Tires Poke Further on Passenger Side
Discussion in '2nd Gen Tundras (2007-2013)' started by MGMTUNDRA12, Jun 20, 2023.
  1. Jun 20, 2023 at 6:15 PM
    MGMTUNDRA12
    MGMTUNDRA12 [OP] New Member
    2012 Tundra SR5 Double Cab MGM
    2" Level Kit Yellow Tinted Fogs 6000k LED Highs & Lows 20% Window Tint 1 1/4" Wheel Spacers Shorty Antenna Weathertech Mats
    Hey guys, looking for some input on this. I'm running 1 1/4" wheel spacers on stock SR5 +60 offset rims and the passenger side sticks out further than the driver side.
    While parked on flat ground, I pressed a level against each fender and while showing plum. Passenger side sticks out 1/8". Driver side doesn't clear the fender. My guess is 3/8 - 1/2" difference between the two.
    Any takers on an explanation?
  2. Jun 20, 2023 at 6:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Are you sure they are installed correctly?
  3. Jun 20, 2023 at 6:20 PM
    Totally normal.and it is usually the passenger rear that is the most noticeable.
    IsaiahCanada likes this.
  4. Jun 20, 2023 at 6:51 PM
    MGMTUNDRA12
    Yes I torqued them to spec, used blue loctite and retorqued after 75kms. No vibrations or wobbles.
    MadMaxCanon[QUOTED] likes this.
  5. Jun 20, 2023 at 6:52 PM
    MGMTUNDRA12
    You do make a good point. The passenger side rear is likely the most prominent one both visually and when measured. So basically I just gotta live with it I guess?
  6. Jun 20, 2023 at 6:59 PM
    Yeah it drives the OCD people crazy but you will forget about it eventually. Every Tundra has it.
  7. Jun 20, 2023 at 7:08 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    order 2 spacer with different offset...:nuclear:
  8. Jun 20, 2023 at 7:19 PM
    MGMTUNDRA12
    I guess I could buy two 1" Bora spacers but I might just live with it for the price of those things.
  9. Jul 18, 2023 at 12:50 PM
    ryanallaire
    ryanallaire New Member
    Ryan
    2010 CM 5.7
    3" RC leveling kit, S&B intake, custom DIY exhaust, tuned for 91 octane, morimoto headlights, all LED interior lighting.
    Did you have to do any modifying to the stock wheel studs or wheels?
  10. Jul 18, 2023 at 12:55 PM
    MGMTUNDRA12
    Nope, everything is stock. I didn't change the 1.25" to 1". Just checked torque again after 1000kms, all good. Still no vibrations or anything.
  11. Jul 18, 2023 at 12:58 PM
    ryanallaire
    Ryan
    2010 CM 5.7
    I'm trying to find out if 1" spacers need any modifications done...
