Tires sizes for 2020 ?
Discussion in 'Wheels & Tires' started by vsantoro, Mar 20, 2023.
  1. Mar 20, 2023 at 6:54 AM
    vsantoro
    vsantoro [OP] New Member
    vic
    2020 Gray Tundra TRD PRO
    Is there a specific thread for tire sizes?
    I have a 2020 TRD Pro , the stock tires are about shot and time for new ones.
    They are 275 65 18.
    I am looking for something aggressive looking like most people, also not too loud on the roads. I live upstate NY where there is alot of snow. Looking at the Nitto Ridge Grapplers.
    I have seen some posts about people putting different sizes on it. But I do not want any rubbing or messing up the speedometer or any computers/sensors.
    Any suggestions on size that will not rub or mess anything up or is my best bet to go default size. Would love to go slightly larger.
    Thanks for any feedback.
    Vic
  2. Mar 20, 2023 at 7:02 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  3. Mar 20, 2023 at 7:07 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    I Just put on 275/70 BFG KO2. My wheels are a +25 offset, had to remove the front flap. But check the thread linked above for all sizes and lift configurations
    Sean492 likes this.
  4. Mar 20, 2023 at 7:25 AM
    vsantoro
    vic
    Thank you both.
    This is what I see on that thread for my truck.
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
    So this means I can go up to 285 width without issue but I dont think that brings the height up any, why would it be 5/10 taller.
  5. Mar 20, 2023 at 7:29 AM
    285 is the width. 65 is the ratio of width to side wall height. So 65% of the width will be the sidewall height. You make it wider and keep the same 65% ratio, it's also gonna be taller.
    RetiredTundra likes this.
  6. Mar 20, 2023 at 7:29 AM
    vsantoro
    vic
    ok thank you. Im going to see if i can find someone on here with that size maybe theres pics. thanks again
  7. Mar 20, 2023 at 7:42 AM
    PermaFrostTRD
    Northern NY
    https://www.tacomaworld.com/tirecalc?tires=275-65r18-285-65r18
    also, once you get a tire size that you want, look at 3peak snowflake rated tires if you dont want to run dedicated winter tires for the snow. BFG KO2, Cooper Disco AT3, Falken WP AT3W, Toyo OC AT3, General Grabber, Mickey Baja Boss AT, etc are some of the tires that fit this designation (in most sizes). Any change to size and weight will throw off your speedo, fuel consumption, and driving "feel"
    A more aggressive AT tire is going to be louder, firmer, and heavier than your stock tires. if you can keep things under 55lbs per tire, you shouldn't notice too much of a difference in feel, but depending on size, your instrument panel will be affected.
  8. Mar 20, 2023 at 7:45 AM
    vsantoro
    vic
    great information. thank you for the link, looks like not much difference. I definitely dont want dedicated snow tires, Just a decent aggressive looking tire for normal driving then good in the snow during winter.
  9. Mar 20, 2023 at 7:55 AM
    PermaFrostTRD
    Northern NY
    Since you have a PRO - your truck comes stock with a 2" front suspension lift vs other Tundras. You can fit a 295/70/r18 (34"x12") in your truck (with most tires, the Mickey Thompson Baja Boss AT is the widest for that size and heaviest) without any trimming cutting or anything else except removal of the forward "front" mudflap that honestly serves no purpose that i've seen. The mickey will rub your front sway bar, and leave a ¼" (on a good day) of space clearing your UCA.
    A 285/75r18 (34.8" x 11.8") may require some trimming. But nothing major.
    A 285/70r18 will fit very well, and look pretty awesome/agressive on your truck. Very pricey, heavy, and large. Will definitely affect your requirements of "sensors & computers". but won't be detrimental to the drivability or reliability of your truck (the checkbook will get a little smokey with the extra gas, but thats about it). There are programmers that can adjust your speedometer based on tire size increase.
  10. Mar 20, 2023 at 8:04 AM
    vsantoro
    vic
    great info again. Thank you again.
