Towing with 37s
Discussion in 'Towing & Hauling' started by TundraPrime408, Nov 29, 2023.
  1. Nov 29, 2023 at 12:40 AM
    TundraPrime408
    TundraPrime408 [OP] New Member
    Lloyd
    2016 Toyota Tundra
    Hey guys,
    So I've been debating to go from 35s to 37s. I tow a Triton Bass boat with a 250hp mercury. The boat is fully rigged and tournament load with trailer is about 3200-3500lbs. I've been told that towing with 37s is rough.
    I was also told that a regear is pointless if my reason to regear is to save freeway miles which I know regear will take away freeway mpg.
    My question is, does anyone tow with 37s without regear and do you see a huge drop in performance?
    Thanks a bunch guys and Happy Holidays!
  2. Nov 29, 2023 at 3:35 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Not sure everyone here would agree that a regear is pointless if you want to tow. Larger tires and new gearing would get you back to a stockish ratio, which is the desired result. I know it's long but dig through the Dirtysevens Thread in the 2.5 Gen section. There are tons of guys who still tow setups similar to yours with 37's, most (not all) of them regeared. https://www.tundras.com/threads/dirty-seven-club.40397/
  3. Nov 29, 2023 at 5:58 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I regeared when I got 34s, can't imagine what 37s do
  4. Nov 29, 2023 at 6:30 AM
    JRS
    JRS New Member
    2012 DCLB
    My 2012 has the 4.3 rear, so consider that, but my opinion is that the truck needs bigger brakes more than gears. On brakeless trailers, if I'm pulling the boat or subcompact tractor (~3500lb) it's fine, if I'm pulling the compact tractor it isn't (~5800lb). 37s put a big hit on braking performance without a trailer involved. Of course that's irrelevant if yours has brakes.
    Also of note, I don't slam it up to speed. Maybe my acceptability criteria is lower?
    TundraPrime408[OP] likes this.
  5. Nov 29, 2023 at 6:37 AM
    Aren't you the one complaining about "poor" fuel economy?
    As for 37s with stock gears, you will absolutely feel it. The truck will still run and pull your boat, but you would definitely see an improvement if you regear it properly.
  6. Nov 29, 2023 at 8:13 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I regeared on 33s just for towing and Only regret not having done it sooner. Calculated Load % shows the truck isn't working as hard, too.
    TundraPrime408[OP] and KNABORES like this.
  7. Nov 29, 2023 at 3:54 PM
    TundraPrime408
    Lloyd
    2016 Toyota Tundra
    Yes I did. Lol but I'm trying to cover all bases before I regear getting opinions because regear will be the last thing I do once I decide all my upgraded parts are put on.
  8. Nov 29, 2023 at 3:55 PM
    TundraPrime408
    Lloyd
    2016 Toyota Tundra
    Thanks for this link. I'll look into it for sure.
    BreyTundy[QUOTED] likes this.
  9. Nov 29, 2023 at 4:06 PM
    Marshwalker
    Marshwalker New Member
    Z
    It’s been my best upgrade of any add one on my last trucks. Mine is getting 5.29 next month
  10. Nov 29, 2023 at 4:33 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Depends on your expectations, for me towing that weight with 4:30's and 37's would be nothing to worry about.
    I went to 5:29's but I tow 8-9K a couple times a week
    TundraPrime408[OP] and Hightide like this.
  11. Nov 29, 2023 at 8:07 PM
    TundraPrime408
    Lloyd
    2016 Toyota Tundra
    That's good to know and thanks. That's 4:3 was the ratio I was originally looking at.
  12. Nov 29, 2023 at 9:44 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I also went with 5.29s when I put 34” tires on. It is amazing…. Empty is amazing, a towing my 25’ TT is better than when the truck was 100% stock.
    Zero appreciable change in fuel economy, but a huge gain in drivability. If someone is telling you that regearing a Tundra will increase your fuel consumption due to increased rpm at speed, they are absolutely mistaken.
    Lower gears=more mechanical advantage=less load on engine=more timing advance and less fuel to make the power necessary for the condition.
