Too much Brakes
Discussion in '1st Gen Tundras (2000-2006)' started by Griff04, Dec 5, 2023.
  1. Dec 5, 2023 at 8:59 AM
    Griff04
    Griff04 [OP] New Member
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    Over the weekend I did the following:
    1. Replaced both strut assemblies, both leaking
    2. Replaced drivers side inner and outer tire rods due to slop in both of them
    3. Replaced sway bar end links on both sides, both worn with slop in them
    Here’s the question on the brakes; I’ve noticed the last several times that my truck has sit for a couple days without driving the first couple of times I hit the brakes they almost throw me through the windshield. After they are engaged 4 or 5 times they are fine.
    Any ideas on what may be causing this appreciated.
    Thanks in advance,
    Griff04
  2. Dec 5, 2023 at 9:04 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Could the brakes be developing just a little bit of corrosion from sitting? On my mom's car the brakes are a lot louder for the first few applications after it sits, but that's really only if it's been a week or more, or if it's rained.
    Also- this started after you replaced the struts, tie rods, and end links? Or was it happening before?
    The Black Mamba likes this.
  3. Dec 5, 2023 at 9:06 AM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    It’s always been like this, even before the weekend work.
    FiatRunner[QUOTED] likes this.
  4. Dec 5, 2023 at 9:29 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Never heard of a temporary overly sensitive brake issue. That’s typically not an issue for our trucks. That said, I’m not sure what’s causing it.
  5. Dec 5, 2023 at 9:30 AM
    I find the same, I just can't remember if they're soft at first, then normal, or firm first, then normal.
    I want to say it's firm first, then normal. Maybe it's just a later-year thing?
  6. Dec 5, 2023 at 10:34 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I have the same thing although not as noticeable and it's worse after any kind of rain or snow. I like @FiatRunner explanation, makes sense to me.
  7. Dec 5, 2023 at 11:04 AM
    FiatRunner
    Jack
    I'm not sure how helpful this information is, but I figured it was worth noting-
    The brake calipers on my little Fiat 124 don't slide very well, and after the car sits for a week or two, it takes a couple good stabs at the brake pedal to get them loose. The brakes will drag and the pedal will be touchier. I think this is similar to the light corrosion idea, maybe things just need to loosen up a bit?
    Do you know when was the last time the brakes were replaced? Are they in good condition?
  8. Dec 5, 2023 at 11:10 AM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    Your Fiat brakes are little different design than the Tundra brakes. Fiat has (from my google search) a single piston with sliding caliper pins. The sliding caliper pins are what I believe you are refereeing to sticking a bit at first.
    The Tundra has 4 piston calipers, 2 on each side. Because there are pistons on both sides there is no need to have it on sliding caliper pins. As such, it is rigidly mounted to the knuckle. No sliding pins to stick.
    I am 100% with you on slight corrosion after sitting creating this increased braking feel. I've experienced it many times on multiple vehicles. Though surprisingly enough I don't experience it much on my Sequoia.
    whodatschrome likes this.
  9. Dec 5, 2023 at 11:14 AM
    FiatRunner
    Jack
    Man, you're completely right. For some reason I pictured the caliper with slide pins, despite having pistons on both sides. Total brain fart moment.
    I think it could still apply though- it sounds to me like something is sticking or not working as smoothly after sitting.
    OverSquareEng[QUOTED] likes this.
  10. Dec 5, 2023 at 11:15 AM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    It’s definitely not a show stopper for sure, just thought it was a little odd. Maybe it’s just the corrosion thing that Fiat mentioned.
    thanks for the replies.
  11. Dec 5, 2023 at 12:53 PM
    rock climber
    The T100 had 4 piston with sliding pins, probably other toyotas of the same era
  12. Dec 5, 2023 at 1:01 PM
    OverSquareEng
    Got a picture of one? I'd be interested to see how it's set up.
    All I can find are single piston with sliding pins (2WD), and 4 piston with no pins/solid mounted (4WD).
  13. Dec 5, 2023 at 2:22 PM
    Richid
    Richid New Member
    Had a similar issue in mine - turns out one of the calipers was sticking. Not so bad that it dragged, but you could feel it if you lifted the front wheel off the ground and tried to spin it after the truck sat for a few days. Determined it was a good time to just upgrade the brakes to WLs and bought calipers, rotors, pads.
  14. Dec 5, 2023 at 4:56 PM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    Richid, stupid question here, what does the acronym “WLs” stand for in your reply?
  15. Dec 5, 2023 at 4:59 PM
    I can answer. WL is the last two letters of the brake caliper model. WL, WE, WG are common brake caliper suffixes for the year rangle SUV/Truck these are.
