Towing 38' trailer at 8600 lbs+fuel/water/people
Discussion in 'Towing & Hauling' started by BC.Austex, Sep 24, 2019.
  1. Sep 24, 2019 at 8:08 PM
    BC.Austex
    BC.Austex [OP] New Member
    2014 Tundra Limited - Texas Edition
    I have a 2014 CrewMax, tow capacity 10k. Looking at Springdale 38 BH trailer, loaded will be 9500 lbs. While this is our first travel trailer, at 95% capacity, I'm concerned this is pushing too close to max weight? What do I need to be aware of?
  2. Sep 24, 2019 at 8:20 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    That’s a lot of weight dude. I tow around 8000 and it pushes the truck around a bit. You would usually want to leave a larger buffer but you should be ok as long as you take it slow and leave space for stopping. Also maybe use an aftermarket brake controller as the tundra integrated one is weak.
  3. Sep 24, 2019 at 8:25 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    No way. Bigger truck or smaller trailer. That's what will happen.
  4. Sep 25, 2019 at 7:41 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Trailer TOOOOOOOOOOOOOOOOOOOOOOO BIGGGGGGGGGGGGGG !
  5. Sep 25, 2019 at 8:49 AM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Too much trailer, I wouldn't do it.
  6. Sep 25, 2019 at 8:55 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    That's too big in my opinion. Even if youre in limits, it will not be an enjoyable experience towing it at all. It will be an absolutely stressful chore. Small items will add up your weight fast, and you will be over without even knowing it. Trailers are rated with not a damn thing in it. (Chairs, tables, dishes, food, ice chest, propane, sewage, tools, kids bring a friend/ toys, etc.)
    GODZILLA, Tundyfundy and Bulldogz71 like this.
  7. Sep 25, 2019 at 8:56 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Compare your loaded tongue weight + all cargo / passengers in your truck against the truck’s payload capacity.
  8. Sep 25, 2019 at 9:00 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I live fulltime in our 30FT TT. Total weight is 9,300LBS. We tow about 20 miles a day, every day. We are properly weighted. A 12K weight distribution hitch, 2 sway brakes and the stock brake controller.
    We feel very confident with towing behind the Tundra.
    We have also added sumosprings and a custom leaf pack.
    eccracer104, Mike59, DiegoC and 5 others like this.
  9. Sep 25, 2019 at 9:06 AM
    sbxx312
    sbxx312 New Member
    This is right on.
    The reason we got the Tundra last year was to avoid the stressful towing. I towed our current trailer with my Tacoma for six years and by the end, my wife and I were done. I started working her for a Tundra year five and after a scary mountain tow, she gave in on the way home.
    I don't know your experience towing, but 38ft is a huge first trailer. If I had to tow a trailer that big now, I'd go back to tent camping.
  10. Sep 25, 2019 at 9:07 AM
    Bulldogz71
    Bulldogz71 New Member
    Clayton
    2018 Tundra CrewMax 4x4
    TRD Pro conversion in progress. Replaced every bulb on truck with LED. Ranch Hand brush guard.
    Have no doubt the truck would pull it. Heck it would probably “pull” 14k#, stopping it and the feeling of it pushing you around would be very uneasy. But That’s too close for comfort for me so you wouldn’t catch me doing it. Would be diff if it was a one time move or 1-2 a year move.
    Tundyfundy likes this.
  11. Sep 25, 2019 at 9:11 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I think it’s just fine. I’ve towed heavy and long too with absolutely no problems. Sounds like you know your stuff with balance and tongue weight. You’ll do great.
    17inferno and snivilous like this.
  12. Sep 25, 2019 at 9:14 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I towed my racecar around a bunch when my Tundra was pretty much stock with a brake controller. Trailer weighed 9000+ lbs. It'd cruise at 80mph fine, and did a few 500-2000 mile trips without issue. You can tow that weight totally fine, I'd be concerned with the length and getting pushed around by wind or other big vehicles disturbing the air and moving it around. If you're smart about driving and not hauling ass I bet you'd be fine.
  13. Sep 25, 2019 at 9:20 AM
    sbxx312
    sbxx312 New Member
    I think there's a difference between whether the Tundra could pull it and whether it's smart to max it out for your first travel trailer.
    Maybe he's headed to the local KOA or living in it. That's different than a road trip out west.
    Mike59 and Tundyfundy like this.
