Tonneau Cover Drain Holes
Discussion in '3rd Gen Tundras (2022+)' started by theredmoose, Nov 19, 2023.
  1. Nov 19, 2023 at 8:15 AM
    theredmoose
    theredmoose [OP] New Member
    I know I can drill through the bed however I would like to use a drain fitting but it is hard to put one in when you have to screw it in on the opposite side.
    Ideas?
    Here is the example for a pre-2022 truck bed.
  2. Nov 19, 2023 at 8:39 AM
    theredmoose
    One more question I had was whether it is better to make a hole in the wall or if we should make the hole in the bottom.
  3. Nov 19, 2023 at 9:29 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I'm not sure if you can see what I did with the BedRug in the way. I simply took a nylon 1/2" barbed X 1/2" threaded 90° elbow with a thin nut on the back side that came with the fitting. I pulled the bed wall plugs out and used a step bit to drill the hole in the plug so the threaded end would fit through and put the nut on and finger tightened it. I pushed the drain hose on then put the wall plug back in. This is the result. I also must credit another member on here for this idea. I just don't recall who that was.
  4. Nov 19, 2023 at 10:32 AM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    The third gen doesn't have the bed plugs.
  5. Nov 19, 2023 at 1:08 PM
    theredmoose
    Thank you for the pictures. Works great but as Nonoredomestics said, there is no bedplugs in the 2022+ bedliners. I have to drill, which I am fine with the issue comes with the fact that since there is no bed plugs I am unable to reach in and put the nut on the other side. I need a solution where I can fasten it from inside.
    Here are some ideas, but nothing perfect. Does anyone have any ideas similar to this? Something like this only smaller. Maybe a grommet style one might work too depending on thickness of the truck bed.
    https://www.amazon.ca/gp/product/B07Y4R7S7J?smid=A2Y9NV9G2H4FL0
  6. Nov 19, 2023 at 1:17 PM
    WBW
    WBW Resident lurker
    Bruce
    I didn't notice that you were speaking of the composite bed in the 2022+ Tundras. I don't have ideas. Sorry.
  7. Nov 19, 2023 at 6:15 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Why not just drill two holes big enough to ram the hoses through? It's not metal so you don't have to worry about rust or anything. I haven't bought a cover yet but when I do, that's my plan.
  8. Nov 19, 2023 at 6:16 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Just drill them where the plugs WOULD be and small enough to where you have to force them through and won't back out.
  9. Nov 19, 2023 at 6:40 PM
    4RunnerConvert
    4RunnerConvert New Member
    Colorado Springs
    22 TundraSR5 Silver
    LOL
  10. Nov 20, 2023 at 6:43 PM
    theredmoose
    It has crossed my mind a few times but I think it would look much cleaner and keep the inside much cleaner if they are sealed.
    This is my latest find. AC unit plugs. I just have to figure out how thick the plastic sidewall is.
    https://www.amazon.ca/gp/product/B0B9JZYS6V?smid=A1NR50YASSZD11&th=1
