Torque specs
Discussion in '2.5 Gen Tundras (2014-2021)' started by donny.brooke, Mar 11, 2020.
  1. Mar 11, 2020 at 6:44 PM
    donny.brooke
    donny.brooke [OP] New Member
    2024 TRD Offroad dbl cab Lunar Rock
    Just looking at my manual for my 2020 and an only find the 97ft/lbs for the wheels, need the specs for oil pan drain plug, oil filter drain plug, oil filter housing, ubolts, and prop shaft bolts. Anybody have these specs, I used the search function with no luck.
  2. Mar 11, 2020 at 6:55 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Mar 11, 2020 at 7:23 PM
    donny.brooke
    Thanks for the info
  4. Mar 12, 2020 at 3:51 AM
    donny.brooke
    Does anybody know if the oil filter housing tool is the same as a Tacoma, have one of those for the wifes 2019 Tacoma and hoping it will work in my Tundra. Havnt had time to pull the skid plate and check it myself
