Total Chaos uniball conversion 2004-2006
Discussion in '1st Gen Tundras (2000-2006)' started by rrod, Jun 12, 2024.
  1. Jun 12, 2024 at 5:48 PM
    rrod
    rrod [OP] 2005 AC Tundra SR5 4x4
    Rob
    Aluma Series, JBA UCA, Wheelers add a leaf
    So I had been waiting on this kit as I have a 2005 access cab. I would check the TC website periodically to see if the the lbj were out for the later gen 1's. So, to my surprise, they're available!
    My question, I'm terrified of the lower ball joint failure issue. Mine are OEM and about 14k miles on them so far. I just am constantly in butt pucker mode when I'm on the freewY or when I hit a pothole. Do y'all feel these uniball conversions are a safer bet? For $1k I feel like it's worth the price for a more secure option. What do y'all think? They say 30 to 50k miles before recommended replacement of the uniball. The price of about $200 for the replacement is not too bad.
    Curious to hear what y'all think on the matter.
  2. Jun 12, 2024 at 6:28 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    I think you're worrying over nothing. You only have 14K on OEM LBJs. They're as solid as you're going to get. If you said 114K, I would advise to replace. With OEM. I don't think the cost of admission and continual replacement every 30K is worth it unless you're constantly out beating the shit out of your truck off-road. An occasional pothole hit is going to be OK with OEM LBJs. But hey, if spending $1K gives you peace of mind, have at it.
  3. Jun 12, 2024 at 6:58 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think you’re way over worrying
    rrod[OP], Weagle and whodatschrome like this.
  4. Jun 12, 2024 at 7:03 PM
    x3
    rrod[OP], Weagle and jerryallday like this.
  5. Jun 12, 2024 at 9:47 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    x4
    rrod[OP] and Weagle like this.
  6. Jun 12, 2024 at 10:16 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    I'll buy your OEM 14k LBJ's as spares.
    whodatschrome and Weagle like this.
  7. Jun 13, 2024 at 10:19 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    There is just more maintenance with uni balls.
    At 14k you SHOULD be fine as long as you're not beating the fuck outta your truck.
    rrod[QUOTED][OP], ATBAV8 and Weagle like this.
  8. Jun 13, 2024 at 10:37 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    +5.
    I got almost 300,000 miles out of my originals and they still tested OK. But if I had been aware of the issues with them I would have replaced them 150,000 miles ago. Maybe sooner if it was used off-road a lot
    Point being OEM are solid as a rock and you can ride comfortably for 100,000 miles or more
    rrod[OP] likes this.
  9. Jun 14, 2024 at 7:08 AM
    rrod
    Rob
    I appreciate y'alls feedback! I can be a bit obsessive and all those doggone videos of FGT's driving down the road with wheels falling off , have me in paranoia mode. To add to the situation, I bought these LBJ's on eBay- but before I get slammed- the vendor is one of the top rated JDM vendors and he's in Japan- his feedback is impeccable. When they arrived they had all the marking of having made the long journey from Japan. Had I to do it today, I would have purchased from the dealer or the Joker, at the time I saw his credentials and thought they were likely legit.
    The World has always been rough but with social media and all the counterfeiting going on, it has become exponentialy so, to add to it; my entry into "old manhood" and you got a recipe for worry. Anyhoo, I appreciate y'all and I guess I need to adopt the attitude of- do all you can but at the end of the day, "it's gonna be what its gonna be".
