Torque converter shudder ???
Discussion in '2nd Gen Tundras (2007-2013)' started by Rex Kramer, Aug 23, 2020.
  1. Aug 23, 2020 at 2:39 PM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    I have experienced this torque converter shudder when driving my 2007.
    TSB: TC018-07 Revised
    My questions:
    How concerned should I be?
    Will this problem get worse? (the truck has almost 300,000 miles).
    Will the TC fail, or will it just keep trucking with the occasional shudder?
  2. Aug 23, 2020 at 3:21 PM
    timsp8
    NY
    Getting any CELs? Figure you would have mentioned it if you were, but there is one for the TC. You might be good until you get a CEL, then know it’ll be on its way out.
    Rex Kramer[OP] likes this.
  3. Aug 23, 2020 at 3:26 PM
    Rex Kramer
    Georgia
    No CEL... not yet.
  4. Aug 23, 2020 at 3:34 PM
    Torque converter shudder can be a few things. If you are going into converter lockup, this can happen. Now if you are already in lockup and get the shudder, different story.
    First check fluid level and condition. I know, easier said than done on Tundras.
    Next you can plan to replace the converter before it fails, causes a complete rebuild.
    Is this the Tundra you use to pull the 5th wheel?
  5. Aug 23, 2020 at 3:40 PM
    Forgot to ask, how are the temps? This is usually caused by heat. When is the last trans service been performed?
    You can warm up the trans and once this happens stop, place in park, then back to drive and apply some fuel with the foot on the brake. If it shudders, new converter time.
    Jtundra81 likes this.
  6. Aug 23, 2020 at 5:37 PM
    Rex Kramer
    Georgia
    I don't tow anything, but it was a farm truck for the first 270,000 miles before I purchased it.
    Temps are fine, it shudders infrequently and only at lower speeds when I let off the throttle. Last drain and fill ATF service was about a month ago... it's had the shudder as long as I've owned it, but I though it was axle wrap or something else.
  7. Aug 23, 2020 at 6:46 PM
    Makes me think the lock up converter isn’t releasing then.
    You can get a remanufactured TC for reasonable. Probably the way I would go before I had a 5100.00 problem.
  8. Aug 23, 2020 at 6:53 PM
    Rex Kramer
    Georgia
    I can't think of a remanufactured TC that I could trust, who would you recommend?
    The best price on a brand new OEM TC that I've found is just under $800
    Rebuilt & Blueprinted: https://www.floridatorqueconverters.com/Toyota-Torque-Converter-89-102.html
  9. Aug 23, 2020 at 7:10 PM
    If you can get an OEM replacement for 800.00, go that route. That’s actually pretty good. I’m used to 1500.00+.
  10. Aug 23, 2020 at 7:59 PM
    Rex Kramer
    Georgia
    $800 is for the TC only, installation is extra, but that can't be too much - right?
  11. Aug 23, 2020 at 8:36 PM
    800.00 + 500.00 installed isn't a bad price.
  12. Aug 24, 2020 at 8:56 AM
    Rex Kramer
    Georgia
    Until I get this sorted out and since the shudder only occurs randomly at lower speeds when I lift off the gas, I have decided to keep the selector in S-4 around town... I will shift into 5 & 6 only when traveling at sustained highway speeds. My MPGs will suffer, but that's better than a catastrophic failure.
  13. Aug 24, 2020 at 9:47 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    You mentioned a drain and fill of ATF about a month ago. Did the shudder start after that service? Was WS ATF used?
  14. Aug 24, 2020 at 11:10 AM
    Rex Kramer
    Georgia
    No, it's been present ever since I purchased the truck 3 years ago - I just thought it was axle wrap, or a bad U-joint or something else. The drain and fill was performed by my local dealer using WS.
  15. Nov 16, 2022 at 11:52 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I'm having this issue and can't afford to fix it
  16. Nov 23, 2022 at 8:02 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
  17. Nov 23, 2022 at 6:37 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
  18. Nov 23, 2022 at 9:11 PM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    Well I don’t think so but I am a mechanic
  19. Nov 23, 2022 at 9:43 PM
    Dr_Al
    Dr_Al New Member
    Al
    How long have you been using it? How many miles? My 2007 has an issue with the internal clutch for the lock up feature. It'll shutter when it locks and unlocks. It's been this way for some time but it would be nice to fix. The 07 and 08 have an issue with this.
  20. Nov 23, 2022 at 11:03 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    I had the same issue on my 07, TC shudder, added this which fixed the issue... eventually my TC went out and I pulled my trans and swapped in a new one, my trac, abs, check eng and 4lo lights came on if I believe. My truck had 235k when the tc went out and then I found out that its apparently an issue on the 07s
  21. Nov 24, 2022 at 12:41 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I guess I have been driving now for 15000km with this
  22. Nov 24, 2022 at 3:43 PM
    Islander
    Islander New Member
    2008 white crewmax
    I had TCS in my 08 CM 4x4. Long story short, put in used trans, new WS oil and had TCS when shifting from 6 to 5. Then in low gear s as well. Asked at trans shop, they said replace TC and new oil and labour came in at close to 2,000. Decided to have trans flushed at toyota due to pan retaining screws corroded (I was told drilled and extracted, tapped would be several hours) anyway didnt do the new screws. Got the truck back, same issue!! No change. I read that tcs was an annoying thing but doesn't harm trans. Kept driving it as I was in dilemma of pay more or put up with it. After 500 miles it suddenly went away!! Learned several things, at least in my case. Flush didn't hurt the trans, lots recmd drain only. Dont take someones word for it use your own judgement as you are the one paying!
  23. Nov 24, 2022 at 8:09 PM
    Dr_Al
    Dr_Al New Member
    Al
    I rarely drive the truck. It's rust free living in snow country so it rarely sees the road when the white stuff flies. It doesn't bother me but I did read where someone said the clutches are slipping and it could cause clutch residue in your transmission. If I replace it I'll do it myself (I have a lift and trans jack) so it's just a bunch of wrench turning. OEM is too expensive but a remanufactured one wouldn't be. I did drop the oil pan to replace the trans filter to see if there was lots of signs of clutch in the pan but it didn't look bad.
