Towing U-Haul 5x8 trailer from CA to TX , any tips ?
Discussion in 'Towing & Hauling' started by kid84, Nov 9, 2022.
  1. Nov 9, 2022 at 10:35 AM
    kid84
    kid84 [OP] New Member
    2019 Tundra 4x4 TSS
    Need to drive my truck with 5x8 Uhaul trailer from Sacramento to Houston , any tips and recomendation ? My truck is 2019 TSS RWD 5.7 stock . What is max load with 5x8 Uhaul trailer ? Only me driving .
    Should I take I-40 or I-10 ?
    Thank y'all pro owner Tundra here
  2. Nov 9, 2022 at 11:26 AM
    If you’re taking I40, Check weather for Flagstaff. Always snows on me there. The 5x8 should pull fine regardless of what you put in there. I towed a 6x12 tandem axle Uhaul loaded down with my FGT with no issues.
    bulldog93 likes this.
  3. Nov 9, 2022 at 11:47 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    For a more scenic drive I'd take 40, for the faster more fuel efficient route I'd take 10. The towing part should be a breeze with the Tundra, tow/haul mode and have at it.
    On a side note, I-10 passes right thru the city I live in so hit me up if you need. Fuel break or food break in New Mexico!
  4. Nov 9, 2022 at 11:52 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    The older U-Haul trailers had some kinda brake that would prevent it from being backed up an incline. Don’t know about the newer trailers.
    I tow both a 28 ft & a 32 ft gooseneck trailer (loaded down with fencing supplies or hay bales) in my pastures, on gravel roads, & on pavement a couple of times a week. Yes, the truck is lifted & it has airbags. I have zero problems towing & I’ll admit sometimes I think my trailers are overloaded but time is not always on my side.
    I pay attention to the weather, load my trailers correctly, check my side mirrors often, & watch out for all the other idiots in the road. The hard part for me is I sometimes get comfortable & complacent on the longer trips.
    Luckydog and bulldog93 like this.
  5. Nov 9, 2022 at 12:27 PM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    We're actually working our way back east from California right now. We're towing a 17' Casita camper and elected to take i10 to avoid any possible snow. We're currently in Twentynine Palms right outside Joshua Tree, next week we'll be in Las Cruces to visit White Sands before arriving in Dallas for Thanksgiving.
    You shouldn't have any issues with a 5x8 trailer, we tow in Tow/Haul mode and S4.
    bulldog93 and KNABORES like this.
  6. Nov 9, 2022 at 1:01 PM
    Retired...finally
    I tow my 5 meter boat weighing 1,200# including trailer in drive and go like the dickens.
    bulldog93 and Mike59 like this.
  7. Nov 9, 2022 at 1:19 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    Your NM stop is in my hometown. Feel free to PM me for any and all info about Las Cruces or White Sands! If you want of course ...
    twotrack[QUOTED] and bulldog93 like this.
  8. Nov 9, 2022 at 4:09 PM
    snoope
    snoope The Old Man
    That Tundra should pull that trailer with no problems..:thumbsup:
    I towed exact same size trailer from U-Haul behind my '02 Tacoma 4x4, 4 cylinder automatic from NH to Florida without an incident , except when I left Mother Nature gave me a Surprise ... 82911316_10206678018666488_1568575150884913152_n sno tacoma.jpg
    I had to stick the loaded trailer in the garage over night so the plows wouldn't hit me o_Oo_O
  9. Nov 9, 2022 at 10:30 PM
    Blue By U
    Blue By U New Member
    Don't stop for fuel in Needles! 15 more miles will be worth it.
    bulldog93, KNABORES and Bprose like this.
  10. Nov 9, 2022 at 11:22 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Those trailers have inertia brakes on them and can be finicky. When I moved fro Iowa to Arizona I used one and I soaked the brake mechanism on the tongue with WD40 and some lube and it worked much better. Those trailers are heavy for no bigger than they are.
    ColoradoTJ likes this.
  11. Nov 10, 2022 at 3:12 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    A 5x8 should tow like a dream. You should be fine driving in 6th. Just watch the grades and if you find the trans downshifting or the converter unlocking a lot, grab 5th.
    I have towed a 5x8 many times. Expect about 12 mpg.
  12. Nov 10, 2022 at 4:50 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm pretty sure my dad has towed a 5x8 with his Suzuki Grand Vitara. You'll be fine.
  13. Nov 10, 2022 at 5:15 AM
    IowaGuy
    IowaGuy New Member
    In Process
    Oh, and don't trust the tires and check them quite often. People abuse those things and run over stuff all the time.
  14. Nov 10, 2022 at 5:22 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    Load the trailer properly, meaning you need to have weight on the tongue or it'll fishtail. When driving a long vehicle or pulling a trailer you need to "drive with the back" watch your mirrors and pay attention to where the trailer tires are in the lane. A typical uhaul 5x8 cargo trailer doesn't have trailer brakes, not a problem just be aware of your loaded braking performance. A typical uhaul 6x12 cargo trailer does have hydraulic surge brakes. Your truck will tow any uhaul trailer available at max trailer capacity. If you think you may be near the capacity of the 5x8 trailer consider just getting the 6x12, a larger trailer will tow easier than a smaller trailer.
  15. Nov 10, 2022 at 5:30 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    larger trailers also maneuver easier than smaller ones, especially if you aren't used to backing trailers up
  16. Nov 10, 2022 at 5:34 AM
    IowaGuy
    IowaGuy New Member
    In Process
    I like the dual axle trailers because if you blow a tire it is usually not as destructive and scary event. A blown tire on a dual axle lets you get to a safer place to pull over.
  17. Nov 10, 2022 at 6:10 AM
    Most I’ve ever paid for gas. Definitely don’t buy the fuel at the first stop off of the interstate.
  18. Nov 10, 2022 at 6:33 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    They also don't bounce like single axles do.
  19. Nov 11, 2022 at 2:51 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    If one does stop in Needles and see a sign advertising "best ribs", they are not.
    Had a short job in Needles several years ago. Hopefully that large reefer processing facility has done something for the little town.
    Medic343 and MadMaxCanon like this.
  20. Nov 11, 2022 at 2:45 PM
    2mchfun
    Above all else, remember it's back there. Tiny light loads can be easy to forget about if you get distracted. Safe travels!
  21. Nov 13, 2022 at 3:16 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I get whatever extra insurance they offer. Saves me from doing a proper damage inspection, and getting screwed over by a bogus damage claim. Welcome to Houston. Guard your cats…
    Retired...finally and RCwyoming like this.
  22. Nov 13, 2022 at 10:39 AM
    kid84
    2019 Tundra 4x4 TSS
    Thank you ...
    Got shield covered my cat
    Luckydog[QUOTED] likes this.
  23. Nov 13, 2022 at 10:40 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I just so happen to have a uhaul 5x8 hooked to the back of my truck right now. Can’t feel it or see it back there, so make sure you check on it often.
    RCwyoming and 2mchfun like this.
  24. Nov 14, 2022 at 7:07 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Towed one 700 miles with my 4.6, max loaded and slightly over payload with stuff in my bed too. Didn't even feel it. Check your mirrors, go slow and stop slow, be mindful when making turns and you'll be just fine.
  25. Nov 14, 2022 at 8:53 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Get the insurance, or call your insurance company up and get a rider added to your policy for the trailer. **Important** Make sure whatever insurance you have covers the trailer and any damages resulting if the trailer detaches from you vehicle. Unlikely yes, but you need to read the fine print in the insurance. If a trailer detaches, and your insurance doesn't cover it, you could be up that famous creek without a paddle, especially if injuries occur.
