Tools , Which Size Sockets Needed ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Nov 10, 2024.
  1. Nov 10, 2024 at 10:48 AM
    brandostundra
    brandostundra [OP] New Member
    I bought me a Milwaukee 1/2" drive impact recently and now about to purchase some metric impact sockets . On the fence if I need a deep socket set or if a shallow set will do for basic future maint. on the 2016 Tundra.
    Is there any need for the deep sockets on these trucks?
  2. Nov 10, 2024 at 11:22 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What
    What basic maint are you thinking about? Fluids and other routine maintenance?
    Or more like suspension work etc?
    T-Rex266 likes this.
  3. Nov 10, 2024 at 11:23 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I use deep well 7/8" sockets for the lug nuts.
  4. Nov 10, 2024 at 11:54 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Get both Harbor Freight can't be beat for tools like this that aren't used regularly
    Please don't use chrome sockets on an impact
  5. Nov 10, 2024 at 12:38 PM
    brandostundra
    thanks for the replies so far,
    yes I always use a deep socket on the wheel lugs , but just wondering if there are any other areas on the truck that would require a deep socket. I dont plan on any suspension work , maybe rear shackles in the future
    Leo's first likes this.
  6. Nov 10, 2024 at 12:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    IMO... Should have a mix of deep and shallow. With the shrinking of engine bays a mix is not a bad idea. If you can only afford a few bits. 10mm, buy a stack of these. They tend to grow legs and run away. 8, 12 and 14mm, should check the majority of needs. Atleast in my tool box they seem to have the most wear among the rest.
    HulkSmurf14 and Leo's first like this.
  7. Nov 10, 2024 at 12:48 PM
    Leo's first
    Groton ma
    I think they use them on the oil pan drain plug and the filter housing at the stealership :rofl:
    Sound like you got a real nice lug nut changer
    Buy a nice deep lug socket and spend the rest of the money on a torque wench your bound to over tighten the nuts with that beast
    RainMan_PNW likes this.
  8. Nov 10, 2024 at 12:59 PM
    brandostundra
    I do have hundreds of other tools (most SAE) including a torque wrench, I agree on metric 10mm-14mm being used the most used , but just wondering where else a deep socket might be needed .
    I am not going to buy a full set of short and deep as 99% of them might never be used
    blackdemon_tt likes this.
  9. Nov 10, 2024 at 2:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Why buy an impact if you think you only need 1 set of sockets?
    You may as well be better off with an adjustable wrench.
    Jk.
    You should get both shallow and deep chromium -vanadium sockets as well as actual impact sockets.
  10. Nov 10, 2024 at 2:57 PM
    brandostundra
    I have metric chrome sockets and wrenches.
    I have an impact because I have some 60's muscle cars and a car trailer, and use it often because I got rid of my air compressor and air tools , I do have SAE impact sockets.
    As the original post states im looking to buy some metric impact sockets for the tundra,
    and my question was, do I really need deep sockets on anything but the Lug nuts.
    thanks
    pvn.beluga likes this.
  11. Nov 10, 2024 at 3:16 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    I'd go with the the lug as the only deep really needed here. If you happen to run into one, add it to your list for next trip to HF.
  12. Nov 10, 2024 at 8:52 PM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    For regular maintenance items I can't think of any time I've needed a deep impact socket for the Tundra. I think I only own one, a 22mm, which I think I needed years ago for a tacoma suspension swap.
  13. Nov 10, 2024 at 9:06 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's been said already but as cheap as HF is, get you both kinds (shallow & deep). I have a stout set of Pittsburgh deeps that run from 11mm to 24mm and they haven't let me down.
    pvn.beluga and Leo's first like this.
  14. Nov 10, 2024 at 9:16 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Harbor Freight has the Quinn 1/2” master impact set for around $180… pretty good deal for covering all your bases. Unfortunately most of the smaller
    Pittsburgh and Quinn sets skip sizes which gets really annoying when you actually need an 18mm impact socket (GM)
    Really what you want for general use is the M12 ratchets. Thank me later.
  15. Nov 11, 2024 at 12:45 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I think you’ll probably need it for your torque wrench.
  16. Nov 11, 2024 at 3:40 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I have seemingly every tool imaginable and I still mostly use hand tools for everything. The battery impacts are phenomenal but they are unforgiving. Lot of power and good at breaking or stripping rusty fasteners. And just when I think I have everything I find something else I didn’t have and couldn’t live without. Buy quality stuff…then you won’t have to buy twice.
  17. Nov 11, 2024 at 7:04 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Even the quality (name brand) items aren't as good as they once were. Snap-On, Craftsman, etc... I've seen numerous posts in my tool groups on FB where a newer more expensive tool broke and nowadays these companies won't warranty them or they'll drag their feet on a replacement.
  18. Nov 11, 2024 at 9:27 AM
    kevine0001
    kevine0001 New Member
    Kevin
    Even for maintenance, you'll need deep and shallow. Don't cheap out on sockets, they will crack/break. Yes, I have some HF, but I have better ones too. I prefer redundancy, so I carry SAE/metric in 1/4, 3/8 and 1/2. I have carried my 1/2" Dewalt impact on some trips but just easier to carry a cheater bar.
  19. Nov 11, 2024 at 9:28 AM
    kevine0001
    Kevin
    When my wife and I hit antique flea markets or even a garage sale now and then, I'm always on the look out for good/older tools
  20. Nov 11, 2024 at 9:29 AM
    kevine0001
    Kevin
    FWIW, carry a couple extra lug nuts and a couple spare lugs. I've even been known to replace my coils/radiator hoses, and carried the old ones as spares...ask me how I know
  21. Nov 11, 2024 at 9:30 AM
    Leo's first
    Groton ma
    They getting harder to find
    kevine0001[QUOTED] likes this.
  22. Nov 11, 2024 at 9:31 AM
    kevine0001
    Kevin
    Funny, even the swap meets are now charging a lot more than they use to for random sockets, etc. I recently found a lady selling a brand new set of Husky ratcheting box end wrenches. SAE, I think set had 10 wrenches, $20. I grabbed that
  23. Nov 11, 2024 at 11:12 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Get 10mm deep, shallow, 6-pt, 12-pt, and magnetic deep and shallow. You’ll use them all. And lose a few.
