Touch key to start button
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Dec 30, 2023.
  1. Dec 30, 2023 at 8:07 AM
    WasAChevy
    WasAChevy [OP] New Member
    2022 1794 4x4
    Had not started my truck in about two weeks and it gave a message to touch the key to the start button first. After that it has been fine as usual.
    Any ideas?
    Thanks
  2. Dec 30, 2023 at 8:12 AM
    DRP
    DRP Old Member
    Dave
    Was the FOB asleep?
  3. Dec 30, 2023 at 8:27 AM
    WasAChevy
    I have no clue...how do you tell if the fob is asleep?
  4. Dec 30, 2023 at 9:06 AM
    DRP
    DRP Old Member
    Dave
    I'd have to look in the manual. I know there was something in there on how to do it.
  5. Dec 30, 2023 at 10:46 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    There's been a few threads on this issue. A common denominator is this often happens when you use the phone app to unlock the truck. Is that what you did?
    There's also a FOB health check in the app that you should check out.
  6. Dec 30, 2023 at 10:50 AM
    WasAChevy
    Negative, I really don't use the app at all. Just looked at the health check you mention and it states that all is good.
  7. Dec 30, 2023 at 10:54 AM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Had this happen once in the last 3 months since purchase. The only thing out of the ordinary was wife stayed in truck while I went in the store. She locked when I left and unlocked when I returned. I have no idea if that caused the problem tho.
  8. Dec 30, 2023 at 11:00 AM
    Matt2015Tundra
    2023 1794 CrewMax
    It definitely seems related to locking/unlocking the doors, but I haven't seen a definitive answer, yet.
    I've also read that when you get this message, if you use the FOB to lock/unlock the doors, the message will go away and the truck will start without touching the FOB to the start button. I've never had this problem, so I can't confirm.
  9. Dec 30, 2023 at 11:05 AM
    WasAChevy
    None of those scenarios apply. The only thing different was that my truck had not been driven for a couple weeks. Maybe it defaulted into some security mode????
  10. Dec 30, 2023 at 7:50 PM
    Csteppe
    Csteppe New Member
    Chip
    It’s an ongoing issue with my truck. I’ve been to the dealership now twice with a battery replaced and then an update on software. They said it was fixed but it did it twice Friday. I will be going back to the dealership again and this is now the new remote that is doing it. I keep video’s of it as well, so I can make sure they know it’s happening.
  11. Dec 30, 2023 at 7:56 PM
    Hella Krusty
    Hella Krusty New Member
    My truck sat a month last winter when I was in the Cayman Islands and it fired right up upon return. In short order it will be sitting for February
  12. Dec 30, 2023 at 8:10 PM
    WasAChevy
    Thanks for the info. When you say battery, cranking battery or the fob battery? Ive driven it about 10 or so drive cycles since and it hasn't done it again.
  13. Dec 31, 2023 at 6:02 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    This happened to me once and it was the same situation where I had the wife locked in the truck but I had the fob. Also after the big android update I had to enter my pin number right after and only once.
  14. Dec 31, 2023 at 6:23 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    If a passenger locks truck from inside when driver leaves vehicle it will require a key press to button everytime to start. Security feature but very annoying
  15. Dec 31, 2023 at 9:37 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    Historically Toyota push button start system uses several oscillators (in outside door handles and a couple in the interior) that emit very short range RF pulses every couple seconds (can be heard with an old school little AM radio tuned off of a station held up to one of the oscillators) the system then "listens" for a response from an in range fob with the correct rolling code. My understanding of the system is after several days this pulse goes from every couple seconds to every 8-10 seconds and after more time elapsed less than that to eventually not signalling at all for reducing vehicle battery state of charge depletion while vehicle is not being used for a period of time.
    The other way around is if the fob is left inside vehicle continuously or for long periods of time it will eventually stop responding to the vehicle as well to help preserve its little internal lithium battery. The "hold the fob up to the start button " is the fail safe system used if the battery in the fob was dead or whatever just like the conventional key start systems utilizing immobilizer NFC chips in the keys.
  16. Dec 31, 2023 at 11:17 AM
    WasAChevy
    Makes complete sense. Key fob battery was recently changed within the last couple months. With that said, I did notice while driving, until recently, that the message stated "battery charging" while stopped instead of the ole push harder message. The info you provided, very plausible. Thanks
  17. Dec 31, 2023 at 11:38 AM
    Matt2015Tundra
    2023 1794 CrewMax
    This is good to know. I live in the boonies and always leave my FOB in the truck when it's parked in my garage. It will often sit for a week or so without being driven. It sounds like I should start bringing the FOB inside with me.
  18. Dec 31, 2023 at 6:42 PM
    Csteppe
    Csteppe New Member
    Chip
    Yeah so they replaced the fob battery.
    Didn’t make a difference on the original fob.
  19. Dec 31, 2023 at 8:29 PM
    ScootARoot
    ScootARoot New Member
    TJ - aka Dada
    Georgia
    2024 Limited OR - Smoked Mesquite
    Mine did this the other day. I locked my doors via the Toyota app, then started it from there as well to warm up before jumping in. We get in and I need to touch the FOB to the start button to start the truck.
    Did the exact thing several days before this, and started up like normal. Just hop in and start back up just by pressing the button. Truck is maybe 2 months old
