan 13, 2024 at 6:52 AM
    Scotkulp
    Scotkulp New Member
    Scot
    Virgin
    You are pretty safe with stock rims and tires up to 295 width, <35" dia. For 20" rims, thiswould be 295/60r20 which are 33.9" nominally. 295/65r20 is 35.1", but that might be fine on a 3rd gen withnolift.
    TundraDan723 likes this.
