To lift or not to lift, many things to consider.
Discussion in 'Suspension' started by Ruggybuggy, Feb 6, 2024.
  1. Feb 6, 2024 at 7:03 AM
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your thinking of lifting you should always evaluate the effect it will have on the stability, reliability, payload and towing ability. TFL has a very good video that talks about the consequences of installing a lift and oversized tires.
    https://youtu.be/vOGn-nNB3qk?si=rCLOeOgzqAUkoQMf
  2. Feb 6, 2024 at 7:14 AM
    Sadly, I think many believe that the lift and big tires increases the trucks ability in these areas.
    Sierradevil likes this.
  3. Feb 6, 2024 at 7:54 AM
    Steve6
    Steve6 New Member
    Tucson
    Great info. Thanks for posting it.
  4. Feb 6, 2024 at 8:07 AM
    SD Surfer
    Bruce
    So Cal
    I'm frightened and amazed on a daily basis by some of the shit that many people believe. :rolleyes: It's astounding we haven't wiped ourselves out of existence yet.
    Ebrperk, 2mchfun and Ruggybuggy[OP] like this.
  5. Feb 6, 2024 at 8:10 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Bigger tires do not help with towing. They create more stress for the drivetrain and raise the center of gravity which effects handling.
  6. Feb 6, 2024 at 8:15 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    So on a more leveled discussion:
    Would leveling the truck with a 3/2 or 2/1 lift kit be worth it or would it also destroy the truck's center of gravity?
    I am not sure what vehicle manufacture were thinking, but why build a truck with front end heavy and backside high?
    I just want to level my truck so it doesn't nose dive at the slightest tap of the brake....
  7. Feb 6, 2024 at 8:27 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The rake design is for towing as the truck will level out once a load is placed on the bumper /bed.
    KNABORES and SnrDisregardo like this.
  8. Feb 6, 2024 at 8:32 AM
    Ghost Rider
    Ian
    Cypress, Texas
    But, even if you are a farmer or heavy truck user, there are gonna be times where you ride empty or just need to get some stuff without towing xlbs of dirt in the back or something....
    Guess I need the remote controlled leveling kit, rake when towing and level when not....
  9. Feb 6, 2024 at 8:38 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Or just haul some sacks of quickcrete or sand in the bed. I have my 37" spare in the bed shoved all the way up against my tailgate haha
  10. Feb 6, 2024 at 8:38 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You can level but everything is a compromise. As already stated, the rake is there for a purpose. If you don't use your truck to haul heavy loads or pull a trailer then a slight level will have a minimal effect.
  11. Feb 6, 2024 at 8:42 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Can I get a moderator to correct my title from "thing" to "things".
    Thanks
  12. Feb 6, 2024 at 8:45 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    All things considered, I lift my trucks and will continue to do so. I don't haul very often and rarely pull a trailer.
  13. Feb 6, 2024 at 8:46 AM
    2mchfun
    Definitely lift it, old and fat chicks can't jump!
  14. Feb 6, 2024 at 8:57 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Then you are one of the few that accepts that the lift does have a negative impact on towing and hauling. You have made the decision that more ground clearance is what is important to you. It's all about choice and what works best for your situation.
    For myself towing and payload is more important but I also realize that my truck will not go places that a modified Tundra would.
  15. Feb 6, 2024 at 9:05 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep. When I bought my truck, first thing I noticed when I opened the door was a sticker on the jamb that said my load capacity was decreased merely by the dealer installing the 20" wheels that come with the TSS package.