  14. Sep 25, 2019 at 9:42 AM
    Mwray8909
    Chino Valley
    I will say I would never go bigger that what we currently have.
  15. Sep 28, 2019 at 2:59 PM
    That sure is a lot of trailer behind you.
    I would rent the biggest trailer you can for a trip out and see what you think.
    I wish someone would have given me this advice 5 years ago.
    Chucho, HappyGilmore, Casper3 and 2 others like this.
  16. Sep 28, 2019 at 3:06 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    To much trailer IMO, you need to move up to a 3/4ton if your actually going to go on trips with it or a smaller trailer. If your only pulling local then it probably wont matter much.
    Casper3 likes this.
  17. Sep 28, 2019 at 3:20 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Too much. The length of the trailer alone will not be friendly to a half ton truck. IMHO, anything bigger than 33’ is 3/4 ton of bigger territory to tow it safely in any condition.
  18. Sep 28, 2019 at 3:48 PM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I had a 10,000lb 36’ travel trailer...and I used a 6.7L Powerstroke. Just because you can doesn’t mean you should...
  19. Sep 28, 2019 at 6:38 PM
    Jmad1997
    Jmad1997 New Member
    I’m gonna try this! I’ve been wanting a trailer but don’t know where to start lol.
  20. Sep 28, 2019 at 7:01 PM
    I wish this was the route we went.
    This 28’ camper that was within the limits of my CM, upper limits, was a hard pull in CO & NM.
    This is even more heavy than the camper.
    The decision was made to go larger in truck. If I only would have purchased the smaller 23-24’ TT, I wouldn’t have had to spend the money on a new truck.
    GODZILLA and Jmad1997[QUOTED] like this.
  21. Sep 28, 2019 at 7:02 PM
    Jmad1997
    Jmad1997 New Member
    That’s a lot of trailer for sure! I want to start out with something smaller for sure to get used to it.
  22. Sep 28, 2019 at 7:14 PM
    It can be with wind and other weather elements. Research a thread “tough towing this go around” or something like that.
    Just imagine another 10’ on top of this camper pictured.
    Jmad1997[QUOTED] likes this.
  23. Sep 28, 2019 at 9:07 PM
    Ericsopa
    Ericsopa Old man and the sea
    By the owners' manual, my '13 CM Limited with tow pkg and nothing else extra, has a max tow wt of 9300#. I think you're pushing it to close, especially since this is your first TT.. Don't know where you plan to tow, but I've pulled 53' trailers driving 18 wheelers, and the winds in the west (CO front range) can be ferocious, and the grades unforgiving if you're not careful. That 38 footer behind your half ton is like a huge sail back there. You're gonna feel it big time.
    I also question your 9500# loaded weight. The specs on the trailer say 8750# dry weight, 56 gal fresh water tank, 60 gal propane tank. Fill those two up and your already at 9450# and nothing else in the trailer yet.
    ColoradoTJ and Tundyfundy like this.
  24. Oct 31, 2021 at 12:59 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    My wife and I have been trailer shopping and today came across EXACTLY what we want, but think it is too big. It's the Wolfpack 27PACK10. Dry weight is 7988, and 33' total length.
  25. Oct 31, 2021 at 1:14 PM
    Retired...finally
    That's the way a properly set up combo should look. Did you set up the WDH yourself?
  26. Oct 31, 2021 at 2:12 PM
    Yes I did. My Equalizer was maxed out. I rode rather rough and if you look closely, the back was still sagging a little bit. I should have just went up in bar size to the 1200/12000 lb ones and had minimal adjustment.
  27. Nov 1, 2021 at 8:35 PM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    Mine is 31' 7500 pounds dry.Truck pulls it pretty good but I would have gone a little smaller.Wife fell in love with it so it was over.FYI she wanted bigger but I had to be realistic with the tow vehicle.Very happy with my Tundra 2017 SR5 2wd crew max.IMG_3722.jpg
  28. Nov 1, 2021 at 8:36 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Air bags and stock tow mirrors added after this picture
  29. Nov 1, 2021 at 8:39 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I agree that's too big for a halfton, even one with more payload and a higher towing capacity than the Tundra. Either a smaller trailer or a 3500 is in your future.
  30. Nov 2, 2021 at 3:20 AM
    Retired...finally
    My wife wanted a larger trailer until she found one she really like and thank goodness it was only 23' and 6080 GVWR.
    Cpl_Punishment and Mike59 like this.