    A lot of people get hung up on the gear ratio in the rear axle and think that a 4.30 ratio is super low. That may be accurate if our 6th gear ratio wasn’t in the 0.57:1 range. It’s a pretty steep overdrive, which kills that “really low” axle ratio. In my opinion, our trucks could use lower gears in stock form…
    I’d rather slam my dick in a car door than run 37” tires with stock gears!
    Rodtheviking likes this.
  13. Nov 29, 2023 at 11:07 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    37s and stock gears here lol 37s and 4.88s on the old man’s rig and he tows
    rockmup and Mater like this.
  14. Nov 30, 2023 at 10:59 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    I always forget that you’re on 4.30s! With your big power, I’m sure it rips, but how does it compare to your dad’s? Isn’t he SC also? Seems like there would be advantage to low gears with them big knobby knobby tires even after SC.
    I should clarify that I’d rather slam my dick in a car door than have a N/A Tundra on 37s with stock gears.
    reywcms[QUOTED] and Rodtheviking like this.
  15. Nov 30, 2023 at 11:04 AM
    4:30 is the stock gearing.
    rockmup likes this.
  16. Nov 30, 2023 at 12:13 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Haha yea he’s on a whipple also. He definitely thinks 4.88 good for none towing but sometimes in small situations the 5.29 would be nice.
    Not bad for 4.30s lol https://youtube.com/shorts/s7dbr-TAwcA?si=JxOs0f9vpdRE5LDG
    BreyTundy and TOYOTARIG like this.
  17. Nov 30, 2023 at 12:42 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Regear to make the truck not anameically underpowered feeling, makes no considerable difference in mpg in my experience.
    rockmup and reywcms like this.
  18. Nov 30, 2023 at 12:53 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    37s and 5.29 here no problem towing the 6quads and trailer really don’t even feel it.
    AZBoatHauler and reywcms like this.
  19. Nov 30, 2023 at 2:04 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    This is quite the statement! :eek:
    I think @reywcms needs to grab a trailer and meet up with you. Open both drivers doors and see which one you choose to get in… but if you get in yours, better drop your pants beforehand:itllbuffout:
    reywcms likes this.
  20. Nov 30, 2023 at 2:14 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    lmao
    Mater[QUOTED] likes this.
  21. Nov 30, 2023 at 10:50 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Shit. That’s no good, I’m headed to Rey’s hood in the morning! Until right meow, I’d hoped to meet him and check out his truck…
    At this time, I want to make it perfectly clear that I am only claiming that a door slam to the dick is preferred to driving a NATURALLY ASPIRATED truck with stock gears and 37” tires. Since I don’t have stock gears (or 37” tires) and Rey isn’t N/A, I’m hoping to avoid any opportunity that involves my tallywacker and any swinging part of a truck! lol.
    GODZILLA, reywcms[QUOTED] and Mater like this.
  22. Dec 4, 2023 at 2:37 PM
    rockmup
    rockmup New Member
    Todd
    I like my dick far too much to even consider that .....................
  23. Dec 5, 2023 at 7:57 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    On 37s and stock gears and towing a camper trailer weighing about 3500-4000lbs loaded. Pulls fine but definitely feel the lost of power when going uphill. Planning for 5.29gears soon IMG_6901.jpg
  24. Dec 12, 2023 at 10:35 AM
    SD Surfer
    Bruce
    So Cal
    As a kid I had my finger slammed in the door of a '72 Plymouth Fury III Station Wagon. (I still think my older sister did it on purpose.)
    Like, finger in door, door latched, Dad had to open door. :eek2:
    This is triggering some PTSD
    TundraPrime408[OP] and bflooks like this.
  25. Dec 12, 2023 at 11:41 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Thumb, week before Xmas in third grade. 1980 Caprice Classic, 2 door. Same scenario, in locked latch. Thumb has never fully recovered and neither have I, and thinking about it being a penis, I am nauseous.
  26. Dec 17, 2023 at 10:46 AM
    TundraPrime408
    Lloyd
    2016 Toyota Tundra
    Ouch
  27. Dec 17, 2023 at 11:17 AM
    centex
    centex New Member
    I gained 2mpg towing going from 4.30’s to 5.29’s. From 7 to 9 towing a 4 door rzr on a 16’ trailer. No change around town mileage but the truck drives so much better with the 5.29’s and I’m only on 34’s. Can’t imagine being on 37’s.
    Chad D. likes this.
