Topper clamp recommendations?
Discussion in 'Tonneau Covers, Caps and Shells' started by OhanaTundra, Feb 19, 2025.
  1. Feb 19, 2025 at 10:05 AM
    OhanaTundra
    OhanaTundra [OP] New Member
    Ohana
    2008 Tundra
    this is what I have right now, but I would like something that goes through the hole.
  2. Feb 19, 2025 at 10:19 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    alll the topper clamps I have ever seen are.....clamps. Similar to what you have.
    If you want to thru-bolt, just drill and put a bolt in that hole with a nut on the bottom.
  3. Feb 19, 2025 at 11:44 AM
    2mchfun
    Not just a bolt and nut, use fender washers too so you're actually fastening to some surface area of the materials. A 3/8" bolt on each corner will get the job done just fine and I would use nuts with a nylon lock ring to prevent unwanted loosening from vibrations. If you use eyebolts, you gain tie down anchors too.
  4. Feb 19, 2025 at 11:49 AM
    OhanaTundra
    Ohana
    2008 Tundra
    So your saying I should just drill a different hole further back in the fiber glass to where I can bolt through the bed?
  5. Feb 19, 2025 at 11:54 AM
    98% of camper shells on the road are held in place by clamps like the one you have. What’s the motivation to use that hole?
  6. Feb 19, 2025 at 11:55 AM
    OhanaTundra
    Ohana
    2008 Tundra
    I just like putting it in the hole.
    lol I just would feel better about it being more secure, but if it’s fine then I’ll leave it.
  7. Feb 19, 2025 at 11:57 AM
    4 clamps is usually sufficient. Some add 2 more for a total of 6, especially on longer bed trucks. Never seen a camper shell blow off or fall off on the freeway. Make sure your gasket, or seal between the shell and bed rail is in good shape.
  8. Feb 19, 2025 at 12:01 PM
    OhanaTundra
    Ohana
    2008 Tundra
    I don’t have a gasket right now.
  9. Feb 19, 2025 at 12:03 PM
  10. Feb 19, 2025 at 12:03 PM
    OhanaTundra
    Ohana
    2008 Tundra
    Why? Water?
  11. Feb 19, 2025 at 12:04 PM
    It's hard to tell from the pic, but it looks like you could use a J bolt to hook the edge of the bed and then use a washer and nut to secure it from the top. Personally, I think the clamps will work fine.
  12. Feb 19, 2025 at 12:04 PM
    Water. Friction. The gasket keeps two harder materials from grinding each other down. Also gives the top some grip when clamped down to prevent shifting.
  13. Feb 19, 2025 at 12:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  14. Feb 19, 2025 at 12:50 PM
  15. Feb 19, 2025 at 1:06 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My 2019 SR5 TRD Offroad + SR5 Upgrade had the rails.
    Yeah, I see he has no rails now. Bummer.
  16. Feb 19, 2025 at 1:30 PM
    I was differentiating between 2nd and 2.5 gen. My 2.5 had the rails as well, but I don't know that any trucks older than 2014 had them.
  17. Feb 19, 2025 at 3:04 PM
    2mchfun
    All I'm really trying to say is that 4 bolts, 4 nylon lock nuts, and 8 fender washers all preferably stainless steel will keep it on there and look good. There won't be no ugly and bulky clamps in the way when your trying to get things done either. The hole location isn't rocket science, just 6-16" from each end should be fine. As said above, weatherstrip should be between the bed rail and the shell rail. 1/4"x 1 1/2" fairly dense foam rubber type will be available at most hardware stores.
  18. Feb 22, 2025 at 8:52 AM
    splicnfiber
    splicnfiber New Member
    Kevin
    OKC
    2003 AC 4.7 2wd SR5
    These are the clamps you're looking for
    GODZILLA likes this.
