Tire tread wear - Tire Cupping
Discussion in 'Wheels & Tires' started by SilveradoSwap, Apr 22, 2025 at 6:42 PM.
  1. Apr 22, 2025 at 6:42 PM
    SilveradoSwap
    SilveradoSwap [OP] New Member
    2024 1794 Edition Tundra
    I have Toyo OC AT3s on my Tundra and my son recently pointed out tire chopping on my outer tread blocks, mainly the ones that were on the front. Its not crazy but does make me wonder why it is happening. Can definitely feel it by running my hand over it, raised/ higher tread on the frontside of each tread block. I did install RC coilovers to level my ride at 3k, currently at 20k. Had the truck aligned twice when tires were installed, one shop didnt do it right. I rotate every 5k, last one I didnt get to it until 7k. I was rotating front to back per side. Last night I rotated in an X which puts the high side of each tread block to the back of the block.
    Has anyone else experienced this? Hate to see tire wear given the high price of rubber.
  2. Apr 22, 2025 at 6:53 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Reduce your tire pressure and see what happens.
    SilveradoSwap[OP] likes this.
  3. Apr 22, 2025 at 6:59 PM
    SilveradoSwap
    I was at 45psi, should I run 35psi per the door sticker?
  4. Apr 22, 2025 at 7:00 PM
    SilveradoSwap
    Anytime an unknown shows up on a vehicle I tend to hit the panic button, lol.
  5. Apr 23, 2025 at 6:13 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Interesting. I've never seen cupping at higher psi. I've also never seen rotating in an X pattern on radials, I've always heard keep the tires rotating the same direction (on the same side). I generally run higher psi in front unless towing something, but definitely higher psi for summer/economy. I have experienced cupping but only at lower psi.
    HulkSmurf14 likes this.
  6. Apr 23, 2025 at 6:18 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
  7. Apr 23, 2025 at 6:32 AM
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    I also have Toyo AT3s and the RC N3 front struts and I also noticed uneven wear. I had another alignment done and it seems better... but I'm just like you - paranoid it's not absolutely perfect!
    Can you share a pic of the cupping?
    [Edit - I run all 4 tires @ 42PSI]
  8. Apr 23, 2025 at 3:41 PM
    SilveradoSwap
    This is the best I can get, more about feel really for me. Right side block is higher on the one side than the block on the left.
  9. Apr 23, 2025 at 4:37 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Lot of times cupping can come from not rotating. Also can come accelerating hard too or over torquing.
  10. Apr 25, 2025 at 5:55 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    As far as rotation goes, my understanding is drive wheels move straight (forward or back on same side) the other two cross over to the other side. I've always done it this way, it helps to keep wear patterns at a minimum.
    Of course proper alignment is always important.
  11. Apr 25, 2025 at 7:16 AM
    SilveradoSwap
    There are quite a few tire rotation methods that are acceptable to use based on the drive type (rear, front, 4-wheel). In my case, I choose what would make the most sense given my situation. I also took the advice and dropped my tire pressure. All seem well currently, I’ll monitor wear as I put on more mileage.
  12. Apr 25, 2025 at 7:50 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    that's what I was told and I didn't do
  13. Apr 25, 2025 at 11:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Does it vibrate or wander to a direction when driving? You can get cupping with funky toe on occasion, too...I'd do the "cheapest" first and air down to 36psi and see how that works...then address the next solution...
  14. Apr 25, 2025 at 1:12 PM
    SilveradoSwap
    It tracks straight.
