Tire/wheel/lift combos
Discussion in '2.5 Gen Tundras (2014-2021)' started by SeabeeTundra, Oct 27, 2019.
  1. Oct 27, 2019 at 3:24 PM
    SeabeeTundra
    SeabeeTundra [OP] New Member
    Rick
    2014 Tundra Limited
    Hi all, I have a 2014 Tundra Limited with the TRD Off-road package. I currently have the factory 18” TRD wheels with the 275/65R18 Michelin tires. I’m looking to upgrade to either a 18x9 or 20x9 wheel with Nitto Ridge Grapplers. I understand I’ll have to put a lift kit and am open to putting up to a 4” lift.
    Any recommendations on tire size, wheel spacing and how much lift I would need to fit them? Thanks in advance!
    TXRailRoadBandit73 likes this.
  2. Oct 27, 2019 at 6:48 PM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    I have airlift on rear with Toyota shocks. Rides way better tan I expected.
    saybng likes this.
  3. Oct 27, 2019 at 6:54 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
  4. Oct 27, 2019 at 9:37 PM
    panicfishwater
    panicfishwater New Member
  5. Oct 27, 2019 at 10:46 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Very nice! What lift and rim/tire specs?
  6. Oct 27, 2019 at 10:56 PM
    That's a schweeeet ride!
  7. Oct 27, 2019 at 11:02 PM
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    1475E87B-D176-4C88-8E5D-82D7069CF6F1.jpg EE4249D2-ECF5-4F33-8573-A427A46EF07D.jpg
    18x9 Stealth Custom Series Ray 10s. 275/70R18 Ridge Grapplers. Bilstein 6112 set at 1.9” up front with 1 CB shim on driver side. 5160 in rear with no lift.
    EDDO, Mattco808, Tundra_361 and 2 others like this.
  8. Oct 28, 2019 at 6:55 AM
    panicfishwater
    kings 2.5
    Shackles in the rear
    35x12.5x18
    Method 306 wheels
  9. Oct 28, 2019 at 3:58 PM
    Leetomnsx
  10. Oct 30, 2019 at 7:22 PM
    Rand7777
    Rand7777 New Member
    South Texas
    2018 MGM Platinum
    Got a 3/1 with factory wheels on 295/65R20 nitto ridge grapplers, 1.25 spacers, and bumper spacer. So far so good.
    Leetomnsx likes this.
  11. Dec 30, 2019 at 5:24 AM
    TundraTrucking4
    TundraTrucking4 New Member
    Has anyone seen these wheels on a tundra at all? I've googled the crap out of it and nothing KMC Wheels KM702 Duece 20x8.5 Satin Black Milled +35mm Offset
  12. Dec 30, 2019 at 4:35 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    SWEET!
  13. Dec 30, 2019 at 4:42 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    Still waiting on Coachbuilder shock shims, bumper shims, +3 shackles, steering kit and bump stop extensions and 5 BFG 35x12.5r18 KO2s
    pictured are FN BFD 18x9, king OE fronts and rears, Total Chaos UCAs
    I’m told that with the following alignment specs:
    Alignment specs to use after installing:
    Camber +.2 Degrees Per Side.
    Caster +2.2 - +2.5 Degrees Per Side.
    Toe +.07 - +.10 Degrees Per Side, Not to Exceed +.20 Combine.
    my understanding is that everything should fit with only minimal trimming....fingers crossed. 6CE6E5A3-8661-4A09-8A1B-203A21BD837D.jpg
    JH5370 likes this.
  14. Dec 30, 2019 at 4:53 PM
    MJ_19Tundra
    MJ_19Tundra Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
  15. Dec 30, 2019 at 5:11 PM
    Phin Fan13
    Phin Fan13 New Member
    '18 Tundra CM MGM
    A-Pillar, Limo Tint, Stubby Antenna, Pedal Commander, K&N filter and Hard Shell Trifold Tonneau Cover. Color Matched Grille Surround, glossy grill insert, color matched mirror caps, center console wireless phone charger.
    That's awfully purdy!!!!
  16. May 6, 2020 at 11:27 AM
    Lossy87
    Lossy87 New Member
    Carlos
    2014 Tundra Crewmax
    What’s lift set up do you have
  17. May 6, 2020 at 11:35 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Procomp 20" wheels. Procomp 6" with extended spindles. Blocks plus add a leaf in the back.
