Tools to loosen the drum brakes via the star adjuster?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, Sep 30, 2021.
  1. Sep 30, 2021 at 9:36 AM
    Jack McCarthy
    Jack McCarthy [OP] Working remotely from the local pub
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I made the mistake of overtightening the rear star adjuster on the right rear drum brake. Now it causes the truck to shake while driving on the highway since its dragging against the drum i assume.
    I had no luck pulling off the drum, so I tried to use a couple of small screwdrivers to back off the rear brake adjustment star, but I can't get to the mechanism that keeps it from loosening. If I can't push that back, the adjustment star won't loosen the drum brake pads.
    Any suggestions? I can't even physically see it to push it if I take a photo. (photo is upside down)
  2. Sep 30, 2021 at 9:41 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Usually you can overcome the starwheel and crank them back with a big screw driver.
    Jack McCarthy[OP] likes this.
  3. Sep 30, 2021 at 9:46 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @Tundra2 knows the trick taught by heather
    Darkness and Jack McCarthy[OP] like this.
  4. Sep 30, 2021 at 9:51 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    I typically use a 90 degree pick to push the adjuster lever forward and use a flathead screwdriver to loosen the star wheel.
    dbittle, 41bigdawg, Darkness and 3 others like this.
  5. Sep 30, 2021 at 9:53 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    I did the same thing a long long time ago - took a piece of wood and a hammer and whacked the drum till it came free. Also make sure your E brake is off.
    Neo, Darkness and Jack McCarthy[OP] like this.
  6. Sep 30, 2021 at 10:30 AM
    Jack McCarthy
    Bill
    North of Boston
    I like this idea. I've got a 90 degree pick I can use as well.
    This will most likely be my backup approach.
    FrenchToasty and Darkness like this.
  7. Sep 30, 2021 at 10:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I believe the FSM also says to use a similar tool. Personally, I had to use two screwdrivers, a phillips head to push the little lever in, then the flathead to turn the star wheel.
    You have to push this forward from that hole.
  8. Sep 30, 2021 at 12:30 PM
    Jack McCarthy
    Bill
    North of Boston
    Strange; I saw this in the FSM. Unfortunately it didn't work for me. I'm not sure why unless I was pushing on the spring.
    FrenchToasty likes this.
  9. Sep 30, 2021 at 12:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It is really awkward to release and took me a LONG time to get it. Have you tried the bolt method on the front of the drum? There is a place a bolt threads in and helps push the drum off.
  10. Sep 30, 2021 at 1:00 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Jack McCarthy[OP] and Diablo675 like this.
  11. Sep 30, 2021 at 3:11 PM
    Jack McCarthy
    Bill
    North of Boston
    What size bolt do I need for that? I saw it, but I was thinking it may drag the shoes off with the drum since it isn't corrosion that I'm trying to overcome.
  12. Sep 30, 2021 at 3:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    M8x1.25
    Most toyota 12mm head bolts are that size if you have some laying around.
  13. Sep 30, 2021 at 4:18 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    It may very well, especially if there is a lip on the outside of the drum. If the shoes are indeed on too tight, it will only make it worse. Seen a few broken spring retainers happen like that.
  14. Oct 1, 2021 at 3:04 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Are you sure you're turning the star wheel the correct way? One side has left hand threads -- I could be wrong, but I think it's the right side.
  15. Oct 1, 2021 at 3:28 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just found thus thread right before I left work. Not sure what's happening or where you are Jack, but here's a video I made when I was figuring it out fir myself.
    Can't recall which way is which off hand. It's in the video though.
    https://youtu.be/1fGZTmzlxWk
  16. Oct 1, 2021 at 5:21 AM
    Jack McCarthy
    Bill
    North of Boston
    Yep, its the same way for both as I was able to tighten and loosen it with the drum off originally. Plus it's easy to tighten but not loosen through the hole in the backplate.
  17. Oct 1, 2021 at 5:28 AM
    tvpierce
    Maine
    That's a great video. And a great tip at 5:00. (paraphrasing his comment) Over-tighten the adjustment so the shoes are centered in the drum and not just dragging in one spot.
    I never thought of doing that.
    tunyota[QUOTED] and Darkness like this.
  18. Oct 1, 2021 at 5:32 AM
    tvpierce
    Maine
    It can't be the same for both. They're mirror images of each other, so the threads have to be left hand on one side and right hand on the other .
  19. Oct 1, 2021 at 5:38 AM
    FrenchToasty
    Mo
    Bone stock
    There are right and left side adjusters, threaded differently so that when you adjust, your clicking the same direction on both sides, which is upwards from the pumpkin side of the plate
  20. Oct 1, 2021 at 5:43 AM
    tvpierce
    Maine
    Ahh. Got it.
    :oops:
  21. Oct 1, 2021 at 5:50 AM
    Jack McCarthy
    Bill
    North of Boston
    Thanks. I couldn't find my pick tool so I only ended up going to home depot to buy a set yesterday. Will try before sundown if I get off early today, otherwise it'll be tomorrow morning.
    Darkness and Tundra2[QUOTED] like this.
  22. Oct 1, 2021 at 5:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. Oct 2, 2021 at 11:00 AM
    Jack McCarthy
    Bill
    North of Boston
    Looks like the FSM picture was correct. Had to push back on the locking mechanism from underneath rather than over the star adjuster. Took some pics for reference.
    Darkness and BubbaW like this.
  24. Oct 2, 2021 at 11:42 AM
    Jack McCarthy
    Bill
    North of Boston
    I think I may have to get the rotors turned for the first time in almost 20 years though. I had to loosen the star adjuster quite a bit to get it past the lip of rust thats built up.
    It also may be the cause of a minor vibration I still feel in the wheel on the highway that randomly goes in and out.
    Darkness likes this.
  25. Oct 2, 2021 at 12:23 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Having my stock drums turned eliminated the slight brake pedal pulsation I had after replacing my front pads, calipers and rotors. My brakes now work/feel better than they ever have since I've owned it.
  26. Nov 1, 2024 at 6:09 PM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    This. Years ago, I was changing pads and rotors on an 88 M5 and couldn't remove the rear rotors. Like a good boy, I had set the parking brake before jacking up the car. The parking brake worked by pressing a set of drum brake shoes against the inside of both rear rotor hubs. I nearly destroyed one of the shoes before I realized what was happening, :anonymous:
    whodatschrome likes this.
  27. Nov 1, 2024 at 6:17 PM
    FrenchToasty
    Mo
    Bone stock
    Deep diggin!
  28. Nov 1, 2024 at 7:26 PM
    Neo
    Neo New Member
    Alabama
    In mid-September, I got an opportunity to walk away from an 08 Lexus LS (that was fast becoming a money pit) and still get some decent cash. I took it. My brother loaned me his 02 AC until I can find a pickup of my own. At his house, it sits under a tree and only gets used occasionally. I needed it to be a solid daily driver plus reliable and comfortable enough to take me 3 hours away on the interstate for an annual event I attend almost every November. The first thing I did was replace the front rotors and pads because of an excessive front shimy. It worked. Since then, I've been at a mad scramble to learn as much as I can to get things dialed in. After seeing the discussion related to this post, I started deep diving on rear drum brakes and the LSVP to see if that's something I ought to dial in as well. Saw the post above and it brought back old memories.
  29. Nov 1, 2024 at 7:28 PM
    FrenchToasty
    Mo
    Bone stock
    What’s the event? A boil? A turkey? A lady?
  30. Nov 1, 2024 at 7:29 PM
    Neo
    Neo New Member
    Alabama
    Annual re-qualification for my state armed security officer license. It's a 2-day event.