    So with a 285/70r18 I would not need to remove the mud flap or anything else and no rubbing/trimming tire correct ? I see its a little more of a difference with the speedometer but that will not negatively influence the the truck besides gas mileage (im only getting about 14-16 now but I don't really care about that). That sounds like its what I would like to get. I will update my other post to see if there are any pics of my truck with those tires on it. This is why I love the power of forums, It would have taken me many hours to find this info and unlikely it would be this good.
    PermaFrostTRD likes this.
  11. Mar 20, 2023 at 8:24 AM
    PermaFrostTRD
    Northern NY
    You're welcome. You would likely need to remove the forward facing front mudflap. It's very small.
    I believe @RusPro21 runs a ridge grappler in this size on his 2021 pro. Check his build, or maybe he'll chime in from his tag.
  12. Mar 20, 2023 at 8:27 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've read Ridge Grapplers are not that good in snow.
    Myself running 275/70R-18 General Grabber A/TX, no questions in deep snow. They are slightly bigger (33"), but the speedo is not lying.
    Pbed85 likes this.
  13. Mar 20, 2023 at 8:39 AM
    vsantoro
    vic
    ok good to know, ill check out the general grabbers. are those 275/70r18s on a tundra trd pro ?
  14. Mar 20, 2023 at 8:44 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No, TRD OR, but the wheel params are exactly the same. Wife drives TRD PRO Sequoia, I've swapped PRO wheel to my OR Tundra for test and decided I don't mind OR wheels.
  15. Mar 20, 2023 at 8:46 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  16. Mar 20, 2023 at 8:47 AM
    vsantoro
    vic
    thank you
  17. Mar 20, 2023 at 8:49 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    On my stock Pro I run 285/70/18’s no rubbing issues at all. You can leave the flaps on. I’m now lifted with the westcott lift and still keeping my 285’s.
  18. Mar 20, 2023 at 8:51 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    275/70/18 is bigger than 285/65/18.
  19. Mar 20, 2023 at 8:52 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    One thing I always forget to mention is that if you liked how your Michelin LT/X drive and you don't do offroad too often, better get a P-rated tire. It looks as aggressive, however it is much lighter, which is good for MPG and softer ride. All LT tires are stiff by design.
  20. Mar 20, 2023 at 8:56 AM
    Taller, but not wider. So bigger in some respects.
  21. Mar 20, 2023 at 9:09 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    use this to show the conversions, size in inches, as well as speed difference.
  22. Mar 20, 2023 at 9:30 AM
    vsantoro
    vic
    great info everyone. thanks. My current size is 275 65 r18, If I went to 285 70 r18 wouldnt that make the new tire not as wide as my current tire ?
  23. Mar 20, 2023 at 9:32 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    First number is width. 285 is 10 mm wider than 275.
    Hbjeff and KNABORES like this.
  24. Mar 20, 2023 at 9:40 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  25. Mar 20, 2023 at 9:42 AM
    vsantoro
    vic
    thank you. looks good to me. Hey RusPro21, you said you run the 285/70R18's on your pro. It says you have a 21, is everything the same as a 2020 ?
    You did not have to trim or remove anything and it fits on that oem wheel correct ?
    what tires are they ?
  26. Mar 20, 2023 at 9:44 AM
    vsantoro
    vic
    vtl - do you have a recommendation for a p rated tire that looks as aggressive in 285/70/R18 ? Im guessing the grabbers are not P rated.
  27. Mar 20, 2023 at 9:53 AM
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    I have a 2020 pro and got new 275/70r18 last fall. Cooper discoverer at3 xlt. I think their perfect! 76C624BA-0EBA-41D0-A3B4-86F079EE1331.jpg7E4E39B0-BE08-4C96-B19E-978651EB7A39.jpg
    ATV25 and EN2TUNDRA like this.
  28. Mar 20, 2023 at 9:54 AM
    vsantoro
    vic
    looks great thank you 7dgoat, I would love to see what a 285/70R18 looks like on a 2020.
  29. Mar 20, 2023 at 10:32 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    rruff likes this.
  30. Mar 20, 2023 at 10:36 AM
    PermaFrostTRD
    Northern NY
    There are only (to my knowledge) 6 tires offered in the 285/70r18 sizing. All LT and mud terrain, all-terrain.
    rruff likes this.