    Earlier models of 1GT I think are all 13WE. My 2006 have 13WL calipers as should yours. I might have this a bit off, but you get the gist. The caliper model number is embossed on the caliper, same side as the hard brake line.
    Richid likes this.
  16. Dec 5, 2023 at 5:09 PM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    Thanks Shifty.
  17. Dec 6, 2023 at 9:58 AM
    Richid
    Richid New Member
    Yes - I think there are some threads around here on this. Early 00-22 came with WE, after used the larger WL. They are direct replacements and there was a TSB for user complaints regarding WE brakes where the dealer would upgrade to WL. They are direct fit, but larger - so swapping requires rotors, calipers, and pads.
    Not sure the difference is that much, but I figured to upgrade as soon as I needed a part - so the stuck caliper motivated me.
  18. Dec 6, 2023 at 1:23 PM
    rock climber
    Now that I re-read your comment maybe I misunderstood. The T100 had pins that hold the brake pads in place and the pads slide along the pins as the pads get worn. Not sliding pins like a single sided caliper.
    In my awesome paint picture the red is where the pins go.
  19. Dec 6, 2023 at 9:24 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Think rotors are the same but the pad surface is physically bigger right?
    Jack McCarthy likes this.
  20. Dec 7, 2023 at 5:53 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s correct.
  21. Dec 7, 2023 at 6:19 AM
    This is the frozen piston problem. Mine was always the drivers side outside lower. Replaced it twice. Current caliper has held up for the last few years without freezing up. But now when I rotate my tires I take some channel locks and squeeze them all to check them.
    Richid and w666 like this.
  22. Dec 7, 2023 at 6:23 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You have to burn through half the pad before the surface area is bigger. & even then, its not by much.
    When i was first going down this rabbit hole i was seeing that 13we rotors were 199mm & 13wl were 231mm, but that doesnt seem to be the case?
  23. Dec 7, 2023 at 6:48 AM
    Richid
    Richid New Member
    The rotors appear the same, but pads are apparently .6" longer - I think you can get tapered pads from different vendors. Ya - they would have less surface area until worn down.
    Realistically, I got way more brake out of adjusting the LSPV arm and the rear brakes. Of course, I had to replace the adjuster and clean the bell cranks to get everything working back there.
    Like @KNABORES, my drivers side caliper had been the problem. Haven't seen it with the WL, but I'm not expecting it to be the resolution.
  24. Dec 7, 2023 at 6:54 AM
    My WE OEs did it first. I replaced everything up front with the upgraded WL, rotors, calipers and new pads. 12k miles later the same thing happened. Replaced the driver's caliper again, and about 20k later, it did it again. Damn. Replaced again and haven't had the issue since (about 30k miles on current caliper). These are not OE calipers, but maybe remans of OE. I've been using the channel lock pliers to move all the pistons (squeezing the frame of the pads on each side to compress slightly) at each tire rotation.
    Richid[QUOTED] likes this.
  25. Dec 7, 2023 at 6:57 AM
    OverSquareEng
    Those are caliper length dimensions, not rotors. 13WE and 13 WL rotors are the same, 319mm diameter.
    Looks like friction coefficient is the same on both pads (FF), caliper pistons are the same diameter on WE and WL, pad height is the same, and pad length is slightly longer on WL's. Honestly surprised it makes much of a difference.
    Edit: though the friction coefficient is a range. F is 0.35 to 0.45 so the WE pads could be closer to 0.35 and WLs closer to 0.45....
  26. Dec 7, 2023 at 7:00 AM
    Richid
    Richid New Member
    Oh - great idea! I think I'll start doing this as well as it drags just enough to hang up and not return all the way.
  27. Dec 7, 2023 at 1:12 PM
    Jack McCarthy
    Bill
    North of Boston
    Not the case anymore if you go with the generic Toyota OEM ceramic replacements I just did. They got rid of that bevel you see.
    Mr.bee[QUOTED] likes this.
  28. Dec 19, 2023 at 4:46 PM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    So I finally got around to pulling the tires and checking for a sticking caliper…bingo, passenger side is definitely the culprit.
    Plans are to replace both sides to include rotors, pads, and calipers.
    Any recommendations on where to purchase just “stock” parts for this along with manufacturers. I’m really not looking to upgrade anything, the stock brakes work fine for me.
    TIA,
    Griff04
    bmf4069, OverSquareEng and shifty` like this.
  29. Dec 19, 2023 at 4:54 PM
    If you're OEM just rebuild. Unless this looks too complicated (it's pretty easy, take your time, have fun). This is your EXACT caliper, so all details are accurate to what you'll do:
  30. Dec 19, 2023 at 5:18 PM
    Griff04
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    Thanks Shifty, the video was definitely worth watching…pretty straightforward, I think I can handle that.
    shifty`[QUOTED] likes this.
