Tow Mirror Install
Discussion in '3rd Gen Tundras (2022+)' started by danolschewskijr87, Mar 27, 2024.
  1. Mar 27, 2024 at 9:21 PM
    danolschewskijr87
    danolschewskijr87 [OP] New Member
    Daniel
    I have a 2023 Toyota Tundra SR5 that I added tow mirrors to, but the blinker and/or marker light on the back of the mirrors anrnt illuminating. Does anyone know if you can reprogram something to enable that light feature, like you can on a ford, through forscan.
    wing-2 likes this.
  2. Mar 28, 2024 at 12:31 AM
    wing-2
    wing-2 New Member
    Following. Did you you do this yourself? My SR5 needs tow mirrors.
  3. Mar 28, 2024 at 1:26 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Did you wire the factory buttons to it as well? If you don't use both buttons they won't work properly
  4. Mar 28, 2024 at 4:51 AM
    danolschewskijr87
    Daniel
    Yes, I installed them
  5. Mar 28, 2024 at 4:51 AM
    danolschewskijr87
    Daniel
    How do I wire the buttons
  6. Mar 28, 2024 at 12:12 PM
    danolschewskijr87
    Daniel
    Is this the only way
    ryanwgregg likes this.
  7. Mar 28, 2024 at 12:22 PM
    danolschewskijr87
    Daniel
    What if I just wanted the marker lights on the back
  8. Mar 28, 2024 at 3:28 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Find the wire that powers the marker lights. Pull power directly from the running lights wires under the hood. Might be more splicing then you want but it'll do it.
    RobertD likes this.
  9. Mar 28, 2024 at 5:40 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    What good would they be unable to extend? And leaving them extended would be a disaster. Can you share a pic please? I’d like to see them. Thx
  10. Mar 28, 2024 at 6:04 PM
    danolschewskijr87
    Daniel
    Here are a couple pictures
    Releake3 likes this.
  11. Mar 28, 2024 at 6:28 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    And does every other function work except the marker lights?
  12. Mar 28, 2024 at 7:24 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    When I was installing the auto start/stop disable I saw the wiring harness for the tow mirror buttons. I wonder if the limiteds are pre wired for the tow mirrors in the doors too? I like the tow mirrors, but they are crazy expensive.
  13. Mar 28, 2024 at 8:40 PM
    danolschewskijr87
    Daniel
    No, with this being an SR5 and coming originally with the smaller mirrors, it doesn’t have any buttons for the mirrors. The only thing I’m interested in is having the marker lights on the back and blinkers
  14. Mar 29, 2024 at 5:18 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I think what he’s asking about is the wiring, not the buttons. All of the buttons on the panel most certainly do have pre-wiring but the big question is where does it terminate.
  15. Mar 29, 2024 at 6:30 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    These mirrors are great to have the BSM are key & the side lights when backing up really light up your surroundings, this is definitely well worth cash for an add on when purchasing the 3rd gen.
    Good luck hooking up your mirrors you'll be glad you made the decision to get them and even happier once you get them done.
  16. Mar 29, 2024 at 6:49 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Does anyone know the ‘code’ for tow mirrors? E.g. WS = heated steering wheel.
    Are they always packaged with BSM?
    It’s not filter able in the allocation sheet.
  17. Mar 29, 2024 at 6:58 AM
    Blufin
    Bob
    23 Capstone
    This is on there build page nothing about SKU#.
  18. Mar 29, 2024 at 7:06 AM
    MaineTundy
    Thanks. Almost as hard to figure out as catching a 100”er. ;-)
    Blufin[QUOTED] likes this.
  19. Mar 29, 2024 at 7:18 AM
    Blufin
    Bob
    23 Capstone
    Good hunting man:thumbsup:
    MaineTundy[QUOTED] likes this.
  20. Mar 29, 2024 at 12:26 PM
    PNW Tundra Mike
    Southern Cal
    Big harness for those mirrors. 10 or more functions. Curious if all the extra wiring is even in a standard Limited & above with the usual remote, memory, fold, defrost, turn sig, BSM?
  21. Jun 24, 2024 at 7:39 PM
    Releake3
    Releake3 New Member
    Robert
    2023 Toyota Tundra Limited
    Trd lift w/ 35 bfg KO2, ARE bed cap
    Maybe I missed it, what tow mirrors are they? They do not have the pvm camera, did Toyota make a set without it? If they are factory, what are the part numbers for them? I just purchased a set if the ECCPP Tow mirrors for my 23 Limited Tundra, not liking the manual fold. They look like factory minus the camera, electric fold or electric extend.
  22. Jul 4, 2024 at 5:40 PM
    Belan52
    Belan52 New Member
    Nathan
    2024 Toyota tundra sr5 8ft bed
    Toyo tires, black rhino rims, Tint, trigger industries mud flaps, tork lift truck camper mounts, air bags
    Did those mirrors plug right in what functions the reverse lights and the signals I wanted a set but not sure if they will work for that I don’t mind the manual extend and fold
  23. Nov 25, 2024 at 12:06 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    In Case anyone has any questions about towing mirrors.
