Tow Sag
Discussion in 'Towing & Hauling' started by FisherMan1, Oct 17, 2024.
  1. Oct 17, 2024 at 10:00 PM
    FisherMan1
    FisherMan1 [OP] New Member
    2024 Tundra Limited TRD Package
    First thing, I haven’t hooked up to my Ranger Z520c yet. I have read and seen complaints about rear sag when towing. I’m trying to understand the difference in all package suspensions and systems. Am I correct in that the TRD package does not have the air suspension system? I noticed on a different thread a comment was made that these new suspension systems were supreme to aftermarket. Can someone advise the different package level suspensions and if my Limited TRD will sag when towing my boat?
  2. Oct 17, 2024 at 10:51 PM
    I would first hook to the boat and see if it is a problem.
  3. Oct 17, 2024 at 10:51 PM
    GODZILLA Introverted Troglodyte
    Wyoming
    2024 Ferd F150 XLT, 2019 Super Tenere
    Trying not to mod it
    There's going to be a certain amount of sag when towing. That's why most trucks come with rake from the factory. Quick bit of google shows that boat weighs less than 2000 lbs. I wouldn't worry to hard about it at that light of a weight, unless there is some reason your trailer has a huge tongue weight bias.
  4. Oct 18, 2024 at 4:45 AM
    FisherMan1
    You are somewhat correct. The boat weighs 1850 dry. The mercury 250 weighs about 500-550. By the time you add in the Ultrex TM, two PP blades, batteries, oil, gas, loads of gear, and the trailer weight, it’s approximately 4500.
    I guess knowing the rear suspension set up would be an indicator. I’ve seen many sagging tow set ups online/youtube, but none were the TRD package.
  5. Oct 18, 2024 at 4:45 AM
    FisherMan1
    Clear cut answer. You are correct and that will happen next week.
  6. Oct 18, 2024 at 4:46 AM
    Wyoming
    You need to clarify "TRD Package" too. TRD Sport or TRD Off Road? Or do you mean TRD Performance package?
  7. Oct 18, 2024 at 4:57 AM
    FisherMan1
    Yikes. Thanks for the reminder. It’s a TRD Off Road package in the Limited line.
    GODZILLA[QUOTED] likes this.
  8. Oct 18, 2024 at 5:16 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    OP
    I don't think you will sag much on your Ranger. I have the Pro which is even softer than TRD OR and it doesn't sag on our Ranger. Even when I tow our center console boat, it is minimal sagging. There's another thread on Sumo Springs which will help sag for heavy loads. Its the nature of coil springs vs leaf springs, give and takes.
    FisherMan1[OP] likes this.
  9. Oct 18, 2024 at 5:16 AM
    Wyoming
    Off Road is usually a little squishier for towing, though I don't know how much it applies to the new gen. They've got a completely new rear suspension, so it might not be as much of a difference when towing.
  10. Oct 18, 2024 at 8:25 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2022 Limited Crewmax 6.5 Bed
    Lots of stuff!
    We have the TRD offroad suspension and it does sag about 1.5 to 2 inches with our 500 lbs tongue weight from our 4,200 lbs trailer. I put a 1.75" levelling kit in so it makes the sag look worse. I also use a WDH to move some weight to the front axle and take some sway out of the experience. Once you connect to the trailer you will be able to determine if it works or not.
  11. Oct 18, 2024 at 9:55 AM
    GAMark
    GAMark New Member
  12. Oct 18, 2024 at 10:06 AM
    FisherMan1
    Cool video. I think I understand weight distribution…just curious about others experience with the limited TRD OR towing a boat.
