Tired of bad phone mounts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bullshawrk, Apr 9, 2025.
  1. Apr 9, 2025 at 6:50 PM
    Bullshawrk
    Bullshawrk [OP] New Member
    Tired of phone mounts which ones you guys going with?
    Looking at rago or the one from Amazon
    Need some pointers please!
    Corndog123 likes this.
  2. Apr 9, 2025 at 6:51 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I went with ICS and it's absolutely rock solid. Never once has to adjust it. I like it better than rago because it's easier to access under the mount to add more accessories without removing the mounting plate and I can still use the area for putting things in.
    JMGmanAZ likes this.
  3. Apr 9, 2025 at 6:55 PM
    Bullshawrk
    Do you have a link?
  4. Apr 9, 2025 at 6:56 PM
    MadMaxCanon
    Tripleconpanna likes this.
  5. Apr 9, 2025 at 7:17 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    I've been using a proclip in each of my vehicles for several years now. It's a little pricy, but rock solid. In essence you'll need to order two pieces, one piece is the custom designed mount for your Tundra center dash and the other piece is a custom designed holder for your particular phone. The two pieces mount together into one unit. https://www.proclipusa.com/
    Wolfie410 and Bergy24 like this.
  6. Apr 10, 2025 at 4:27 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have this and i like it real well. Can’t fully close the vent but it will shut bout 85%.
    https://a.co/d/jcXWxao
  7. Apr 10, 2025 at 4:35 AM
    MyActualName
    MyActualName New Member
    Buy once, cry once: https://www.amazon.com/dp/B09DWKS5BX
    Offroam phone mount (I bought the Tacoma one, worked great on my tundra vent).
    Best phone mount I've ever seen/used.
    Super solid, no movement whatsoever.
    Easy placement and removal.
    100% solid aluminum, no plastic junk.
    Spring action on the jaw sliders.
    Fits multiple sizes phones due to sliding jaws.
    Love it so much I bought another to use in my wife's Subaru.
    10/10 would buy again.
    DiamondW likes this.
  8. Apr 10, 2025 at 7:42 AM
    Mirg
    Mirg New Member
    2021 Tundra Limited TRD OR
    Absolutely love the ProClip with Scosche MagSafe mount!
    Buhockey22 and DeepBushCaboose like this.
  9. Apr 10, 2025 at 7:49 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Proclip on top can be used with phone. RAM on bottom has been good. Little rubber pieces work themselves off.20250402_150852.jpg
  10. Apr 10, 2025 at 8:00 AM
    I've had nothing but vibrations with the vent mounts. I can't recommend them.
    MadMaxCanon likes this.
  11. Apr 10, 2025 at 8:19 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I swore off vent phone mounts after my phone overheated one time from the heater.
  12. Apr 10, 2025 at 8:19 AM
  13. Apr 10, 2025 at 8:23 AM
    seydou
    seydou Distinguished Member
    Another vote for Proclip. Keeps the phone out of your field of vision. Great adjustability of viewing angle. Zero function loss of the vent and with a iOmount from Klockwerks there is zero vibration. Like them so much my new Tundra is the fourth vehicle I have put them in. Not the cheapest but imo the best.
    https://getklocked.com/products/iomounts-universal-magnetic-phone-mount
  14. Apr 10, 2025 at 9:54 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Got any details on which Scosche you used? There's so many on their site.
  15. Apr 10, 2025 at 9:58 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have the Rago mount with the ics backing plate and tackform mounts. Works great for my purposes and very secure
    JMGmanAZ and Tripleconpanna like this.
  16. Apr 10, 2025 at 10:22 AM
    SD Surfer
    Bruce
    So Cal
    I've tried multiple different mounts, and there's something I hated about all of them... I'm pretty dang happy with this little cheapo! Like $14 for a 2-pack on Amazon.
    I've bombed down some washes in the desert pretty good and it stays put, the only time it falls off is if I accidentally hit the edge of the phone.
    This is with the metal piece for the magnet inside my phone case, it would hold stronger if I stuck it to the outside of the case.
  17. Apr 10, 2025 at 10:33 AM
    DeepBushCaboose
    DeepBushCaboose New Member
    Michael
    Austin, TX.
    2020 Black Platinum Tundra
    atc250r[QUOTED] likes this.
  18. Apr 10, 2025 at 10:42 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    RAGO with the ICS support plate and mounts:
    Patch999, cwmoneymaker and Tunrod like this.
  19. Apr 10, 2025 at 12:49 PM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    Second the buy once , cry once approach. Had good luck with OFFROAM mounts
  20. Apr 11, 2025 at 6:36 PM
    cwmoneymaker
    cwmoneymaker New Member
  21. Apr 11, 2025 at 6:37 PM
    cwmoneymaker
    I would like to have the starlink mini mount to
    This
    JMGmanAZ[QUOTED] likes this.
  22. Apr 11, 2025 at 9:18 PM
    ericmunns
    ericmunns New Member
    Eric
    Seattle
    2019 white 1794/TRD
  23. Apr 11, 2025 at 9:43 PM
    MadMaxCanon
    Yes but you can leave it wired up, at least I did. Pretty easy to do, just use a plastic trim tool and a zip tie to keep the HU from falling down and stressing wires.
    cwmoneymaker[QUOTED] likes this.
  24. Apr 11, 2025 at 10:16 PM
    cwmoneymaker
    I guess at that point it would be worth switching it out to get Apple car play..
  25. Apr 11, 2025 at 10:33 PM
    MadMaxCanon
    Also a good time to add front anytime camera.
  26. Apr 11, 2025 at 10:34 PM
    cwmoneymaker
    for sure. My superduty front camera is so nice. You don’t realize what you’re missing until you don’t have one
    MadMaxCanon[QUOTED] likes this.
  27. Apr 11, 2025 at 10:37 PM
    MadMaxCanon
    Yup, couldn't live without it now.
  28. Apr 12, 2025 at 4:20 AM
    ZPMAN
    Minnesota
  29. Apr 12, 2025 at 5:18 AM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    I had the same problem.
    I went with Rago because I liked the look better, the combined that with a MagSafe charger. I am currently using the otter box head on a ram arm and with the right case it stays locked in tight even over the roughest terrain.
