tnga frame
Discussion in '3rd Gen Tundras (2022+)' started by Jthawks, Dec 10, 2023.
  1. Dec 10, 2023 at 10:57 AM
    Jthawks
    Jthawks [OP] New Member
    Jeff
    2022 tundra limited silver trdoffroad
    As we all are aware is that toyota uses the tnga frames for all its body on frame vehicles globally. My question is and I hope someone can explain this, how can the same frame on my tundra be the same as the new tacoma frame? Also the same frame as the new landcruiser and most likely new 4runner? I guess I'm looking for more of the technical side of how toyota achieves this with so many models using this frame. Thank you for any insight to this.
    Well not sure why I did not think to ask google but I did and I mostly got my answer. hahaha
  2. Dec 10, 2023 at 11:05 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Perhaps it was designed to scale in/out as needed. They have a parametric model, where you say what you need and the software generates a frame that will fit the needs. It is a different frame, but it uses the same digital model and goes through the same computations.
    It's catch up game, of course, since more advanced vendors use it for at least two decades. They build a whole model line out of one digital model.
    ryanwgregg and Jthawks[OP] like this.
  3. Dec 10, 2023 at 11:10 AM
    Jthawks
    Jeff
    one would think putting a mid size body and underpinnings on a fullsize truck frame would not make sense. So you are probably right and it does make sense. Also found tnga F platform is used for all body on frame applications just different codes for every different model.
  4. Dec 10, 2023 at 4:55 PM
    xc_tc
    xc_tc New Member
    The frame rail width is narrower on the TNGA frame than the previous one. This is how it can be used on a midsize truck. And for length, they just extended the frame center section depending on the length of the vehicle body. Some sections/cross members are modified for each model but the basic architecture is the same.
    I found this on another forum
    GX550 frame
    LX600 frame
  5. Dec 10, 2023 at 5:59 PM
    Jthawks
    Jeff
    Thanks for that, that explain it better than what I read online.
    ryanwgregg likes this.
  6. Oct 18, 2024 at 11:06 AM
    SeanW88
    SeanW88 New Member
    2024 Tundra Limited TRD off road
    Anyone know what toyota use to paint their new tnga frames from factory? The black finish looks better than the 2022 tacoma I had before, it's more "gloss" looking and looks more durable. My new 2024 tundra, picked up last week had a scratch on the rear frame, not sure how it happened, most likely from transporting, but I'm looking to touch it up before I apply undercoating on it, I know I probably don't have to cause undercoating cover it anyway, but I prefer to.
    Tundrastruck91 likes this.
  7. Oct 18, 2024 at 11:37 AM
    Breathing Borla
    Northern Illinois
    take it back to the dealer and have them document and fix it
    CYA for later
  8. Oct 18, 2024 at 12:37 PM
    SeanW88
    SeanW88 New Member
    do you think they have some "special" way to fix this or just spray one of those paint like we do? If that's the case I rather just do it myself and keep the paint for next time when I need it after overlanding or offloading. The dealer is about 1 hour away.
    Thx for your reply bro.
  9. Oct 18, 2024 at 12:57 PM
    Breathing Borla
    Northern Illinois
    I just think on a brand new truck let them handle it and most importantly get it documented in case something happens later, then you don't give them the excuse, well you did this repair blah blah.
    Hella Krusty likes this.
  10. Oct 18, 2024 at 1:09 PM
    SeanW88
    SeanW88 New Member
    yes, that point makes sense.
    Thank you
  11. Oct 18, 2024 at 4:32 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Oh no, a frame damage, they will total your truck!
    C'mon, it's just a scratch. Not even metal deep.
  12. Oct 18, 2024 at 4:38 PM
    SeanW88
    SeanW88 New Member
    lol I know it's not a big deal, that's why I'm gonna treat it myself. Just wondering what's the best "spray" I should use for this frame.
  13. Oct 18, 2024 at 5:03 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    SeanW88[QUOTED] likes this.
  14. Oct 18, 2024 at 5:29 PM
    SeanW88
    SeanW88 New Member
  15. Oct 18, 2024 at 5:35 PM
    Hella Krusty
    Hella Krusty New Member
    I would just spray it with a high quality black gloss. One day of rain no one is going to see it anyways
    SeanW88 likes this.
