Tire rubbing after level kit
Discussion in 'Suspension' started by JewelledKitten, Aug 26, 2022.
  1. Aug 26, 2022 at 9:55 AM
    JewelledKitten
    JewelledKitten [OP] New Member
    2021 Tundra SR5 2019 Tacoma TRD
    Hi!
    I had an RC 1.5" level kit installed on my 21 SR5 and now the front tires rub when turning sharp. Is that normal?
    TIA
  2. Aug 26, 2022 at 9:59 AM
    mike220022
    mike220022 New Member
    Do you have front mud flaps, if so pull those off first and see if it helps any. What size tires did you go with? I just put the RC 2.5-3 inch leveling kit on my '08 and put 33s on it and they rub when turning sharp still after pulling the mud flaps
    JewelledKitten[OP] likes this.
  3. Aug 26, 2022 at 10:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    you had the front end alignment done after the install?
    Rub points would be the front little air flaps in front of truck, mud flaps, possibly sway bar or skid depending on wheel offset and tire size. What size tires and wheels and what wheel offset if not stock?
  4. Aug 26, 2022 at 1:22 PM
    WarDamnTundra
    WarDamnTundra New Member
    2014 Tundra TRD Limited CrewMax
    Icon Stage 2 w/ Icon Mini Leaf Pack - WildPeak A/T3W 35x12.5x20 - 20" Rock Star II - Retrax Bedcover
    I had a Pro Comp leveling kit installed on my 2014 and during the install they had to trim underneath where it wouldn't rub. It only rubbed on the right side when turning sharply. Not sure this helps. Im not 100% certain what wheel offset I have but they did offset them too.
    I am running 35s on the truck.
  5. Aug 27, 2022 at 12:09 AM
    JewelledKitten
    My tires are the stock Michelins. I put new wheels on it before the level kit and had no problem. The alignment was done with the kevel kit. The guy at the shop did say they were rubbing on the mud flaps. But why? I don't buy it or don't get it lol. Why does that happen when the only change is the level kit? I don't know the offset.
    Thanks for you wisdom guys! I appreciate it so much.
  6. Aug 27, 2022 at 12:23 AM
    Because you are changing the geometry of the suspension. When those angles start changing you can get rubs when you previously didn't, even with the same wheels and tires.
    Look at this image below.
    When you get a level kit or lift, etc. you are lengthening the coilover (C) with either a new coil over or spacer. To accommodate that being longer you are pushing both control arms (both marked A) apart, but they are attached to the vehicle at the same point as before. This makes them pivot slightly downward, and that pivoting moves the wheel and everything else in an arc around the circled points below. As it moves up or down, it also moves inward a bit as shown with the arcing arrows. This pulls the wheel and tire in a bit, and now when you turn you are rubbing because your wheel is actually in a different position.
  7. Aug 27, 2022 at 3:10 AM
    JewelledKitten
    My tires are the stock Michelins. I put new wheels on it before the level kit and had no problem. The alignment was done with the level kit. The guy at the shop did say they were rubbing on the mud flaps. But why? I don't buy it or don't get it lol. Why does that happen when the only change is the level kit? I don't know the offset.
  8. Aug 27, 2022 at 3:11 AM
    JewelledKitten
    Hey Godzilla - thank you :) I think I get it now!
  9. Aug 27, 2022 at 3:14 AM
    Sure thing. I wasn't sure I was explaining it very well, but I'm glad you could piece it together from my jibber jabber! :thumbsup:
  10. Sep 21, 2023 at 10:46 AM
    TruckGuyJeff57
    TruckGuyJeff57 New Member
    20 Black Tundra TRD
    hi - what a great job explaining this! I consume a lot of great material on this site, but don’t get a chance to contribute often. I’m considering getting an RC leveling kit and your post here helped me understand what’s involved. Appreciate it!
