Tires with no lift or level
Discussion in 'Wheels & Tires' started by rustynail11, Jan 31, 2018.
  1. Jan 31, 2018 at 7:42 AM
    rustynail11
    rustynail11 [OP] New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    I have searched and can't find an answer so I apologize if this question has been beat to death.
    I have a 2017 SR5 TRD CrewMax. I want to dump the stock tires and get something more aggressive. I don't want to lift or level, I like the current ride and for the limited off-roading I do (mostly beach) stock height is fine.
    So my question is what is the biggest tire I can go to at stock height? I have no problem doing a little trimming or running spacers if needed.
  2. Jan 31, 2018 at 7:46 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    With 275/70/18 you may have to bend in the front skid plate on the edges to keep from rubbing (some have a slight rub with this size, some don't). I had this size (Nitto Ridge Grapplers) on my previous Tundra and they looked and rode great. A lot of guys also run 285/65/18.
  3. Jan 31, 2018 at 7:47 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Check out wheel and tire specs thread. Link in my sig. Thanks.
    trayday likes this.
  4. Jan 31, 2018 at 7:47 AM
    T-Rex266 SpaceX Director Staff Member
