Tires for rocky trails in AZ
Discussion in 'Arizona' started by VWTim, Aug 12, 2022.
  1. Aug 12, 2022 at 9:30 AM
    VWTim
    VWTim [OP] Mid-Travel Crew
    Corvallis, OR
    My wife and I just moved here last month for a 1 year assignment, we're from the PNW that is generally really easy on tires. I'm currently running a fairly new set of Terra Grappler G2's on my mid-travel '07.
    We've done 2 "trips" around here, spent one day taking the out/back way around Lake Pleasant, including the BLM slice on the North side of the lake. Then we went up past Crown King and back last weekend pulling our Teardrop.
    I'm super happy with how the tires are handling, but noticed they are getting a LOT of broken/cut/town tread blocks. I'm assuming that's par for the course out here with the small blocks on an AT tire.
    Anyone have direct experience how swapping to a MT tire will hold up with the larger blocks? I was considering Grabber X3's originally, but went with the AT's due to the rain/snow I see up north.
    Any insight?
  2. Aug 12, 2022 at 9:51 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve had decent luck with my Toyo open country AT3s but I think mud tires would chunk and cut just the same as AT tires. Pay to play
  3. Aug 12, 2022 at 10:34 AM
    AZBoatHauler
    So.Arizona
    Toyo AT3 and BFG KO2 seem to be the most popular choices. I’m on my second set of Nitto Ridge Grapplers but they seemed to get hard and start chunking bad after 25k miles… First 20k miles were great.
  4. Aug 12, 2022 at 10:34 AM
    AZBoatHauler
    So.Arizona
    And air down. High pressure + wheel spin is the enemy.
    shellshock and FrenchToasty like this.
  5. Aug 12, 2022 at 10:40 AM
    VWTim
    Corvallis, OR
    Already on that, plus the ride is much better.
  6. Aug 12, 2022 at 10:54 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    KO2s were good, but my set would get torn up from the rocks.
    It didn't help that I would choose the rockier line. :rofl:
  7. Aug 12, 2022 at 12:38 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I know of someone who put the Goodyears with kevlar on and they still got torn up.
  8. Aug 12, 2022 at 12:43 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    All tires are going to chunk on rocks, no way around it. BFG has a good track record with desert/rock conditions. They shine there, much better than how they perform on wet pavement. I would say BFG MTs for your conditions.
  9. Aug 12, 2022 at 12:46 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I have more issues with sidewall cuts than I do tread damage with my Wild Peaks AT3's.
  10. Aug 12, 2022 at 4:57 PM
    VWTim
    Corvallis, OR
    I unfortunately got burned by a set of BFG MTs a while back. KM2s that would not hold a balance
    Now to decide between trashing my ATs or pull them off for when we eventually return to the NW and get a set of X3s for down here...
  11. Aug 13, 2022 at 6:55 AM
    frichco228
    Yes, BFG can have balance issues. AT or MT, any tire is going to get some chunks and wear more heavily in the conditions you off road. Just pick a tire you like and know that you will be replacing them more frequently due to the conditions you run.
  12. Aug 13, 2022 at 8:33 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Toyo MT is probably one of the best tires for durability
    CaptRussia253 likes this.
