Toolbox suggestions for Gen1 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, May 8, 2020.
  1. May 8, 2020 at 2:07 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    One of my first mods will be adding a bed toolbox. Looking for suggestions on boxes and mounts.
    Typical emergency tools and supplies will be carried. Nothing irreplaceable or particularly valuable. I live in a quiet safe area.
    I figure steel or aluminum is necessary. Any preferences on gullwing or chest style, or those rectangle designs that sit in the bed versus the ones with wings that sit on the walls of the bed?
    Also, my truck has a bed liner insert. I don't see any holes to mount a bed but I do have steel tie down brackets near the front and don't want to obscure those from being used.
    Are there predrilled holes in the bed and I just have to locate them thru the bedliner? Or I've seen some people use steel J-hooks so I could just put small holes in the side of the bedliner at the lip? Thoughts and feedback appreciated. Thanks.
  2. May 8, 2020 at 2:12 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I had a UWS low profile cross bed chest style on my last truck and loved it. Aluminum was strong enough to carry everything I needed but light enough to handle by a single person when empty. Needed a toolbox and tonneau cover on my tundra so couldn’t bring it over otherwise I would have.
    can’t remember the length (easy to check) but it looked just like this:
    https://www.homedepot.com/p/UWS-69-...ile-Crossbed-Truck-Tool-Box-EC10473/306377884
    Richid and MrAristo like this.
  3. May 8, 2020 at 2:16 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Depending on how much ‘stuff’ you need to carry you could just do a swing case like I did.
    Weagle and abcinv like this.
  4. May 8, 2020 at 2:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have (and no longer use) a Deezee aluminum chest that fits just right on the bed floor. I drilled a hole on each side and removed the bolts holding the bed to the frame, then used slightly longer bolts to pass through the box and to the frame. Basically used the bed bolts to hold the box.
    I removed it because I didnt need that much storage anymore. Would be willing to sell cheap in Southern California. I upgraded it with steel latches so padlocks can be used.
    ToyotaJim[OP] likes this.
  5. May 8, 2020 at 2:56 PM
    ToyotaJim
    @Darkness Appreciate it, but I'm too far away. Someone might want it though!
    Darkness[QUOTED] likes this.
  6. May 8, 2020 at 3:04 PM
    ezdog
    ezdog New Member
    Gateway To The West
    It really just depends on how much storage you need and how nice a box you want.
    Look on CL and FB for sure though and score one for a fraction of the price of a new one and many times get a new one too!
    I have had several and the Adrian Steel or Weather Guard or Knack or other commercial units are so much nicer that its worth it to me to spend more but you cn usually find one for $100 and be just fine too.
    Darkness and ToyotaJim[OP] like this.
  7. May 8, 2020 at 3:07 PM
    ToyotaJim
    Yep, that's actually my plan. I have two (an aluminum and a steel one, both chest style) that I got second hand for cheap. Both are in use as tool lockers in my garage. I'm looking at a few used ones locally but want feedback before investing any time/money even on a used one.
  8. May 8, 2020 at 3:26 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Part of it depends too on how high your bed rails are and how high your arms are!
    If the bed sits too high it can be hard to get the chest style to work sometimes as there is a strange angle to unlatch them and then to close them sideways in which case the style that opens towards the center might be easier to use.
    Likewise if the box sits on top of the rails and the opening is higher then yo need to make sure that you can even reach in and not have to get into the bed to get stuff out,guess how I know what thats like?
    Times like that the Chest style might be better as the top is lower and easier to reach into and across from the ground.
    There is more to think about than you realize until you are trying to reach too high or far and lift something too big and heavy before you realize that the shorter box might have been the better call?
  9. May 8, 2020 at 3:54 PM
    Professional Hand Model
    Hand Protectors
    I had these on my truck since about 2003-4ish. They worked well for me. Carried a variety of items in them over the years until their removal last year when at that point the only thing in them was a check book and some nail clippers. They are still in great shape still. Looking to sell if interested. $200 each. Much more user friendly than the big inside the bed boxes. Polished Aluminum and keys included. You pay shipping.
