Tow/haul
Discussion in 'Towing & Hauling' started by MikeS., Jan 23, 2014.
  1. Jan 23, 2014 at 6:57 AM
    MikeS.
    MikeS. [OP] New Member
    Far Eastern WVa
    2010 SR5 Tundra TRD off road pkg.
    I bought this on 1/12/14 and have added a code alarm remote start, an Alpine head unit with Nav and a backup camera.
    Ok I traded in my 2008 Tacoma which I dearly loved for a 2010 4WD 5.7L Tundra SR5 TRD off road with tow pkg. I have a 1963 4wd Chevy Suburban I've been restoring. The Tacoma wasn't upto hauling it and a dbl axle trailer. The Tundra will like a champ.
    So there's this tow haul button on the dash, I've read the owners manual and all it says is to use when towing or hauling a load. Gee Really?
    What I'd like to know is, what does it actually do? Change shift points, no overdrive, give 500 extra HP or what?
    Thanks
  2. Jan 23, 2014 at 8:14 AM
    T-Rex266 SpaceX Director Staff Member
    I believe it just keeps the gears lower before shifting
    JROCK915 likes this.
  3. Jan 23, 2014 at 9:16 AM
    Supermoto
    Supermoto New Member
    Fallbrook, CA
    2002 Tundra
    Everything
    Biggest thing it does is change shift points. It holds in gears longer, really helps to keep the tranny temps down. I always used it when towing. Also its really great going down grades, when you even just tap the brake it kicks down a gear. Just always make sure to use a good trailer brake controller.
  4. Jan 23, 2014 at 10:54 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    Congrats man! I did the same thing, traded my 08 taco for a 10 tundra TRD O/R, I love it!
    erm626 likes this.
  5. Dec 15, 2014 at 6:09 PM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    I traded in a 2008 Nissan frountier for a 2014 tundra TRD with tow package 5.7
    T-Rex266 likes this.
  6. Mar 23, 2015 at 10:18 AM
    jonsylvia
    jonsylvia Gone camping
    Jon
    Turlock California
    2015 Tundra
    Running boards Air bags 2.5" front leveling kit Towing mirrors TRD rear sway bar
    I traded a 2012 Tacoma in on a 2015 Tundra. I plan on putting a slide in camper and hauling my boat.
    Tried the tow/haul on the boat and it does change shift points and the down shift is great. I really don't need it just for the boat but had to try it out.
    It also changes throttle response. It is a lot quicker to respond to your foot.
  7. Mar 25, 2015 at 1:26 AM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    If it is like the 1st Gen Tundras, it also locks out OD. Though only being a 4-speed auto the button is simply labeled to turn OD on or Off. Not sure if it does that also on the newer ones. 1st Gen trannies are not happy towing big loads in OD (Toyota bought me a new tranny at 35k). Haven't towed without pushing the OD Off button since and she is still happy at 120+k.
  8. Apr 1, 2015 at 5:04 PM
    jonsylvia
    Jon
    Turlock California
    2015 Tundra
    It doesn't turn off OD any more it used all gears in tow mode with boat in tow. We are on flat land and it will hopefully drop out of OD when we tow in the hills.
    This 2016 has six speeds and the last two are both OD's.
  9. Apr 1, 2015 at 6:02 PM
    Pretty sure all 2nd, and 3rd gens are 6 speed. I know my 2nd gen was, and my 3rd gen is....both were the 5.7, so idk if that makes a difference when compared to the smaller engines.
  10. Apr 2, 2015 at 5:07 PM
    jonsylvia
    Jon
    Turlock California
    2015 Tundra
    Mine is the 5.7. If you pull up the transmission gear ration 5&6 are both overdriven. They make up for it by using 4.30 to 1 rearend gears. Plus the 400 ft pounds of torque doesn't hurt.
  11. Apr 4, 2015 at 3:40 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    I used mine; hauling a full 6×14 trailer, full bed, and full cab. All the way from FL to CA., 3300 miles in 2 days! Never knew I had any extra weight.
    I'm a 2nd gen., 4.7, rwd.
  12. Sep 25, 2016 at 3:29 PM
    Nodlenor
    Nodlenor New Member
    Ronald
    2010 Black Tundra TRD SR5
    I traded my 1999 Tacoma for a 2010 Tundra so I could pull my 22 1/2 ft. camper. I like my Tundra but I sure wish I could have kept my Tacoma also. The Tundra pulls my camper without any problems, I'm just not used to it yet. It has tow/haul but I didn't know how to use it. I will try it out the next time I go camping. This forum is helping me get to know my Tundra, Thanks guys!
  13. Sep 25, 2016 at 11:58 PM
    Rkcruza
    Rkcruza New Member
    Bob
    Not sure about the newer Tundras, but most vehicles (regardless of make) suggest not towing any real loads in OD as the gear itself is not all that strong. Tow in OD you risk blowing up the tranny . I know with my 4.7 which has a single over drive, I get the same or better mileage towing in the 1:1 gear than I do towing in OD. Not sure which gear that would be in the new Tundras in mine, 4th is OD so regular towing is in 3rd. With my new Taco which is a 5 speed auto, 4th is 1:1 and 5th is OD. I believe 4th is 1:1 in the new Tundras with the 6 speed.
  14. Sep 26, 2016 at 12:11 AM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    I was going to trade my 05 Tacoma in on my Tundra but the wife said no way in hell are gonna get rid of the Tacoma!.....third world problems.
    NewImprovedRon likes this.
  15. Sep 26, 2016 at 5:39 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Welcome from CO. Came from a 09 Taco. That 63 Suburban has got to be pretty cool.
  16. Jan 19, 2017 at 12:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  17. Jan 19, 2017 at 12:24 PM
    csuviper
    Broomfield, CO
    Tow Haul Mode:
    1. Holds lower gears longer
    2. Increases throttle response
    3. Increases pulling power
    4. Increases engine braking
    NewImprovedRon and ColoradoTJ like this.