    ToyotaJim[OP] and ezdog like this.
  10. May 8, 2020 at 5:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I also like my swing case.
  11. May 8, 2020 at 6:03 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Tough polycarbonate swing chest: AAA+++recommended. Whatever you choose, get only what you need to carry essentials, make it easily removable and weather tight/non-corrodible. Bigger metal boxes gather crap and the weather is brutal to them over a long time. A manageable, removable box stows essential gear but can be removed for hauling loads if necessary.
    MrAristo and CodyP like this.
  12. May 8, 2020 at 6:17 PM
    Hand Protectors
    No need to remove these for hauling loads, but they come off easily if needed. They actually help keep loads inside with the higher side walls.
    Weather tight and the 4 strut assists are brand new(ish) heavier duty# than the originals. Lids pop right up on their own and stay up until you pull them down.
  13. May 8, 2020 at 7:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have a box that mounts behind the cab on the bed rails using j hooks through the bed rail holes nearest the cab. Sit on top of the bedrails, has about a 6 inch gap between the bottom of the box, and the bed. Junk, dirt, and trash accumulates there. NG.
    In hindsight I would have gotten one that mounts INSIDE the bed such as the units described above.
    2 reasons for this​
    1. I have a shell for the truck, and at the time of purchase of tool box I was not thinking ahead. I would need to remove tool box for the shell to go on. It's not an issue now because the back glass is broken out of the shell. I still have yet to find a suitable replacement. So nbd there now.
    2. The junk/trash that accumulates underneath.
    I should have done more research, but I was trigger happy trying to clean up my tool clutter in the cab.
    I think its a "Rural king special" not a Big gurll unit. ​
  14. May 8, 2020 at 9:38 PM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    Does that require drilling into the bed to secure?
  15. May 8, 2020 at 10:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yes but it’s super simple, also they are self tapping screws.
    Tundra2 likes this.
  16. Nov 14, 2021 at 7:04 PM
    05TRDYT
    05TRDYT New Member
    Nathan
    Hi, do you remember what model you used? Can't seem to find an 05' specific swing case
  17. Nov 14, 2021 at 10:45 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    They don’t make one for the 1st gen. Get one for the 07 and it will work. You will lose that corner tie down though.
    Weagle likes this.
  18. Nov 15, 2021 at 10:01 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Just another idea. I wanted to still use my retrax bed cover. And easy to remove the toolbox with wheels. For those rare times I need the whole bed to carry plywood.
    Bought this Stanley one. Had to modify height but easy. Cut it in half with circular saw and plywood blade. Then it is tapered some. So the top half pushed down and overlapped the bottom by a few inches. So lowered the height. 4 screws and liquid nails to attach. Strong and holds a lot of weight. Can reach in and pull out the handle. To wheel to the back to unload.
    Rodbolt likes this.
  19. Feb 5, 2024 at 2:56 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Which one did you go with? I see it's a swing case, but what truck was it meant for?
  20. Feb 5, 2024 at 3:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    07 Tundra.
  21. Feb 5, 2024 at 6:10 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Thanks. No issues with it interfering with your cap clamps?
  22. Feb 5, 2024 at 6:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes an no. I can't fit a clamp in between so I just added extra ones further up. Scroll up and you can see it in the picture.
  23. Feb 5, 2024 at 6:25 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah I saw that. What about the back?
  24. Feb 5, 2024 at 6:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    There is no room for a clamp back there either. I got like 7 clamps on this thing. It's not going anywhere.
  25. Feb 5, 2024 at 6:41 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Well shit, that's what I was afraid of. So it won't work with my softopper then.
  26. Feb 5, 2024 at 8:13 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  27. Feb 5, 2024 at 8:25 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
  28. Feb 5, 2024 at 8:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
